October 14, 2015, 08:02 |
Easiest way to calibrate elevation time trace?
#161 |
Pal Schmitt
Rep Power: 16 |
Dear All,
I am probably missing some obvious information. What is the easiest way to generate a given timetrace of surface elevation in IHFOam? I tried to use the wavemaker, but that seems to require paddel information which is not what I want. Any comments are much appreciated and thanks for making this interesting tool available! Cheers, Pal |
November 10, 2015, 07:01 |
Tunning of alpha (VOF)
#162 | |
Rafael Marques
Rep Power: 12 |
Hi Pablo, I am want to ask if you can indicate, in which Paper you about the tuning of the indicator alpha? I want to know a little bit more about this calibration. I wrote 3 of your paper but the are nothing about the tuning. thanks a lot, Greets Rafael Marques |
November 10, 2015, 07:31 |
#163 |
Pablo Higuera
Rep Power: 19 |
Hi Pal,
probably the best way is to decompose your signal into components by means of an FFT and set up the irregular waves. Hi Rafa, there is no calibration/tuning for that, check "Simulating coastal engineering processes with OpenFOAM": An alpha1 value of 0.1 has been used to consider a cell as inundated. This 10% threshold translates in an effective water height on those cells of 1.25 mm, which is a convenient value regarding the resolution of experimental devices. Best, Pablo |
November 10, 2015, 07:37 |
Tuning of VOF alpha
#164 |
Rafael Marques
Rep Power: 12 |
Hi Pablo,
Thanks for the quick response. I will check this paper. Thanks again you are helping me a lot! Greets Rafael Marques |
November 10, 2015, 09:13 |
Waves change as travelling in the domain
#165 |
Rep Power: 11 |
Hi Pablo,
I have received training in ihFoam in May and have a series of questions and would be grateful if you could help me with it. I am modelling stokesV waves and they are close to target at the wave-generating boundary, however, when waves travel inside the domain, their trough and crest locations change and make it challenging to correctly predict resultants that depend on the water column elevation. My wave height is 0.512 m and cubic cell size is 0.028 m. I appreciate it if you could help me with this. Cheers, Hossein |
November 19, 2015, 12:44 |
Compilation Error on Ubuntu 14.04 using OpenFoam 3.0
#166 |
Joseph D.
Rep Power: 10 |
Hi, I currently downloaded the IHFoam extension. During compilation It has been a success boundary conditions:
cd genAbs ./allMake Code:
user@user:~/ihFOAM/solvers/ihFoamFE30_31$ ./allMake Making dependency list for source file ihFoam.C could not open file cyclicAMILduInterface.H for source file ihFoam.C due to No such file or directory could not open file cyclicAMIPolyPatch.H for source file ihFoam.C due to No such file or directory could not open file twoPhaseMixture.H for source file ihFoam.C due to No such file or directory could not open file turbulenceModel.H for source file ihFoam.C due to No such file or directory could not open file readPIMPLEControls.H for source file ihFoam.C due to No such file or directory g++ -m32 -Dlinux -DWM_ARCH_OPTION=32 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam30/src/transportModels -I/opt/openfoam30/src/transportModels/incompressible/lnInclude -I/opt/openfoam30/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam30/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam30/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam30/src/OpenFOAM/lnInclude -I/opt/openfoam30/src/OSspecific/POSIX/lnInclude -fPIC -c ihFoam.C -o Make/linuxGccDPInt32Opt/ihFoam.o In file included from /opt/openfoam30/src/finiteVolume/lnInclude/ddtScheme.C:30:0, from /opt/openfoam30/src/finiteVolume/lnInclude/ddtScheme.H:337, from /opt/openfoam30/src/finiteVolume/lnInclude/fvcDdt.C:28, from /opt/openfoam30/src/finiteVolume/lnInclude/fvcDdt.H:199, from /opt/openfoam30/src/finiteVolume/lnInclude/fvc.H:44, from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:8, from ihFoam.C:64: /opt/openfoam30/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:35: fatal error: cyclicAMILduInterface.H: No such file or directory #include "cyclicAMILduInterface.H" ^ compilation terminated. make: *** [Make/linuxGccDPInt32Opt/ihFoam.o] Error 1 ihFoam compilation failed |
November 19, 2015, 13:52 |
#167 |
Pablo Higuera
Rep Power: 19 |
Hi Joseph,
you ere trying to compile Foam-extend version with OpenFOAM 3.0. I haven't had the time to prepare an OpenFOAM 3.0 solver yet. I guess you'll need to wait until I find some time or create it yourself. Best, Pablo |
November 19, 2015, 13:58 |
#168 |
Joseph D.
