May 5, 2021, 12:37 |
#361 | |
Benjamin Norris
Rep Power: 5 |
I'm glad you were able to get the 2D irregular wave model to work. I still haven't worked out why the model was producing longer maximum wave periods than is specified in waveProperties. Ultimately, my workaround was to supply the model with a smaller number of input frequencies between [0.03 - 0.33] Hz, and use a rampTime that was about two times the max period (64 s). I then ran the model so two complete wave cycles occurred (another 64 s). My experimentation indicated that running the model for more than 128 s total did not produce significantly different results. Best, Ben |
August 15, 2021, 21:11 |
#362 | |
Valerio
August 19, 2021, 08:28 |
IHFoam installation suggestions
#363 |
Scott Hicks
Rep Power: 5 |
I'm new to IHFoam and working through getting it installed. Does anybody have suggestions for tutorials for successful installation? I'm hacking my way through it but haven't found a definitive approach. Also, is IHFoam compatible with the latest versions of OpenFOAM? If not, what it is the latest version of OpenFOAM that I should have up and running first? Thanks! Scott |
August 20, 2021, 13:47 |
IHFOAM/OpenFOAM installation
#364 |
Benjamin Norris
Rep Power: 5 |
Hi Scott,
IHFOAM comes packaged with all modern versions of OpenFOAM, so no additional installation is necessary to use the toolbox. To me, this ease-of-use is one of the key advantages over other wave generators (e.g., waves2Foam, olaFlow). If you installed OpenFOAM in /opt/, tutorials for IHFOAM can be found in the "tutorials" folder. For me, with OpenFOAM v-1912 installed, the path is /opt/OpenFOAM/OpenFOAM-v1912/tutorials/multiphase/interFoam/laminar/waves IHFOAM also has some tutorials on their website, https://ihfoam.ihcantabria.com/source-code/tutorials/ In my experience, these tutorials are enough to get you started for a range of different use cases. However, they do not cover more advanced issues like obtaining model convergence, turbulence modeling, advanced sampling, and so on. To learn these other topics, I had to read forums, reports, and theses. Model development takes time, so my advice is be patient and willing to try (and fail) a lot before finding a solution that works. Best, Ben |
August 24, 2021, 09:32 |
#365 |
Scott Hicks
Rep Power: 5 |
Thanks Ben. This was helpful.
Now I'm trying to work through the tutorial cases. It seems the waves/laminar tutorial cases all have a "0.orig" folder rather than the "0" folder that the other OpenFoam tutorials seem to have. Is this because of the solver that we use for IHFoam? If I try to run with interFoam, I get an error that it can not find the p_rgh file (because p_rgh is really in the '0.orig' folder and the interFoam solver is looking in '0' folder. I've tried running the solvers ihFoam and ihDyMFoam but both provide the following error in that it can't find the associated files for those solvers. Am I missing something with the installation? ~/OpenFOAM/OpenFOAM-v1906/tutorials/multiphase/interFoam/laminar/waves/solitary$ ihFoam Traceback (most recent call last): File "/usr/lib/command-not-found", line 28, in <module> from CommandNotFound import CommandNotFound File "/usr/lib/python3/dist-packages/CommandNotFound/CommandNotFound.py", line 19, in <module> from CommandNotFound.db.db import SqliteDatabase File "/usr/lib/python3/dist-packages/CommandNotFound/db/db.py", line 5, in <module> import apt_pkg ImportError: /home/shicks33/OpenFOAM/ThirdParty-v1906/platforms/linux64/gcc-6.3.0/lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /lib/x86_64-linux-gnu/libapt-pkg.so.6.0) ~/OpenFOAM/OpenFOAM-v1906/tutorials/multiphase/interFoam/laminar/waves/solitary$ ihDyMFoam Traceback (most recent call last): File "/usr/lib/command-not-found", line 28, in <module> from CommandNotFound import CommandNotFound File "/usr/lib/python3/dist-packages/CommandNotFound/CommandNotFound.py", line 19, in <module> from CommandNotFound.db.db import SqliteDatabase File "/usr/lib/python3/dist-packages/CommandNotFound/db/db.py", line 5, in <module> import apt_pkg ImportError: /home/shicks33/OpenFOAM/ThirdParty-v1906/platforms/linux64/gcc-6.3.0/lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /lib/x86_64-linux-gnu/libapt-pkg.so.6.0) EDIT: I've also added the error that results from using the interFoam solver since as reading through the forum that it appears to be the correct one to use for the wave tutorials. To me, it looks like the solver is trying to find the "p_rgh" file in a "0" folder. However, those tutorials all include a "0.orig" folder instead of a "0" folder. Is this a problem with the install or the solver that I'm using? --> FOAM FATAL ERROR: cannot find file "/home/shicks33/OpenFOAM/OpenFOAM-v1906/tutorials/multiphase/interFoam/laminar/waves/solitary/0/p_rgh" From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 548. FOAM exiting Thanks for any help you can give! Last edited by shicks99; August 25, 2021 at 13:59. Reason: Updated information |
October 11, 2021, 11:16 |
#366 |
