[Other] Tabulated thermophysicalProperties library
Like Tree37Likes
Old   January 7, 2019, 04:59
Jianrui Zeng
calf.Z is on a distinguished road
Originally Posted by janGaertner View Post
What you use depends on the table you have. If your viscosity table is organized with temperature as the first argument you have to use muTable(T,p) otherwise muTable(p,T).
Thanks for the clarification.
I think the thermophysicalTable.py provided in the github link just allows you to transform the format of the tabulated table?
If I want to obtain thermo propertities from NIST or coolprop, should I write another .py code to realize it? Thank you.
calf.Z is offline   Reply With Quote
Old   January 7, 2019, 09:44
Yuusha is on a distinguished road
The python script allows you to import tables from any text file which is formatted in csv or equivalent. Use python3 thermophysicalTable.py --help to see all available options.
@Yuusha: Maybe it would be good to change this to be consistent with the function call.
Most of the time, I need many different temperatures and only one or a few different pressures. That's why I prefer the format with one line by temperature when it is possible. I think it is more human readable.
Yuusha is offline   Reply With Quote
Old   February 3, 2019, 18:23
Thumbs up 2 new versions for tables
  #43
Two new versions of thermophysical tables is available at GitHub : https://github.com/Yuusha0/tabulated...icalProperties
The first one (v.3.1.0) fixes several bugs, improve the tutorial and add a bahsrc file in etc/ directory. This file let you choose the folder when you want to place the source code. It does not break compatiility with older versions.
The second one (v.4.0 and master branch) add tables for density-based solvers (thanks to calf.Z), and change the out of bound default boundary from extrapolate to clamp. This last feature may break backward compatibility.
wyldckat and vince_cfd like this.
Old   February 7, 2019, 04:37
Henrik Johansson
HenrikJohansson is on a distinguished road
Would it be possible to compile this library for foam-extend 4.0?
What would the changes needed to be to implement it if not compatible?
I'm currently using the real gas branch of foam-extend by Chris Lucas but having problems calculating the NASA polynomials correctly.
/ Henrik Johansson
HenrikJohansson is offline   Reply With Quote
Old   February 8, 2019, 15:33
Hi Henrik,
Unfortunately I never used foam-extend. So I don't know if it is easy to port the tables in it. Did you test to compile the source code with foam extend ? Did you see any errors ?
Old   February 11, 2019, 05:05
Henrik Johansson
Hi Yuusha,
It can't open wmake/scripts/AllwmakeParseArguments when running ./Allwmake.
So I removed the
$WM_PROJECT_DIR/wmake/scripts/AllwmakeParseArguments
Then i get the following error
tabularThermo/tabularThermo.H:39:25: fatal error: fluidThermo.H: No such file or directory compilation terminated.
rhoTabularThermo/rhoTabularThermos.C:27:23: fatal error: rhoThermo.H: No such file or directory compilation terminated.
tabularThermo/tabularThermos.C:27:23: fatal error: psiThermo.H: No such file or directory compilation terminated.
chemistryReaders/chemistryReader/makeTabularChemistryReaders.C:28:39: fatal error: tabularThermoPhysicsTypes.H: No such file or directory compilation terminated.
tabularReactionThermo/tabularReactionThermos.C:29:31: fatal error: rhoReactionThermo.H: No such file or directory compilation terminated.
Maybe these five libraries are named diffrently in foam-extend. I have not yet had time to look into that. It could maybe also be a linking error in the make/options?
After futher examination of the code I saw that a few needed components for the tableRead codes have been implemented in foam-extend 4.1. I'm currently installing it.
After installing foam-extend 4.1 I get the following errors:
unknown option: '-u OpenFOAM'
usage: wmakeLnInclude [-f] <dir> [-lnOption]
    Link all the source files in the <dir> into <dir>/lnInclude
Note
    The '-f' option forces an update when the lnInclude directory already exists
    and also changes the default linking from 'ln -s' to 'ln -sf'.