Rep Power: 10 |
I have tried compilation of ihFOAM in OpenFOAM 2.4.0, both compilation went successful. The problem i had posted above was encountered in OpenFOAM 3.0.0. It seems that the compilation of solvers of ihFOAM for OpenFOAM 3.0.0 still have a minimal problem.
November 19, 2015, 14:17 |
#169 | |
Joseph D.
Rep Power: 10 |
Thank you very much for your time. For the meantime, I will be using OpenFoam 2.4.0 since everything works fine for this version. By the way, I am new to OpenFoam so as to ihFoam, forgive me if I might ask some noob questions. Like I am trying now to try the tutorials, breakwater, specifically. Am I right to use "blockMesh" to create the Mesh? It gave no errors, however, after as I input to the terminal "ihFoam" for simulation, I encountered this error: Code:
--> FOAM FATAL IO ERROR: cannot find file file: /home/user/OpenFOAM/user-2.4.0/tutorials/OF230_240/breakwater/0/p_rgh at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting |
November 22, 2015, 02:09 |
breakWater Simulation Error
#170 |
Joseph D.
Rep Power: 10 |
Hi Pablo,
How are you? I managed to run now the blockMesh and ihFoam commands. I am using OpenFoam 2.4. However, I notice some questionable error that prompted in my terminal after I run the "ihFoam" : Code:
user@user:~/OpenFOAM/user-2.4.0/tutorials/OF230_240/breakwater$ ihFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : ihFoam Date : Nov 22 2015 Time : 13:41:18 Host : "user" PID : 31674 Case : /home/user/OpenFOAM/user-2.4.0/tutorials/OF230_240/breakwater nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field porosityIndex Porosity NOT activated Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon --> Upgrading k to employ run-time selectable wall functions Backup original k to k.old Writing updated k --> Upgrading epsilon to employ run-time selectable wall functions Backup original epsilon to epsilon.old Writing updated epsilon --> Creating nut to employ run-time selectable wall functions Writing new nut kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Reading g Calculating field g.h No finite volume options present time step continuity errors : sum local = 0, global = 0, cumulative = 0 DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 deltaT = 0.00119048 Time = 0.00119048 PIMPLE: iteration 1 alpha.water BC on patch inlet #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/opt/openfoam240/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #3 cnoidalFun::calculations(double, double, double, double*, double*) at ??:? #4 Foam::IH_Waves_InletAlphaFvPatchScalarField::updateCoeffs() at ??:? #5 Foam::fvPatchField<double>::evaluate(Foam::UPstream::commsTypes) at ??:? #6 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::evaluate() at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #9 ? at ??:? Floating point exception (core dumped) I then tried to run ParaView to see the simulation: Code:
user@user:~/OpenFOAM/user-2.4.0/tutorials/OF230_240/breakwater$ paraFoam created temporary 'breakwater.OpenFOAM' Is there something wrong with my process? Regards, Joseph D. |
November 22, 2015, 13:31 |
#171 |
Pablo Higuera
Rep Power: 19 |
Hi Joseph,
have you taken a look at the wiki? It's a nice place to start: https://openfoamwiki.net/index.php/Contrib/IHFOAM Each case has an runCase with all the steps needed to run the case, take a look at them. Best, Pablo |
November 22, 2015, 14:56 |
#172 |
Pablo Higuera
Rep Power: 19 |
Dear all,
I have updated IHFOAM to include the solvers and tutorials for the latest release: OpenFOAM 3.0. https://github.com/phicau/IHFOAM Best, Pablo |
November 23, 2015, 00:43 |
ihFoam solver compilation for OpenFoam 3.0 error
#173 |
Joseph D.
