#141 | |
Rep Power: 11 ![]() |
Any solution for the problem you were facing? Your reply will benefit me since I am experiencing simialr behaviour for a StokesV wave that I am interetesd in. This is my obseravtions so far: Attenuation with time could be significantly reduced when using laminar model. Attenuation with location could be significantly reduced when Courant number is reduced. Cheers, Hossein |
#142 |
Gizela
Hi everbody, I´m new to OpenFoam and Ihfoam. I have installed the solver with success and now i´m learning how it works, but i had some problems running the basewaveflume tutorial.
I didn´t change anything at the dict files. But when i received the following error: Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field porosityIndex Porosity NOT activated Reading field p_rgh --> FOAM FATAL IO ERROR: cannot find file file: /home/costas-portos/Zazu-2.4.0_RUN/openfoam240/IHFOAM/ihFoam/tutorials/OF230_240/of230_240/basewaveflume/0/p_rgh at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting costas-portos@ObrasCosteiras:~/Zazu-2.4.0_RUN/openfoam240/IHFOAM/ihFoam/tutorials/OF230_240/of230_240/basewaveflume$ Could someone tell me why i received this error, and how can i solve the problem? Waiting for your reply... Kind regards |
#143 |
Pablo Higuera
Rep Power: 19 ![]() |
Hi Gizela,
it seems that you lack some steps before running the simulation. Please take a look at the runCase file. Best, Pablo |
#144 |
Gizela
Hello Pablo,
Thanks for your quick reply. I did exactly what is written at the runcase file, but it is stilll returning the error. Maybe it´s an installation problem but even if it is, i don´t know how to solve it. ![]() ![]() Any idea? |
#145 |
Pablo Higuera
Hi Gizela,
without further information I can only think that something failed while following all the steps. Check if there is a folder 0 and a p_rgh file inside. The 0 folder should have all the files present in 0.org prior to performing setFields. Best, Pablo |
#146 |
Pietro Danilo Tomaselli
Rep Power: 13 ![]() |
Hi Pablo,
I am looking at the code of IHFOAM. In particular, I am interested in the generation of waves, hence in the way how alpha and U are treated. Following the manual at pag. 28 and the file IH_Waves_InletAlphaFvPatchScalarField.C, this is what I understand: For the case T > M: - if (zSup[cellIndex] <= measuredLevels[cellGroup[cellIndex]-1]) This is zone "c" and alpha = 1 for in flux and zeroGradient for out flux. - else if ( zInf[cellIndex] < measuredLevels[cellGroup[cellIndex]-1]) This is interface "b-c". Again, alpha = 1 for in flux and zeroGradient for out flux. - else alpha = 0 both for in flux and out flux. I think this is zone "a" My question is: where is the calculation of zone "b" and of the interface "a-b"? Could you please help me to find the lines of the code where "The intersection between the theoretical water level and the cell is calculated to obtain the corresponding alpha of the cell" ? Thank you in advance for your help. Cheers, Danilo @ Hossein Sorry for the late reply, I just saw your post. However, I have not found any solution for that problem yet. |
#147 |
Rafael Marques
Rep Power: 12 ![]() |
Hi everybody,
I am simulating a wave breaker and i am interested in obtaining the overtopping but at the moment i only have one way to do it. To sample the alpha field and the velocity x field and then i wrote a script in matlab to make threshold if alpha>=0.5 them multiply alpha and Ux then i make the integrate in the vertical direction to obtain the massflow per meter. The problem is that in have a lot of folder because i am simulating all timestep. i am wondering if there is a better way to do it? Thanks to everybody Rafa Marques |
#148 |
Pablo Higuera
Hi Kobelak,
actually, the reference manual is quite outdated. Recent improvements allow us to work without calculating transition zones a-b and b-c. Some of the old infrastructure remains in IH_Waves_InletAlphaFvPatchScalarField.C, though. Hi Rafa, there are countless other ways, including the integration of a faceSet within a function object. Best regards, Pablo |
#149 |
Rafael Marques
Hi Pablo,
thanks for your quick reply, i will try it, because with the method explaind in the earlier post it is possible but it is also to time consuming. Greets Rafa Marques |
#150 |
nirbhay tiwary
hi guys,
as i m a new user of ihfoam i am able to run any of the test cases provided in the tutorial directory of ihfoam....can any body list the step by step procedure for runny any of the test cases.For ur information my ihfoam installation is fine. thanx in advance. |