Making dependency list for source file reaction/reactions/makeTabularReactions.C
could not open file tabularReactionTypes.H for source file reaction/reactions/makeTabularReactions.C
could not open file thermo.H for source file reaction/reactions/makeTabularReactions.C
could not open file tabularTransport.H for source file reaction/reactions/makeTabularReactions.C
could not open file hTabularThermo.H for source file reaction/reactions/makeTabularReactions.C
could not open file tabularEOS.H for source file reaction/reactions/makeTabularReactions.C
could not open file infiniteReactionRate.H for source file reaction/reactions/makeTabularReactions.C
SOURCE=reaction/reactions/makeTabularReactions.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/OpenFOAM/lnInclude -IlnInclude -I. -I/home/henrik/foam/foam-extend-4.1/src/foam/lnInclude -I/home/henrik/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/makeTabularReactions.o
reaction/reactions/makeTabularReactions.C:27:34: fatal error: tabularReactionTypes.H: No such file or directory
reaction/reactions/makeTabularReactions.dep:214: recipe for target 'Make/linux64GccDPOpt/makeTabularReactions.o' failed
make: *** [Make/linux64GccDPOpt/makeTabularReactions.o] Error 1
Making dependency list for source file tabularThermo/tabularThermo.C
Making dependency list for source file tabularThermo/tabularThermos.C
Making dependency list for source file rhoTabularThermo/rhoTabularThermo.C
Making dependency list for source file rhoTabularThermo/rhoTabularThermos.C
could not open file psiThermo.H for source file tabularThermo/tabularThermos.C
could not open file rhoThermo.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file fluidThermo.H for source file rhoTabularThermo/rhoTabularThermo.C
could not open file fluidThermo.H for source file tabularThermo/tabularThermo.C
could not open file rhoThermo.H for source file rhoTabularThermo/rhoTabularThermo.C
could not open file rhoThermo.H for source file tabularThermo/tabularThermos.C
could not open file makeThermo.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file makeThermo.H for source file tabularThermo/tabularThermos.C
could not open file Vector.H for source file rhoTabularThermo/rhoTabularThermo.C
could not open file Vector.H for source file tabularThermo/tabularThermo.C
could not open file tabularEOS.H for source file tabularThermo/tabularThermos.C
could not open file tabularEOS.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file incompressiblePerfectGas.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file Boussinesq.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file rhoConst.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file perfectFluid.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file PengRobinsonGas.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file adiabaticPerfectFluid.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file hTabularThermo.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file sensibleEnthalpy.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file sensibleInternalEnergy.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file thermo.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file hTabularThermo.H for source file tabularThermo/tabularThermos.C
could not open file tabularTransport.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file hePsiThermo.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file heRhoThermo.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file fluidThermo.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file Vector.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file heThermo.H for source file rhoTabularThermo/rhoTabularThermos.C
could not open file sensibleEnthalpy.H for source file tabularThermo/tabularThermos.C
could not open file sensibleInternalEnergy.H for source file tabularThermo/tabularThermos.C
could not open file thermo.H for source file tabularThermo/tabularThermos.C
could not open file tabularTransport.H for source file tabularThermo/tabularThermos.C
could not open file hePsiThermo.H for source file tabularThermo/tabularThermos.C
could not open file heRhoThermo.H for source file tabularThermo/tabularThermos.C
could not open file fluidThermo.H for source file tabularThermo/tabularThermos.C
could not open file Vector.H for source file tabularThermo/tabularThermos.C
could not open file heThermo.H for source file tabularThermo/tabularThermos.C
