[IHFOAM] The IHFOAM Thread
Like Tree58Likes
Old   November 28, 2014, 16:15
Hao Chen
hchen is on a distinguished road
Hi Pablo:
Do you have plans to code volume averaged turbulence models for flow in porous media? If so, what kinds of VA turbulence model would you like to choose?
Best regards
Hao
hchen is offline   Reply With Quote
Old   November 29, 2014, 07:02
Pablo Higuera
Phicau is on a distinguished road
Hi Hao,
the VA turbulence models, k-epsilon and k-omega SST, are already developed and almost ready to be released, I just need a little time for code cosmetics and to port them to all the supported versions.
I am now finishing writing my PhD and don't have as much time as I would want to develop IHFOAM, but I think you can expect them in the following 3 weeks, along with a tutorial case to apply them.
Best,
Pablo
Phicau is offline   Reply With Quote
Old   November 29, 2014, 07:15
Hao Chen
Hi Pablo:
Thanks very much for your work and I am looking forward to the new released version!
Do you have any comments on the applicability range of these two turbulence models based on your practical experience? e.g. under what kind of conditions k-epson gives better results and so on...
Best regards
Hao
Old   November 29, 2014, 07:52
Pablo Higuera
Hi Hao,
you have a thorough comparison here (if you don't have access just let me know by PM): http://www.sciencedirect.com/science...78383912001093
Most of the times the results are very similar, although I think SST stands out when wave breaking or large flow separation occurs.
Best,
Pablo
Old   December 4, 2014, 17:01
Hao Chen
Hi Pablo:
Thanks very much for your info. I have access to it and I am reading it thoroughly.
Could you give some refs on the VA turbulence models that IHFOAM follow?
Best regards
Hao
Originally Posted by Phicau View Post
Hi Hao,
Best,
Pablo
Old   December 5, 2014, 04:07
Pablo Higuera
Hi Hao,
sure, check this reference: http://www.sciencedirect.com/science...78383913001452
As it happens with our VARANS equations, the turbulence equations are not 100% mathematically correct. However, we have only encountered minor differences with the new derivation/implementation.
We are exploring the possibility of publishing the new material. In any case, the new equations will be included in the reference document that you can download when you register in the IHFOAM website.
Best,
Pablo
Old   December 26, 2014, 15:42
Default General question for discussion on mesh resolution
  #87
haze_1986 is on a distinguished road
Hi all, I would just hope to ask for advice on the mesh resolution of VoF in ihFoam. Validating of experimental results seems to give me good results when the total length of the flume are around 20 to 50 metres. I would normally use horizontal mesh spacing of 0.1 metres and 0.05 metres vertically.
However, in the case of real simulations of lets say a harbour that can be 500 metres in the area of interest, what would be the recommended mesh resolutions? I am not sure from which physical quantity should I start with to predict. Would the resolution be dependent on the inlet boundary wave length as well?
haze_1986 is offline   Reply With Quote
Old   December 29, 2014, 04:16
Pablo Higuera
Hi Haze,
yes, you usually need a certain number of cells to accurately define a wave. In general you should go for at least 5 cells per H and 75 cells per L.
Best,
Pablo
Old   December 31, 2014, 14:32
Hi Haze,
Best,
Pablo
Hi Pablo,
Happy New year and thanks for the advise. I would just like to check if there is also a strict requirement that the aspect ratio of each cell be less than 2? What can we do if after applying the above the aspect ratio H:V we obtain is about 10? Any issues with it?
Old   January 5, 2015, 04:28
Pablo Higuera
Hi Haze,
in CFD there are very few strict requirements. In this case it is a recommendation. Having said that, I would never go beyond 5:1 (and this at an unimportant location far from the interest zone, though).
Best,
Pablo
Old   January 18, 2015, 03:34
Hi all, I came across a problem which I am not able to solve. I am trying to test a diffraction of waves case which is fully 3D. I sampled the surface elevation at the inlet and the trend is different from the Stokes wave I generated in IHFoam. Does anyone knows why and if there is anything I can do to improve the solution?
