[ImmersedBoundary] Immersed Boundary Method in OpenFOAM-3.1-ext |
August 29, 2015, 23:56 |
#41 |
Ali
Rep Power: 12 |
Dear Prof Hrvoje Jasak,
Thank you very much for your reply. In foam extend-3.2, the cylBumpInterIbFoam tutorial runs without any problem. But if I refine the ibCylinder for level 3 using refineImmersedBoundaryMesh -ibCellCellFaces the solver show all.points < 5: 2 , If I use level 4 refinement it end up with singular matrix error, If I refine ibCylinder region using mesh refinement options the courant number diverges after 0.10 sec. I am wondering about refinement technique which can be used for immersed body. Actually I want use immersed boundary method (as overset is not available in public release) for dynamic body simulation in waves. Best Regards, Ali |
October 8, 2015, 03:18 |
Rotating ImmersedBoundaries
#42 |
Robert Grandl
Rep Power: 11 |
Hy,
I'm trying to make the ImmersedBoundaries move. I already had a look in to the source code. Unfortunately, I did not understand it realy good. Can someone tell me, which file or where I can find the code, which is resposible to read the .stl-files. It whould be realy nice, if some one can give me a short overview ouver the programm structures of immersed boundaries. Best regards RobertG. |
October 8, 2015, 05:41 |
#43 |
Rep Power: 12 |
Hi Robert,
I looked into this too but couldn't find a proper solution yet. If you "just" want to move the IB but not alter the body-shape you can take a look at the movePoints() / moveTriSurfacePoints() method in immersedBoundaryPolyPatch.C. It should be possible to move the already existing IB-points. (I think this happens via dynamicMesh handling.) If you want to alter the IB-body-shape altogether it's getting complicated. I have not been able to read in a new .stl/.ftr during runtime. If someone has a clue how to do that, please respond Best regards, Philip Last edited by Phil_; October 8, 2015 at 07:26. |
October 8, 2015, 06:54 |
#44 |
Hrvoje Jasak
Rep Power: 33 |
Have a look in 3.2 nextRelease branch: I made a dynamic mesh class and a tutorial for a moving immersed boundary.
Enou
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
October 8, 2015, 10:01 |
#45 |
Robert Grandl
Rep Power: 11 |
Hello Philip and Prof. Hrvoje Jasak,
thanks a lot for your fast replay. I want to simulate an twin screw extruder. Therefore, I have two rotating parts. But I want to couple the CFD-Simulation with an DEM-Simulation, using foam-extendet, LIGGGHTS and CFDEM. So, I have to create my own solver, based on the cfdemSolverPisoScalar. Is it possible? Best regards RobertG. |
October 8, 2015, 10:18 |
#46 |
Hrvoje Jasak
Rep Power: 33 |
I don't think you can do a screw extruder with immersed boundary. Tolerances in the gap are just too fine and the flow is critically dependent on the resolution in gaps.
At Wikki we have done projects with screw equipment using custom mesh motion. This is probably some of the most beautiful and challenging moving mesh cases I have seen or done Not easy, though. Doing this through Wikki would require funding and an industrial partner; you are most welcome to try IBM or alternative dynamic mesh, but be advised: this is not easy! Hrv
October 8, 2015, 11:31 |
#47 |
Robert Grandl
Rep Power: 11 |
Hello Prof. Hrvoje Jasak,
I'm sorry, I used, the term twin screw extruder, because, it is more common. In fakt it is more than a co-rotating twin screw mixing reactor. The rotation-zylinder of both screw are overlapping, which is the reason, why I can't use the dynamic meshing. But, between the two screw is always enough space. Thanks a lot for your help. Best regards RobertG |
October 8, 2015, 13:24 |
#48 |
Daniel Brunner
Rep Power: 11 |
Dear Prof. Hrvoje Jasak
I am trying the analyze the vortex formation / stability etc. at a flapping / heaving fin. Therefore the I'd like to use the immersed boundary method. As you mentioned you've made a dynamic mesh class and a tutorial for the immersed boundary method. Unfortunately we cannot find it. All of the tutorials of the immersed boundary of the version 3.2 extended (http://sourceforge.net/p/openfoam-ex.../ci/v3.2/tree/) are static. Are we missing something? Thanks for the help Daniel |
October 8, 2015, 13:49 |
#49 |
Robert Grandl
Rep Power: 11 |
Dear Prof. Hrvoje Jasak,