SOURCE=tabularThermo/tabularThermo.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/henrik/foam/foam-extend-4.1/src/finiteVolume/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/meshTools/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/transportModels/compressible/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/OpenFOAM/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/basic/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/reactionThermo/lnInclude -IlnInclude -I. -I/home/henrik/foam/foam-extend-4.1/src/foam/lnInclude -I/home/henrik/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/tabularThermo.o
SOURCE=tabularThermo/tabularThermos.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/henrik/foam/foam-extend-4.1/src/finiteVolume/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/meshTools/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/transportModels/compressible/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/OpenFOAM/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/basic/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/reactionThermo/lnInclude -IlnInclude -I. -I/home/henrik/foam/foam-extend-4.1/src/foam/lnInclude -I/home/henrik/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/tabularThermos.o
SOURCE=rhoTabularThermo/rhoTabularThermo.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/henrik/foam/foam-extend-4.1/src/finiteVolume/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/meshTools/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/transportModels/compressible/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/OpenFOAM/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/basic/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/reactionThermo/lnInclude -IlnInclude -I. -I/home/henrik/foam/foam-extend-4.1/src/foam/lnInclude -I/home/henrik/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/rhoTabularThermo.o
SOURCE=rhoTabularThermo/rhoTabularThermos.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/henrik/foam/foam-extend-4.1/src/finiteVolume/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/meshTools/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/transportModels/compressible/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/OpenFOAM/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/basic/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/reactionThermo/lnInclude -IlnInclude -I. -I/home/henrik/foam/foam-extend-4.1/src/foam/lnInclude -I/home/henrik/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/rhoTabularThermos.o
In file included from rhoTabularThermo/rhoTabularThermo.C:27:0:
rhoTabularThermo/rhoTabularThermo.H:39:25: fatal error: fluidThermo.H: No such file or directory
In file included from tabularThermo/tabularThermo.C:27:0:
rhoTabularThermo/rhoTabularThermo.dep:162: recipe for target 'Make/linux64GccDPOpt/rhoTabularThermo.o' failed
make: *** [Make/linux64GccDPOpt/rhoTabularThermo.o] Error 1
make: *** Waiting for unfinished jobs....
rhoTabularThermo/rhoTabularThermos.dep:468: recipe for target 'Make/linux64GccDPOpt/rhoTabularThermos.o' failed
make: *** [Make/linux64GccDPOpt/rhoTabularThermos.o] Error 1
tabularThermo/tabularThermos.dep:471: recipe for target 'Make/linux64GccDPOpt/tabularThermos.o' failed
make: *** [Make/linux64GccDPOpt/tabularThermos.o] Error 1
tabularThermo/tabularThermo.dep:162: recipe for target 'Make/linux64GccDPOpt/tabularThermo.o' failed
make: *** [Make/linux64GccDPOpt/tabularThermo.o] Error 1
Making dependency list for source file chemistryReaders/chemistryReader/makeTabularChemistryReaders.C
Making dependency list for source file tabularReactionThermo/tabularReactionThermos.C
could not open file rhoReactionThermo.H for source file tabularReactionThermo/tabularReactionThermos.C
could not open file heRhoThermo.H for source file tabularReactionThermo/tabularReactionThermos.C
could not open file hTabularThermo.H for source file tabularReactionThermo/tabularReactionThermos.C
could not open file heTabularThermo.H for source file tabularReactionThermo/tabularReactionThermos.C
could not open file tabularEOS.H for source file tabularReactionThermo/tabularReactionThermos.C
could not open file thermo.H for source file tabularReactionThermo/tabularReactionThermos.C
could not open file tabularTransport.H for source file tabularReactionThermo/tabularReactionThermos.C
could not open file tabularThermoPhysicsTypes.H for source file chemistryReaders/chemistryReader/makeTabularChemistryReaders.C
