[swak4Foam] groovyBC - PULSATIL PRESSURE
Old   September 7, 2014, 01:18
Smile groovyBC - PULSATIL PRESSURE
Tommy Sp
vitorspadeto is on a distinguished road
Can you tell me if my code is right?
My intention is to apply a pulsating pressure at the inlet with the FUNCION: P = A + A*sin(pi*time) , WHERE A=100 Pa (unit in Pa) .... NOTE that the units are [0 2 -2 0 0 0 0] on the description of p file.
This is my code:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    outlet
        type fixedValue;
        value uniform 0;
inlet
     type            groovyBC;
     variables "var=100/1050;";
     valueExpression "(var+(var*sin(pi*time())))"; //*normal();
wall
        type extrapolatedPressure;
        value uniform 0;
1- I divided "var" by 1050kg/m³(that is density of fluid). Am I right? WHERE A=100 Pa (unit in Pa) .... NOTE that the units are [0 2 -2 0 0 0 0]
2- I don't use "(var+(var*sin(pi*time())))*normal()" because I believe that pressure is not a vector. Am I right?
Best Regards,
Vitor Spadeto Venturin
vitorspadeto is offline   Reply With Quote
Old   September 7, 2014, 08:52
Assistant Moderator
Bernhard Gschaider
This is my code:
boundaryField
    outlet
        type fixedValue;
        value uniform 0;
inlet
     type            groovyBC;
wall
        value uniform 0;
Looks OK. Why are you asking? To check whether the BC does what you want without running the solver you can use replayTransientBC (which comes with swak)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
Outlet pressure aja1345 FLUENT 5 August 18, 2015 12:02
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
[swak4Foam] using of field pressure values at groovyBC immortality OpenFOAM Community Contributions 2 November 23, 2012 18:10
Unsteady pressure differential between inlet and outlet of the pipe for single phase joshi20h FLUENT 0 September 26, 2012 13:41
