[ImmersedBoundary] Immersed Boundary Method in OpenFOAM-3.1-ext
Like Tree29Likes
Old   May 22, 2020, 10:27
Shang-Gui Cai
cookcaptain is on a distinguished road
Thanks for your quick reply. But I am not able to see the pictures. By the way, the wall pressure and the skin friction are not smooth, maybe the inherent shortcoming of this type of immersed boundary method ?
cookcaptain is offline   Reply With Quote
Old   June 2, 2020, 14:28
Default Deform (change shape) of Immersed Boundary
  #102
André da Luz Moreira
andredaluzmoreira is on a distinguished road
Hi!
Anyone with previous experience in deforming the shape of an immersed boundary region at each time step?
I have an experimentally measured motion of a deformable wall, and I need to prescribe this motion/deformation at each time step by interpolating from these data.
I am using foam-extend-4.1 and so far I only found cases where boundaries have a rigid body motion.
Thanks!!
André
andredaluzmoreira is offline   Reply With Quote
Old   June 4, 2023, 13:55
Question
  #103
Thomas Shi
ThomasLong is on a distinguished road
Originally Posted by mosaferkarbala View Post
hey
do u find where this error comes from! im stuck on same error, any help would be appreciated
--> FOAM FATAL ERROR:
[0] tauWall not set for IB patch hull for field U
[0]
[0] From function const vectorField& immersedBoundaryVelocityWallFunctionFvPatchVectorF ield::wallShearStress() const
[0] in file wallFunctions/immersedBoundaryVelocityWallFunctions/immersedBoundaryVelocityWallFunctionFvPatchVectorF ield.C at line 200.
thanks
Hello! I am facing the same problem. Have you got any solution?
ThomasLong is offline   Reply With Quote
Old   June 16, 2023, 06:41
Default How to set tauWall in immersedBoundaryEpsilonWallFunction
  #104
Thomas Shi
Originally Posted by Phil_ View Post
Dear all,
so foam-extend next release (release 3.2) is available and I ran a small test for the immersed boundary.
For the kEpsilon turbulence model it works like a charm, but with the kOmegaSST model it complains about "tauWall not set for IB patch ibChannel for field U". In the kEpsilon model tauWall is set by the immersedBoundaryEpsilonWallFunction. This wall function is replaced by immersedBoundaryOmegaWallFunction where tauWall is not defined.
Any ideas?
In the meantime I'll dig in a little more and try to find out what's going on.
Phil
Dear Phil, I am struggling with the problem of "tauWall not set for IB patch ibChannel for field U" when I use k-epsilon model in immersed boundary method. Would you please show me how to set tauWall in immersedBoundaryEpsilonWallFunction? Thank you in advance!
Old   June 16, 2023, 06:54
Hrvoje Jasak
Hi, You are looking at the ancient version of Immersed Boundary Code. It has been re-written twice since. Please see the foam-extend-5.0 code instead.
Hrv
Hrvoje Jasak
Old   June 16, 2023, 10:31
Thomas Shi
Hrv
Thanks for your reply! I found it no problem with boundary condition in foam-extend 5.0. But I want to use a forceBased library (discribed in http://www.tfd.chalmers.se/~hani/kur...eirsson/OF.pdf) which is compiled in foam-extend 4.0. I tested a case in laminar with no problem. While it came to turbulence flow, an error with "tauWall not set for IB patch ibCylinder for field U" occured. So, I want to know how to solve this problem.
Old   July 3, 2023, 11:26
Default Hello gus Did you have this problem?
  #107
Grp
GrpOne123 is on a distinguished road
The force coefficient oscillates intensely4e967c7cb91a0ba295b40aa72f4e8c8.jpg
GrpOne123 is offline   Reply With Quote
immersed boundary method, openfoam-1.6-ext, openfoam-3.1-ext
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
implementation of the Immersed Boundary Method mi_cfd Main CFD Forum 19 April 24, 2019 02:24
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
[ImmersedBoundary] who has the paper about immersed boundary method in openfoam blueshit OpenFOAM Community Contributions 1 November 18, 2013 08:16