SOURCE=chemistryReaders/chemistryReader/makeTabularChemistryReaders.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/henrik/foam/foam-extend-4.1/src/transportModels/compressible/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/OpenFOAM/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/thermophysicalModels/basic/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/basic/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/solidSpecie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/reactionThermo/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/henrik/foam/foam-extend-4.1/src/foam/lnInclude -I/home/henrik/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/makeTabularChemistryReaders.o
SOURCE=tabularReactionThermo/tabularReactionThermos.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/henrik/foam/foam-extend-4.1/src/transportModels/compressible/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/OpenFOAM/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/thermophysicalModels/basic/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/basic/lnInclude     -I/home/henrik/foam/foam-extend-4.1/tabulatedThermophysicalProperties-master/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/specie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/solidSpecie/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/thermophysicalModels/reactionThermo/lnInclude     -I/home/henrik/foam/foam-extend-4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/henrik/foam/foam-extend-4.1/src/foam/lnInclude -I/home/henrik/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/tabularReactionThermos.o
chemistryReaders/chemistryReader/makeTabularChemistryReaders.dep:225: recipe for target 'Make/linux64GccDPOpt/makeTabularChemistryReaders.o' failed
make: *** [Make/linux64GccDPOpt/makeTabularChemistryReaders.o] Error 1
tabularReactionThermo/tabularReactionThermos.dep:588: recipe for target 'Make/linux64GccDPOpt/tabularReactionThermos.o' failed
make: *** [Make/linux64GccDPOpt/tabularReactionThermos.o] Error 1
Looks like alot of files are missing. Maybe the implementation would be alot diffrent in foam-extend. At least with extend 4.1 the table reader library is implemented.
/ Henrik Johansson
Old   March 30, 2019, 16:23
Question
  #47
.bastian is on a distinguished road
Hi Yuusha, hi folks,
i kinda don't get it compiled using your instructions given on your github page.
Allwmake /home/sebastian/OpenFOAM/FOAMExtensions/tabulatedThermophysicalProperties/src
wmakeLnInclude: linking include files to OpenFOAM/lnInclude
wmake thermophysicalModels/specie
wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries:
    wmakeLnInclude error: base directory /home/sebastian/OpenFOAM/sebastian-6/src/OpenFOAM/ does not exist
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam6/src/thermophysicalModels/specie/lnInclude -I/home/sebastian/OpenFOAM/sebastian-6/src/OpenFOAM/lnInclude -IlnInclude -I. -I/opt/openfoam6/src/OpenFOAM/lnInclude -I/opt/openfoam6/src/OSspecific/POSIX/lnInclude   -fPIC -c reaction/reactions/makeTabularReactions.C -o Make/linux64GccDPInt32Opt/reaction/reactions/makeTabularReactions.o
In file included from lnInclude/tabularThermoPhysicsTypes.H:42,
                 from lnInclude/tabularReactionTypes.H:36,
                 from reaction/reactions/makeTabularReactions.C:27:
lnInclude/tabularEOS.H:41:10: fatal error: extrapolation2DTable.H: file or folder not found
 #include "extrapolation2DTable.H"
make: *** [/opt/openfoam6/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/reaction/reactions/makeTabularReactions.o] error 1
Can anyone give me a hint what I'm doing wrong?
EDIT: Got it. I've messed up the correct path in the bashrc.
.bastian is offline   Reply With Quote
Old   August 13, 2019, 16:59
igor
iiigoriii is on a distinguished road
Dear Yuusha,
thank you for your work. Could you please also add example with tabular reaction?
Thanks, BR, ii
iiigoriii is offline   Reply With Quote
Old   August 14, 2019, 08:00
Hi iiigoriii,
Unfortunately I havent'got a case with reactionThermo. I have tested it a long time ago with a two gas mixture without reaction and it works well. However I do not use it anymore.
Maybe you can try to modify the current tutorial by adding a second specie and look at OpenFOAM reacting test cases to add the needed files.
I have added a issue in GitHub to remind me to add a reacting tutorial case.
Old   November 22, 2019, 06:08
Default Support for OFv7
  #50
Vincent
vince_cfd is on a distinguished road
Hallo everyone,
has anyone tested this under OFv7 yet? I can't make it work in OFv7, but I'm not sure if I'm doing it wrong, or if it's a compatibility problem.