IHFOAM The Environmental Hydraulics Institute "IHCantabria"
Rep Power: 9 |
Hi Scott,
Can you check if you have compiled correctly the ThirParty folder and OpenFOAM folder? Please check: https://develop.openfoam.com/Develop...r/doc/Build.md Once you have done it, test any given tutorial case. For example: foamTestTutorial -full incompressible/simpleFoam/pitzDaily It looks to me that you are missing something. Best, IHFOAM Team
http://ihfoam.ihcantabria.com/ |
November 10, 2021, 13:55 |
Stream Function
#367 |
Kayhan
Rep Power: 12 |
I'm trying to run current with waves around DTC hull via stream function. However, the wave height increases immensely at the inlet. I am using the boundary conditions mentioned in the tutorials of IHFOAM but I am not sure what's wrong with the simuation. I am using Fenton's exe program to compute the Ej and Bj coefficients. Can you help me with this problem. Thanks. |
November 17, 2021, 11:32 |
#368 | |
Rep Power: 9 |
Hi ulgenk,
Please, send me a direct message if you might be interested in a potential collaboration. Best, IHFOAM Team
January 5, 2022, 16:01 |
High velocities in air phase above waves
#369 |
Benjamin Norris
Rep Power: 5 |
Hi IHFOAM team,
I have a curiosity about interFoam/IHFOAM that I have not been able to solve myself, and I wonder if you have any insight into this issue. I am currently simulating low frequency waves over a field of hemispheres representing bed roughness. The models are running fine, albeit a bit slowly. The model residuals look fine to me. I've noticed that there are very large air-side velocities in my models (please see attached images--this is a single timestep for both the alpha.water and Umag screen shots). I've gathered from other forum posts that this behavior could be intrinsic to VOF solvers and can be mitigated by adjusting the UEqn.C file in interFoam. I have attempted this solution, but it produced weird results, and so I abandoned it. The attached results were generated with a "standard" (unmodified) version of interFoam. For what it's worth, the water phase velocities look fine to me, and I discard the results above the free surface anyway. But, I would like to optimize my models to run a little faster if possible I have also included my boundary conditions, in case they are useful. Thank you in advance for any and all insight. Ben Last edited by bknorris; January 5, 2022 at 16:09. Reason: Minor edits for clarity. |
January 6, 2022, 16:59 |
Limit air velocities
#370 |
Christopher Goody
Rep Power: 8 |
Hi Ben,
Have you tried experimenting with using a limiter in fvOptions? I think limitU or limitVelocity routine might help to keep the air velocity from growing beyond realistic levels. From what I've read, one needs to be careful not to limit too much b/c you might be dumping too much energy from the system and end up with nice but maybe unrealistic results. Try check out the source code and google examples... Hope this helps. mahalo chris HTML Code:
https://develop.openfoam.com/Development/openfoam/-/tree/master/src/fvOptions/corrections/limitVelocity |
January 13, 2022, 19:50 |
Update on limiting high air-side velocities
#371 | |
Benjamin Norris
Rep Power: 5 |
Thank you for that recommendation! I have run an efficiency test with my models and wanted to share the results in case anyone else is running into this same issue. First off, I think it is important to note that this solution really only works so long as the air-phase velocities are much larger than the water-phase velocities. Applying a velocity limiter across the entire model domain will, of course, limit velocities in both phases, so it is critical to pick a threshold that is above the magnitude of velocities that you care about. In my cases, the air-phase velocities are in the range of 0.20 - 0.75 m/s, and the water-phase velocities are < 0.1 m/s. I constructed two test cases from one of my models, one with limitU and one without. These models were set to run for a short interval (5 s of simulation time). I set the max velocity threshold in the model with limitU to 0.3 m/s, which is conservatively larger than the water-phase velocities in my model. After running both cases, I found that the limitU model runs about 40% faster than the model without the limiter! Considering that a single, full model run takes around 70 hours to complete, this is a massive increase in efficiency. I took the results from the test cases and computed depth profiles of Umag and epsilon in the water phase. As you can see (attached), there are very minor differences between the model with limitU and the one without. I expect this difference would be larger if I used a smaller max velocity threshold, or if the water-phase velocities were closer in magnitude to the air-phase velocities. In other words, it is worthwhile to run a couple test-cases before applying the velocity limiter broad-scale, to ensure you have set the max velocity threshold appropriately. Happy FOAM-ing. Ben |
January 14, 2022, 03:10 |
Issue of the solitary wave tutorials.