#151 |
Pablo Higuera
Hi Nirbhay,
each case has a runCase script that includes all the steps necessary to prepare/run/postprocess it. Best, Pablo |
#152 |
nirbhay tiwary
while running the test case i m getting the following error.....this error happens only for interFoam and ih Foam case....i don't know why......pls guys help me
Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field porosityIndex Porosity NOT activated Reading field p_rgh --> FOAM FATAL IO ERROR: cannot find file file: /home/user/ihfoam_materials/tutorials/OF230_240/irreg45degTank/0/p_rgh at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting |
#153 |
Pablo Higuera
the same question has been answered a couple of posts before. Please use the search tools before asking questions, as some of them can be already answered. Best, Pablo |
#154 |
Rafael Marques
Hi Pablo and Ihfoamers,
In a earlier post i was struggling to obtaining the massflow of the water over a certain section and now i figured it out, so here is the link to what i did to get the massflow. Then i used it for a overtopping sampling. http://www.cfd-online.com/Forums/ope...code-do-2.html at post 25 Greets to everbody Rafa Marques |
#155 |
nirbhay tiwary
hi guys........as i m new to IhFoam......so i need a complete tutorial on generation of 3 D wave tank containing fixed cylinder using stokes 1st order....pls help me guys....i need this very urgently......as i wanted to use openFoam fr validation of my experimental work.
thnx in advance. |
#156 | |
Hi Pablo,
May you please further explain what numerics could be adjusted to more realistically model the waves? I am experiencing damping of waves with time and location. What fvSchemes do you recommend for steep waves? Cheers, Hossein Quote:
#157 |
nirbhay tiwary
hi friends,
I want to generate a velocity profile at the inlet condition of my numerical wave tank generated using OpenFoam/ihFoam by giving the ordinates of velocity.As i m a new user of OpenFoam kindly give your reply in detail. |
#158 |
Dear Pablo
I'm trying to reproduce a 2D wavetank with a floating panel: I'm using OpenFOAM 2.4.0 and ihDyMFoam compiled for this version. I've set up the dynamic mesh dictionary on the same way of the floating object tutorial, with two constraints, a 1x0.4 m2 box and the same mesh of the original tutorial. ![]() ![]() ![]() ![]() BTW, if I try to run a simulation with a 0.4 m thick box, it runs pretty straightforward without particular issues, if I try instead with a thinner plate (I need 0.01 m for my purposes, but even with 0.2 m I've troubles), the simulation diverges almost immediately and I obtain senseless values of linear velocity and pressure (see picture below) ![]() I'm desperately trying to understand what it could be the problem, but I dont' know if it's a problem of coarse mesh, or I'm missing something else. Could you please give any suggestion? Any help will be very appreciated Cheers |
#159 |
nirbhay tiwary
Thanks for reply .
I want to couple my fully non-linear potential flow theory code(which will be used for wave generation ) with Open Foam(which will be used for calculating wave forces on my offshore structure).My FNPT code is giving the follwing results x * *y * z * * u * * *v * * *w * * *px * * py * * *pz * * * *ax * * * ay * * * *az * * So how i can couple my FNPT code with that of OpenFoam .One more thing is there any GUI software which uses Fully Non Linear Potential Flow theory .* How can I generate a wave with known velocity profile at inlet using OpenFOAM or IhFOAM? - ResearchGate. Available from: https://www.researchgate.net/post/Ho...FOAM_or_IhFOAM [accessed Oct 1, 2015]. |
#160 |
Rep Power: 15 ![]() |
Hi All, I have a simple clarification I wish to make regarding the wave phase. For waves travelling horizontally I wish to generate Stokes first order waves (sine). I used a wavePhase of pi/2 which gave me the results I need. I'm quite surprised since it is different from the training manual pdf.
Another situation I was required to generate waves vertically pointing to the North (y +ve). Similarly stokes first order (sine) as well. I wasn't able to obtain the results I need until I change the wavePhase to pi. I have no idea if I'm missing something theoretical here. Please advise if you know, thanks. |
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 7, 2019 23:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 03:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 11:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
