[flameletFoam] new flameletFoam for OpenFoam-2.3.0 |
July 14, 2015, 12:16 |
#21 | |
Hagen Müller
Rep Power: 15 |
that's correct, Yar/Yar_fuel is used. The code is in line 585 of Cantera-CounterflowFlame/src/flamelet.cpp. Best wishes, Hagen |
July 14, 2015, 16:12 |
Mixture fraction definition
#22 |
Rep Power: 12 |
Thank you Hagen and Wenxu,
So user must always specify a very small amount of Argon at the Fuel inlet right? But, flamelet script seems to work without initial solution with no Argon.How can that happen? In the paper suggested by Wenxu, by Prof Pitsch and Prof Peters discuss about a third method for mixture fraction which is different from more popular two feed system and Bilger's formula. They define mixture fraction conserved scalar transport equation. [Eqn 13] That method is quite similar to Argon transport equation, so I guess that is the theory behind using Argon ? |
February 18, 2017, 10:59 |
#23 | |
Faezeh
Rep Power: 14 |
i am using flameletfoam to simulate a DLR-A flame. as you may know it's a free flame and i have some troules with boundary conditions. the B.Cs are: Uinlet : fixedValue Uoutlet: inletoutlet Uoutside: pressureinletoutletvelocity T is calculated for all boundaries P is totalpressure at the outside and outlet and zerogradient at the inlet bounderies. but there is reflections in the outside boundaries. do you have any suggestion? thank you |
February 18, 2017, 14:23 |
#24 |
Bobby
Rep Power: 15 |
Hey Faeze
I am not working on combustion any more. However, for hinting you I should say: The reflections from outside boundary might happen more frequently in future when you want to simulate swirl flames Let me know are you using LES or RAS , give me a little perspective of your grid as well. I will put a general post so as to be useful for everybody and avoid multiple questions |
March 9, 2017, 10:33 |
Boundary conditions
#25 |
LE Van Minh
Hi everyone,
First, Hagen, I have to thank you very much for developing the new useful solver that help me a lot and this thread also is very interesting. Now, I'm confused some places in the Z boundary conditions of the case flame Sandia D in tutorial. In fact, the boundary condition of Z for patch PILOT is 0.271. How can you calculate this value? and can you explain it mathematically? PILOT { type fixedValue; value uniform 0.271; } Have a good day, Minh |
April 10, 2017, 03:05 |
#26 | |
Mukesh Adlak
Rep Power: 10 |
Hi Likun, I want to generate flamelets for h2-air non-premixed combustion. Can u help me how to do that using chem1d. Thanks |
Multiple Floating Objects with 6DoF in OF 2.3.0 | tyoung | OpenFOAM Running, Solving & CFD | 23 | June 11, 2024 01:13 |
[OpenFOAM.org] Problem in installing OpenFOAM 2.3.0 !!! | omid20110 | OpenFOAM Installation | 6 | August 1, 2016 11:20 |
Difference in the results between OF 2.3.0 and OF 2.4.0 simpleFoam | Olgierd | OpenFOAM Running, Solving & CFD | 0 | July 27, 2015 11:23 |
Liquid Evaporation Model Error in OF 2.3.0 | brbbhatti | OpenFOAM | 11 | June 16, 2014 09:40 |
Installing Mixing_plane in either OpenFOAM 2.3.0 or 1.6-ext | Jiricbeng | OpenFOAM Installation | 7 | May 18, 2014 15:46 |