Using the ./Allwmake command seems to do a lot, but also returns an error at the end:
/home/cfd/OpenFOAM_ESI/OpenFOAM-v1906/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt32Opt/tabularThermo/tabularThermos.o' failed
 make: *** [Make/linux64GccDPInt32Opt/tabularThermo/tabularThermos.o] Error 1
When trying to run the tutorial testcase it returns >>>could not load "libTabularThermophysicalModels.so"<<< and some other library files.
Any ideas?
EDIT: Just found the OF7 version: simply click on the Branch drop-down menu and select the correct version. Installing it now.
vince_cfd is offline   Reply With Quote
Old   December 4, 2019, 14:09
Exclamation Tabulated thermo properties in parallel?
  #51
CarlosRom90 is on a distinguished road
Hello everyone,
I have tried to compute in parallel the tutorial case from https://github.com/Yuusha0/tabulated...icalProperties.
Surprisingly, it didn't work with the decomposeParDict delivered in tutorial case system folder, where the authors proposed to use the "scotch" methods.
I even tried with simple decomposition but it also failed.
Any ideas?
Thanks in advance.
PS: The decomposeParDict file in below:
| \\ / O peration | Version: 5 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object decomposeParDict;
numberOfSubdomains 8;
method scotch;
CarlosRom90 is offline   Reply With Quote
Old   December 5, 2019, 07:24
Any ideas?
Ciao Carlos,
this should do the trick:
1. Comment or remove the following lines in your control dict, that this:
libs
    "libuserspecie.so"
    "libtabularReactionThermophysicalModels.so"
becomes:
// libs
//     "libuserspecie.so"
//     "libTabularThermophysicalModels.so"
//     "libtabularReactionThermophysicalModels.so"
2. Run decomposePar
3. Undo step 1 and run your simulation.
Certainly not the most elegant solution, baer it works - At least for me
SHUBHAM9595 and CarlosRom90 like this.
Old   January 27, 2020, 15:32
Default Official release for OpenFOAM-7
  #53
The official release for OpenFOAM-7 is available on GitHub : https://github.com/Yuusha0/tabulated...icalProperties.
Sorry for the long delay. Apart from the switch to OpenFOAM-7 this new release brings some fixes.
First, a new numbering system is used for release. I think it is easier to understand. The first number is the OpenFOAM version (in that case 7), the second number is the tabulated properties version for this OpenFOAM (so 7.1 for the first with OpenFOAM-7) and the last number will be used for bug fixes (actually it is 7.1.0).
Second, the bug with sensibleEnthalpy model is now (normally) fixed. Feel free to test it if you have cases using this model.
Third, the tutorial has been improved. It is a more physical case and it supports sensibleEnthalpy thermopysical model.
And last but not least, old version (OpenFOAM-6 one) is now preserved in a Old_OF6 version on GitHub. So it will be easier if you want to download it or suggest bug fixes.
Old   January 28, 2020, 14:31
Exclamation Tabulated thermo + chtMultiRegionFoam
  #54
Hi everyone,
First, thanks .bastian your tip worked in my case
Second, Yuusha, I was wondering if the tabulated thermo would work for cases with conjugate heat transfers (chtMultiRegionFoam).
Thank you!
Old   January 29, 2020, 04:26
Hi CarlosRom90,
There is no problem for using the tabulated thermo for the fluid part in chtMultiRegionFoam. Unfortunately, you cannot use it for the solid part.
Old   January 29, 2020, 12:57
Exclamation Tabulated thermo + chtMultiRegionFoam (2)
  #56
Thank you for your answer Yuusha.
I'm trying to use chtMultiRegionFoam solver with tabulatedThermo (fluid part).
To test both together I used the heatTransfer/chtMultiRegionFoam/heatedDuct tutorial as test case.