Old   February 2, 2015, 14:42
Default checkMesh issue
  #92
Rafael Marques
rafa13 is on a distinguished road
Hi Pablo,
First, I want to thank you for your great tool box e that you are "putting" it in open-source!!
I have a issue with IHFoam when i try to import a mesh ,created in Gmsh, so i try to explain it a little bit more...
I can import using gmshToFoam and I don get error...but when I execute the checkMesh I get this error message:
Create time
--> FOAM FATAL ERROR:
No times selected
From function checkMesh
in file db/Time/timeSelector.C at line 263.
FOAM exiting
I run the case without the blockMesh command in the runCase file and it runs, but i don't know why i have this checkMesh issue...
...can you help me with this problem? by the way I use OpenFoam 2.2.2
Thanks a lot,
Rafael Marques
rafa13 is offline   Reply With Quote
Old   February 2, 2015, 14:56
Pablo Higuera
Hi Rafael,
you give little information, there a lots of things that can go wrong. For example: are you running the command in the base folder of a case? Do you have a folder named '0' (even empty)? Do you have any folders with an space in their name inside the case folder (I think that would yield another kind of error, though)?...
Best,
Pablo
rafa13 likes this.
Old   February 2, 2015, 20:13
Rafael Marques
Hi Pablo,
thanks for your time and for the quick answer.
Ok I try to explain the steps that I do:
first I copied the basewaveflume tutorial and rename it. After that I copy my Mesh file in to the case folder, then I delete the PolyMesh folder in the constant folder after that I run the command gmshToFoam in the command window and this comand are able to create the Polymesh folder thats not the problem, and then I change the boundary file ( changing the frontAndback patch to empty) and at the end i run the checkMesh in the command window again. Thats the moment when I get this error message, but I delete the blockMesh command in the ControlDict and I am able to run the case with the ./runCase file.
So I get results, but I like to checkMesh...but never mind the important thing are the results so they are Ok so everything is fine.
I decided to check the mesh in a OpenFoam case and it works without problems-
thank you again
Rafael
Old   February 3, 2015, 13:25
Pablo Higuera
Hi Rafael,
then I was right, you need to create a folder named '0' for checkMesh to work. Note that there is only a folder named '0.org' that eventually gets renamed to '0' in the runCase script.
Best,
Pablo
rafa13 likes this.
Old   February 3, 2015, 17:56
Rafael Marques
Hi Pablo
Thanks a lot it works, i am a noob using OpenFoam sorry about this noob issue.
greetings
Rafael
Old   February 7, 2015, 11:10
Default varios gauges line distribuition
  #97
Rafael Marques
Hi Pablo,
I am struggling with the distribution of the gauges, for the free surface elevation. I am trying to make a equal spaced distribution of 200 gauges, a little bit like the waveflume tutorial in waves2foam. But i am not able to do it, so I decide to ask you about it.
I am able to monitorize the surface elevation at various positions, like the breakwater tutorial, but now I want to monitorize at 200 positions and introducing every position by hand is at the moment my only way.
Greetings,
Rafael
Old   February 9, 2015, 06:56
Pablo Higuera
Hi Rafael,
you can create your own script to generate a text block that includes all the points you need to sample, so that you can include it in sampleDict.
After that the script (postSensVOF.py) provided as part of the reference materials will do the rest.
Best,
Pablo
Old   February 10, 2015, 07:18
Rafael Marques
Hi Pablo,
thanks for your answer, I tried it but without success at the moment, but I continuo to try. Thats the nice thing about OpenFoam try and try till it works .
Best greetings,
Rafael
Old   February 21, 2015, 05:48
Hao Chen
Hi Pablo:
In your tutorial for boundary conditions of p_rgh for solid walls, you use buoyant pressure rather than zero gradient, could you explain the reason?
Best regards
Hao
Divergence detected in AMG solver: k when udf loaded google9002 Fluent UDF and Scheme Programming 3 November 8, 2019 00:34
udf problem jane Fluent UDF and Scheme Programming 37 February 20, 2018 05:17
UDF velocity profile willroca Fluent UDF and Scheme Programming 2 January 10, 2016 04:13
Error messages atg enGrid 7 August 30, 2013 12:16
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