Rep Power: 10 |
Hi Pablo,
Thank you very much for your work and time developing ihFoam. I had tried compiling the new solver that you've added for OpenFoam lastest release 3.0. However, it gave an error : Code:
user@user:~/IHFOAM-master/solvers/ihFoamOF300$ ./allMake Making dependency list for source file ihFoam.C could not open file turbulentTransportModel.H for source file ihFoam.C due to No such file or directory could not open file CorrectPhi.H for source file ihFoam.C due to No such file or directory could not open file createTimeControls.H for source file ihFoam.C due to No such file or directory could not open file createRDeltaT.H for source file ihFoam.C due to No such file or directory could not open file readhRef.H for source file ihFoam.C due to No such file or directory could not open file gh.H for source file ihFoam.C due to No such file or directory could not open file createMRF.H for source file ihFoam.C due to No such file or directory SOURCE=ihFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam240/src/transportModels/twoPhaseMixture/lnInclude -I/opt/openfoam240/src/transportModels -I/opt/openfoam240/src/transportModels/incompressible/lnInclude -I/opt/openfoam240/src/transportModels/interfaceProperties/lnInclude -I/opt/openfoam240/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/openfoam240/src/TurbulenceModels/incompressible/lnInclude -I/opt/openfoam240/src/transportModels/immiscibleIncompressibleTwoPhaseMixture/lnInclude -I/opt/openfoam240/src/finiteVolume/lnInclude -I/opt/openfoam240/src/fvOptions/lnInclude -I/opt/openfoam240/src/meshTools/lnInclude -I/opt/openfoam240/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam240/src/OpenFOAM/lnInclude -I/opt/openfoam240/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/ihFoam.o ihFoam.C:69:37: fatal error: turbulentTransportModel.H: No such file or directory #include "turbulentTransportModel.H" ^ compilation terminated. make: *** [Make/linuxGccDPOpt/ihFoam.o] Error 1 ihFoam compilation failed |
November 23, 2015, 04:18 |
#174 |
Pablo Higuera
Rep Power: 19 |
Hi Joseph,
please be more careful and double check always, you are trying to compile the version 3.0 solver with version 2.4. Best, Pablo |
November 23, 2015, 04:25 |
#175 |
Joseph D.
Rep Power: 10 |
Hi Pablo,
Thank you very much for your reply. As soon as you posted the update for OF 3.0, i uninstalled my OF 2.4 and replaced it with 3.0. Then I tried the updated solver. I tried to simulate the breakwater tutorial but got the same error that I encountered using OF 2.4. Regards, Joseph D. |
November 24, 2015, 07:02 |
#176 |
Joseph D.
Rep Power: 10 |
Hi Pablo,
Good Day! Thank you very much Pablo for your work. I reinstalled OpenFoam 3.0.0 along with Paraview 4.4. I completed the compilation for boundary conditions and solvers. Afterwards, I tried the tutorial inside OF300 directory, by running: Code:
user@user:~/Downloads/IHFOAM/tutorials/OF300/baseWaveFlume$ ./runCase Regards, Joseph D. Last edited by jdttl; November 24, 2015 at 12:51. Reason: Additional question. |
November 30, 2015, 02:43 |
want your case setup
#177 |
nirbhay tiwary
Rep Power: 11 |
hi Dmitrjs;
i want ur case setup for your above problem....i think i have the same kind of problem.the link u have attached is not working. Last edited by nctiwary; December 15, 2015 at 03:24. |
December 8, 2015, 22:19 |
#178 |
Rep Power: 15 |
Hi, does anyone knows how do we decide on the wavePhase? When is it 3pi/2? I am getting problems with the boundary not being entirely correct.
December 9, 2015, 18:02 |
P_rgh
#179 |
Gizela Zucula
Hello, everyone. I'm new to IHFoam. I wanna know what are the unities for p_rgh? After running IhFoam, when it comes to read the results we have p and p_rgh, what's the difference between them? Is there anyway of calculating hydrostatic forces on a surface through using some tools in paraview or IHfoam solver? Thanks for your attention. Im waiting for any answer. Regards Gizela Zucula
December 15, 2015, 03:22 |
evaluating the wave-induced forces
#180 |
nirbhay tiwary
Rep Power: 11 |
Greatings Pablo,
I am a new user of the IHFOAM 2.0. I am very impressed and pleased with the way the model behaves, I'm exploring it intensively. i am also facing the same problem what u were facing for evaluating the wave-induced forces on a horizontal cylinder.(in "The IHFOAM Thread" post no.30).Can i know how u solve this problem.....can u send me the correct case file setup??? further do u have any case setup for vertical cylinder???....it will be very helpful for my experimental work validation. do u have any idea about how to couple my "fully non-linear potential theory" code which is generating a list of velocity ordinates , with IHFoam??? thanx in advance nirbhay Capture.JPG |
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 7, 2019 23:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 03:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 11:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