So, I added the required libraries inside controlDict:
libs
"libuserspecie.so"
and when I run the simulation to check the available thermophysical models I get only the following with tabularThermo:
" heRhoThermo-reactingMixture-tabular-hTabular-tabularEOS -specie-sensibleInternalEnergy "
I am interested in:
heRhoThermo-pureMixture-tabular-hTabular-tabularEOS -specie-sensibleInternalEnergy
heRhoThermo-pureMixture-tabular-hTabular-tabularEOS -specie-sensibleEnthalpy
I think it should not be too complicated, but I tried to modified the src/ folder inside the tabulatedThermophysicalProperties-master and I didn't success...
Could you maybe give me an advice?
Thank you in advance!
Originally Posted by Yuusha View Post
Hi CarlosRom90,
Old   February 2, 2020, 00:46
Default tabularThermo for OF 4.x
  #57
ata
ata313ata is on a distinguished road
Dear tilasoldo,
Have you succeeded to adapt it for OF 4.x?
Originally Posted by tilasoldo View Post
Hi chriss85,
First of all thank you for your work, I am amazed by the fact that OpenFoam still doesn't provide a solution for tabulated thermophysical properties, and you implementation is truly wonderful.
I am (also) aiming at adapting it for OpenFOAM 4.x, as some classes have changed since OF 2.3 I will publish my code as soon as I get to validate it!
Regards,
Xavier L.
ata313ata is offline   Reply With Quote
Old   February 3, 2020, 06:45
I am interested in:
Ok. I don't know why but OpenFOAM uses reaction thermo for chtMultiRegionFoam.
You have to edit the tabularReactionsThermos.C file in the src/thermophysicalModels/reactionThermo/tabularReactionThermo/ directory. Copy the structure written line 56 paste in the same file whith the desired properties. Maybe it is :
makeReactionThermos
rhoThermo,
rhoReactionThermo,
heRhoThermo,
pureMixture,
tabularTransport,
sensibleInternalEnergy,
hTabularThermo,
tabularEOS,
specie
and
makeReactionThermos
rhoThermo,
rhoReactionThermo,
heRhoThermo,
pureMixture,
tabularTransport,
sensibleEnthalpy,
hTabularThermo,
tabularEOS,
specie
Recompile the src folder and it should work.
Old   February 3, 2020, 06:52
Originally Posted by ata313ata View Post
Dear tilasoldo,
Hi ata,
I think we never publicly publish an OpenFOAM-4 version of the library. You can try version 1.x or 2.x in my GitHub which have been developed for OpenFOAM-5. But I'm not sure they work on OpenFOAM-4.
Old   April 8, 2020, 07:32
Default new thermophysicalModel, what are changes in files and options files
  #60
pranay
pranay347 is on a distinguished road
makeReactionThermos
rhoThermo,
rhoReactionThermo,
heRhoThermo,
pureMixture,
tabularTransport,
hTabularThermo,
tabularEOS,
specie
and
makeReactionThermos
rhoThermo,
rhoReactionThermo,
heRhoThermo,
pureMixture,
tabularTransport,
sensibleEnthalpy,
hTabularThermo,
tabularEOS,
specie
hi
i am too trying to make a new thermophysicalModel for my case i just need to make new combination of
thermoType
type heRhoThermo;
mixture pureMixture;
transport sutherland;
thermo hPolynomial;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy
so i added this class in thermophysicalModel/basic/rhoreaction/rhothermos.c file and compiled without changing the file and option files in make folder, it compiled but not using in the simulation as its giving same error of "unknown reaction thermo" and listing valid thermo types.
so do i need to change the files and option files ? if so what are the changes? and any other changes?
Thank you
Pranay
pranay347 is offline   Reply With Quote
[Other] Multi species mass transport library [update] novyno OpenFOAM Community Contributions 111 November 10, 2021 00:37
ERROR: unable to find library HJH CFX 6 February 26, 2019 07:52
Forcing a solver to use your custom library. cdunn6754 OpenFOAM Programming & Development 0 March 30, 2017 17:05
Compiled library vs. inInclude Files, DSMC solver crashes after run GPesch OpenFOAM Programming & Development 8 April 18, 2013 08:17
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 16:49
