[IHFOAM] The IHFOAM Thread
Like Tree58Likes
Old   March 7, 2023, 15:49
Default Compressible fluid solver
  #381
Tommaso
evxta3 is on a distinguished road
Hi IHFOAM team,
Is there any compressible solver (e.g. compressibleinterfoam) already implemented in IHFOAM?
Thanks,
Tommaso
evxta3 is offline   Reply With Quote
Old   March 8, 2023, 04:02
IHFOAM Team's Avatar
IHFOAM The Environmental Hydraulics Institute "IHCantabria"
IHFOAM Team is on a distinguished road
Hi Tommaso,
Yes, you can use the waves library in a compressible solver (compressibleInterFoam).
And yes, we have our own version of a porous medium solver for compressible cases. Please, check this presentation:
https://www.researchgate.net/publication/361998233_Novel_Methodology_for_a_Fast_3D_Numerica l_Analysis_of_The_PTO_Damping_Force_on_a_Dual-Chamber_OWC
Best,
IHFOAM Team
evxta3 likes this.
http://ihfoam.ihcantabria.com/
IHFOAM Team is offline   Reply With Quote
Old   March 8, 2023, 04:08
Hi AlxB,
Where could these come from ?
I recommend you to first run the cnoidal case (laminar) provided in the tutorials and check if if works correctly; if so, there is something wrong with the numerical setup of your turbulence model.
Please, check carefully that the initial seeding of the turbulence is correct:
https://www.cfd-online.com/Wiki/Turbulence_free-stream_boundary_conditions
Best,
IHFOAM Team
Old   March 15, 2023, 07:39
Default compressibleInterFoam
  #384
Tommaso
I modified the wave/solitary tutorial using the solver compressibleInterFoam, however it gives the following error:
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Constructing twoPhaseMixtureThermo
Selecting surfaceTensionModel constant
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectFluid;
specie specie;
energy sensibleInternalEnergy;
type heRhoThermo;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in /lib64/libpthread.so.0
#3 Foam::heThermo<Foam::rhoThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > >::he(Foam::Field<double> const&, Foam::Field<double> const&, int) const at ??:?
#4 Foam::heThermo<Foam::rhoThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > >::init(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&) at ??:?
#5 Foam::heThermo<Foam::rhoThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:?
#6 Foam::rhoThermo::addfvMeshConstructorToTable<Foam: :heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#7 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMe sh const&, Foam::word const&) at ??:?
#8 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
#9 Foam::twoPhaseMixtureThermo::twoPhaseMixtureThermo (Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#10 ? at ??:?
#11 __libc_start_main in /lib64/libc.so.6
#12 ? at ??:?
Any ideas where this comes from? Thanks!
Old   March 30, 2023, 07:28
Hi Tommaso
I am afraid we cannot understand or fix the error with just the log file.
Sorry,
IHFOAM Team
p.s: Just curious, does your surname start with an A?
Old   March 30, 2023, 07:52
Tommaso
Hi IHFOAM Team,
Thanks for your reply. We menaged to fix the error and to run IHFOAM with a compressible solver.
Yes, it does start with an A .
Thanks,
Tommaso
Old   March 30, 2023, 08:13
Great, well done !!!
( Good luck with the air pockets )
IHFOAM Team
evxta3 likes this.
Old   September 4, 2023, 10:58
Lucia Ligorio
lucia_995 is on a distinguished road
Hi, I have problem to generate irregular waves with one direction. Can you help me?
Thanks
lucia_995 is offline   Reply With Quote
Old   September 4, 2023, 12:12
Hola Lucia,
Thanks
After the summer nothing works as it should do, but we keep on foaming . Can you give us more info about your problem?
Best,
IHFOAM Team
Old   September 4, 2023, 12:38
Lucia Ligorio
I try to reproduce a channel with a slope and a rubble mound breakwater, regular and irregular waves conditions.
With regular waves I haven't problems but with irregular waves I don't understand gow to setup the wavePropeerties file.
I see the case irregularMultiDirectional in interFoam and I notice that there are a "series" of periods, heights, etc
I don't understand how to derive this series and I want know if there is a way to setup only Tp and Hs like in waves2Foam.
Thank you very much!
Old   September 4, 2023, 12:39
Lucia Ligorio
Hola Lucia,
Best,
IHFOAM Team
Old   September 5, 2023, 08:46
Hi there again,
You can find the answer in the great book "Wavess in oceanic and coastal waters" " by Leo H. Holthuijsen (I believe is in page 44 a clear explanation).
Best,
IHFOAM TEAM
p.d: Sorry, you can not just define Tp or Hs in our model, we believe that following our choice is much better to generate "fast & correct" irregular cases.
Old   September 8, 2023, 19:10
Default Irregular waves model
  #393
Benjamin Norris
bknorris is on a distinguished road
Hi Lucia,
IHFOAM does contain a tutorial case for irregular waves if you haven't found it already,
<OpenFOAM directory>/tutorials/multiphase/interFoam/laminar/waves/irregularMultiDirection
Note this is for multi-directional irregular waves and so to make the waves constant from one direction you would just set 'waveDirs' equal to 0 for each period, height, and phase.
To estimate wave period, height, and phase, well it depends on what data you're working with. For example, when I was using the irregular wave model, I computed the fft of a sea surface pressure time series recorded by an instrument, and used the complex spectrum to calculate wave height (= 2*amplitude), period (1/frequency), and wave phase for each frequency component. If you lack instrument data, you could simply use a program (e.g., https://www.mathworks.com/matlabcent...2-wavemodeling) to generate a spectrum and then calculate these components yourself.
Hope that helps,
Ben
bknorris is offline   Reply With Quote
Divergence detected in AMG solver: k when udf loaded google9002 Fluent UDF and Scheme Programming 3 November 8, 2019 00:34
udf problem jane Fluent UDF and Scheme Programming 37 February 20, 2018 05:17
UDF velocity profile willroca Fluent UDF and Scheme Programming 2 January 10, 2016 04:13
Error messages atg enGrid 7 August 30, 2013 12:16
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