#372 |
Peiwei
Hi IH team members,
I have been learning IHFOAM on OpenFOAM 1812 and 2012. A strange issue I found is that the solitary wave tutorials (solitary/solitaryGrimshaw/solitaryMcCowan) can not be compiled. The simulations always end like this: ************************* Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 deltaT = 0.011 Time = 0.011 PIMPLE: iteration 1 Selecting waveModel Boussinesq -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- [1] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? [1] #1 Foam::sigSegv::sigHandler(int) at ??:? [1] #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 [1] #3 Foam::waveModels::solitaryWaveModel::solitaryWaveM odel(Foam::dictionary const&, Foam::fvMesh const&, Foam:olyPatch const&, bool) at ??:? [1] #4 Foam::waveModels::Boussinesq::Boussinesq(Foam::dic tionary const&, Foam::fvMesh const&, Foam:olyPatch const&, bool) at ??:? [1] #5 Foam::waveModel::addpatchConstructorToTable<Foam:: waveModels::Boussinesq>::New(Foam::dictionary const&, Foam::fvMesh const&, Foam:olyPatch const&) at ??:? [1] #6 Foam::waveModel::New(Foam::word const&, Foam::fvMesh const&, Foam:olyPatch const&)-------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[60199,1],0] Exit code: 144 -------------------------------------------------------------------------- [DESKTOP-E69PS59:05727] 1 more process has sent help message help-btl-vader.txt / cma-permission-denied [DESKTOP-E69PS59:05727] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages ************************** I have tried a lot to work it out, including re-install ubuntu, openfoam but none of them could solve the issue. Could you kindly tell me that what could be the problem? BTW all the other tutorial cases can be compiled well. Thanks in advance. Peiwei |
June 29, 2022, 05:40 |
#373 | |
Haoran Zhou
Rep Power: 6 |
Hi Rafa, Currently I have a problem with wave overtopping over the breakwater. However, the post 25 in the link has gone. Could you please share the post 25 again? Best Stan |
September 6, 2022, 02:10 |
IHFoam nPaddle
#374 |
Rep Power: 5 |
what is the physical meaning of nPaddle in the waveProperties dictionary ? Is a 3D simulation with nPaddle=1 correct ? thanks Last edited by AlxB; September 7, 2022 at 06:06. |
September 12, 2022, 03:26 |
#375 | |
Rep Power: 9 |
Yes, if you re not generating directional waves, decrease the number of wave paddle to speed-up the simulations. Best, IHFOAM Team
October 10, 2022, 13:29 |
Time series as input
#376 |
Benjamin Norris
Rep Power: 5 |
Hi IHFOAM team,
I am working on a new project with IHFOAM, where I will be recreating some laboratory test cases from a wave flume inside OpenFOAM. I am being provided a water level time series from downstream of the wave maker, and so I am wondering if IHFOAM can use a water level time series as the upstream boundary condition? I am familiar with the irregular wave model in IHFOAM, in that I have used it in the past by discretizing a pressure time series into a spectrum (with components of wave height, period, direction, and phase). I could do this with the flume data, but I am wondering if this approach isn't as precise for simulating monochromatic waves in OpenFOAM? Thank you for any and all insight. Ben |
October 13, 2022, 17:43 |
Re: Time series as input
#377 | |
Christopher Goody
Rep Power: 8 |
Chris |
October 28, 2022, 15:36 |
#378 | |
Benjamin Norris
Rep Power: 5 |
I am currently using IHFOAM in OF-v2206. To be more specific about my problem, I am working with a colleague who will be simulating the same case in XBEACH Non-Hydrostatic (XBNH). XBNH takes a water level and velocity time series as input, so ideally I would do the same with my OpenFOAM model so we can directly compare results. At the moment, I am forcing my model using a monochromatic wave that is similar--but not the same--as the wave tank data my colleague is using for their inlet BC. Thanks for the tip about olaFlow, though I think ideally I would find a solution that allows me to modify my current IHFOAM case without needing to redevelop the case with a different set of solvers. I will investigate this further and will consider other options if I get stuck. Best, Ben Last edited by bknorris; October 28, 2022 at 18:14. Reason: edited for formatting; clarity |
January 23, 2023, 08:57 |
wave run-up
#379 |
Rep Power: 6 |
Hiii,
do you guys have any idea on calculating the wave run-up on a structure? Does this approach work ? functions { freeSurface { type surfaces; functionObjectLibs ( "libsampling.so" ); writeControl outputTime; writeInterval 1; surfaceFormat stl; interpolationScheme cellPoint; surfaces ( topFreeSurface { type isoSurface; isoField alpha.water; isoValue 0.9; interpolate true; } ); fields ( alpha.water ); } } and slicing the corresponding stl file in y direction (in paraview) and saving it?? |
March 2, 2023, 15:45 |
cnoidal wave height
#380 |
Rep Power: 5 |
I am running a turbulent k-omega 2D simulation based on the cnoidal wave tutorial of OF2112. In that wave flume channel, when I set 40mm for the wave height in the waveProperties then I got a wave height five times bigger, so 200mm. Another issue is that the water mean level is progressively going down as the time goes along. Where could these come from ? Best, Last edited by AlxB; March 6, 2023 at 07:24. |
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 7, 2019 23:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 03:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 11:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