just now, i tried to download the newes version fe32. When I open the Link at the browser, I see, that there are tutorials for IB. However there are missing, when I download fe32 via the given git command/url. But using the "Download Snapshot"-Button works fine ?! Thanks a lot for the support and your work. Best regards RobertG |
October 8, 2015, 18:47 |
#50 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quoting myself from a few minutes ago:
October 9, 2015, 03:13 |
#51 |
Rep Power: 12 |
is it already possible to vary the geometry of the immersed body over time? In the tutorial case the cylinder moves but there's no change in shape. Best regards Philip |
October 9, 2015, 09:31 |
#52 |
Daniel Brunner
Rep Power: 11 |
Bruno
Thank you very much for the link. However something is wrong with the dynamic mesh file. In my case it contains just a "+" at the top and the next ca. 850 lines are empty, which makes no sense to me. The same thing holds true if I try to download it directly by your posted link. Thanks Daniel |
October 10, 2015, 05:49 |
#53 |
Bruno Santos
Rep Power: 128 |
I've tested it now. There are a few glitches in his repository. For the fixes, see post #11 in this thread: http://www.cfd-online.com/Forums/ope...tml#post567429
edit: For questions and issues about the Dynamic Meshing with Immersed Boundary Method, please use the dedicated thread: http://www.cfd-online.com/Forums/ope...hannelico.html Last edited by wyldckat; November 7, 2015 at 12:47. Reason: see "edit:" |
January 21, 2016, 04:24 |
Potential Flow
#54 |
Rep Power: 12 |
Dear all,
has anyone noticed the potentialIbFoam not working as expected? Please see the attached pic showing the streamlines of the potential solution for a pitzDaily. Is this known? Is there already a fix available? Or am I doing something wrong? Best regards, Philip |
January 21, 2016, 04:39 |
Potential Flow
#55 |
Rep Power: 12 |
The mentioned behaviour can be noticed in turbulent cases, e.g.
tutorials/immersedBoundary/backwardStepShortTurbulentSimpleIbFoam tutorials/immersedBoundary/pitzDailyTurbulentSimpleIbFoam |
January 21, 2016, 07:06 |
#56 |
Robert Grandl
Rep Power: 11 |
January 29, 2016, 02:39 |
Turbulent IBM behaviour
#57 |
Rep Power: 12 |
Dear all,
for a fully developed 2D channel flow at Re=25.000 calculated with k-epsilon turbulence model I get quite different results with simpleIbFoam compared to simpleFoam. Can anyone confirm this? Best regards, Philip |
February 2, 2016, 08:32 |
#58 |
Robert Grandl
Rep Power: 11 |
I have created a new solver, which uses ImmersedBoundarys which are provided at foamExtend 3.2 . Unfortunately, I don't need the ImmersedBoundarys at all boundary condition. In dead, it causes at one point an Error in combination with an volScalarField boundary Condition. Is ist possible to swicht of the ImmersedBoundarys, at boundary condition at which Ib are not neccesery for a correct calculation? Thanks a lot. Best regards RobertG |
March 4, 2016, 08:52 |
#59 |
Rep Power: 12 |
Hi foamers,
I'm trying to validate the new Immersed Boundary solvers in the foam extended version 3.2. For the first case I've tryed the classic 2D cylinder at Reynolds =100. The body fitted simulation work fine, but with the IB I get some strange results. In fact the viscous Lift have a mean different to zero (see the attachments), but looking at the averaged time fields the wake is still simmetric to the cylinder axis, so I think that some mistakes are presents in the force calculation functionObject. Is someone experienced the same problems ?? Have you any guess to how correct the problem ? Thank you in advance, Nigo |
March 4, 2016, 10:00 |
#60 |
Hrvoje Jasak
Rep Power: 33 |
We have published laminar and turbulent flow validation results at ERCOFTAC last year and did a validation study on a moving immersed boundary this December.
Why don't you start from those cases and find out where you made q mistake. All validation cases are public
immersed boundary method, openfoam-1.6-ext, openfoam-3.1-ext |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
implementation of the Immersed Boundary Method | mi_cfd | Main CFD Forum | 19 | April 24, 2019 01:24 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
[ImmersedBoundary] who has the paper about immersed boundary method in openfoam | blueshit | OpenFOAM Community Contributions | 1 | November 18, 2013 07:16 |
