[IHFOAM] The IHFOAM Thread
Like Tree58Likes
Old   October 5, 2020, 13:12
IHFOAM Team's Avatar
IHFOAM The Environmental Hydraulics Institute "IHCantabria"
IHFOAM Team is on a distinguished road
Hi Philip,
if you could brief bit the difference between the version of "IH" and the "IH" included in OF.
In our solver we have just added the new version of the porous solver, waves plus currrents and some new boundary conditions to link with out own in-house codes. We have removed also some parts of the code that for several applications we feel that we do not need it.
Regards,
IHFOAM Team
Panda School likes this.
http://ihfoam.ihcantabria.com/
IHFOAM Team is offline   Reply With Quote
Old   October 6, 2020, 06:15
philip lu
philiplu is on a distinguished road
Hello, IHFOAM Team,
Thank you very much for the reply and explanations.
thanks, regards
philiplu is offline   Reply With Quote
Old   October 8, 2020, 07:04
Isnard Baptiste
Baptiste is on a distinguished road
Hello IHFOAM Team,
I would like to know if its possible to generate 3D waves with a angle from the inlet. And if the answer is yes what parameter in waveDict I have to modify? Or to have quarter face waves I need to rotate my object?
Thank you in advance.
Best regards,
Baptiste
Baptiste is offline   Reply With Quote
Old   October 13, 2020, 05:36
Hi Baptiste,
Yes, always the best choice is to rotate your object, as the wave paddle absorption implemented can just deal with the perpendicular incoming waves to the patch.
Regards,
IHFOAM Team
Old   October 16, 2020, 02:52
philip lu
Hello, IHFOAM Team,
question rephrased:
in your tutorial "Breaking solitary waves on a mild slope (2D)", the "U" in "outlet" of "0.org" shall be updated to
outlet { type noSlip; }
from
outlet { type waveVelocity; value uniform (0 0 0); }
why or is it correct?
yes, the outlet in this case is on bank top, i.e. is open/air (instead of inside water), so the "type waveVelocity;" of U needs update, but why "noSlip"?
thanks, best
Old   November 3, 2020, 05:32
Default IHFoam GUI
  #346
Hattab Abdelhak
Doum2 is on a distinguished road
Hello IHFoam Team,
i need your help to solve a error when i use IHFoam GUI.
When i try to launch blockMesh commande , that show me error saying : BlockMesh not found. but i'm sure i can run blockmesh commande in terminal
any help ?!!
Doum2 is offline   Reply With Quote
Old   November 5, 2020, 07:22
Hi There,
... BlockMesh not found. but i'm sure i can run blockmesh commande in terminal
When using IHFOAM-GUI you must select which version you are using by clicking in:
Edit --> Preferences
and setting the correct OpenFOAM folder.
Best Regards,
IHFOAM Team
Old   November 5, 2020, 15:38
Default help
  #348
Hattab Abdelhak
Originally Posted by IHFOAM Team View Post
Hi There,
Best Regards,
IHFOAM Team
I'm sorry once again for my questions but this time I have a new error which appears after I run the set patches names command as you can see on the screenshots
I have checked the project folder and the blockMeshDict file exists with the settings I entered on IHFoam GUI.
any Idea?
Old   November 6, 2020, 16:50
Default irregularMultiDirectional
  #349
Benjamin Norris
bknorris is on a distinguished road
Hi IHFoam Team,
I have a brief question about the waveProperties file in the irregularMultiDirection tutorial. In this file, there are four blocks of input data that correspond to the required inputs in irregularMultiDirectionalWaveModel.C: wave period, height, phase, and direction.
For example, the waveHeights entry starts with...
waveHeights
57
(0.0022817 0.0021584 0.0019314 0.0016349 0.0013091 0.00099161 0.00071052 0.0004816 0.00030879 0.00018729 0.00010746 5.8323e-05 2.9944e-05 2.9944e-05 5.8323e-05 0.00010746 0.00018729 0.00030879 0.0004816 0.00071052 0.00099161 0.0013091 0.0016349 0.0019314 0.0021584 0.0022817)
etc.
My question is, why are these entries 57x26 and not 57x1? I gather the 57 refers to the number of wave components (analogous to frequencies in the spectrum from which they are derived), but what is the other dimension? Is it time?
Thank you in advance for any and all insight!
Ben
Last edited by bknorris; November 18, 2020 at 14:39. Reason: Solved my other issue
bknorris is offline   Reply With Quote
Old   November 24, 2020, 09:55
Default generate current only
  #350
Fonzzao
Panda School is on a distinguished road
Hello IHFOAM Team,
I would like to know if it is possible to generate current only? I do not want waves but wave absorption boundaries are needed to absorb waves induced by structures in current.
Best regards,
Fonzzao
Panda School is offline   Reply With Quote
Old   December 1, 2020, 07:59
Hi Ben,
To describe the three-dimensional, moving waves, we use the random-phase/amplitude model (in x, y and t-space) by considering the sum of a large number of propagating harmonic waves in x,y-space, in direction θ relative to the positive x-axis.
All the variables used for the OpenFOAM implementation of the three-dimensional definition of the free surface are defined as matrix X i, j, with “i” rows for the frequencies and “j” columns for the directions.
Based on the directional wave spectrum and the definitions given above (sum of harmonic waves), it is necessary to define:
  • Hrms i,j: Root mean square wave height (m): Hrms i,j = 2 * a i,j
  • T i,j: Wave period (s)
  • θ i,j: Wave Direction (º)
  • i,j : Phase (rad)
We hope we have clarified you how to define the input data.
Regards,
IHFOAM Team
Old   December 1, 2020, 08:03
Hi Fonzzao,
Yes, it is possible, but we have not released yet:
Wave-*‐current generation with OpenFOAM. Application to coastal and offshore structures
Please, contact us here if you want to discuss a potential collaboration:
ihfoam@ihcantabria.com
Best Regards,
IHFOAM Team.
Old   December 1, 2020, 08:08
Hi Hattab
any Idea?
Please, post it in the correct thread (here) to help you.
Best Regards,
IHFOAM Team.
Old   December 2, 2020, 15:41
Default Hot-starting a wave model
  #354
Benjamin Norris
Hi IHFoam Team,
Yes you did, thank you very much!
I have another basic question for you if I may. If I first run my wave model with a large rampTime to initialize conditions (where rampTime > the longest wave period), I'd then like to run a subsequent model from the latestTime of the first to simulate conditions. My question is, do I need to set rampTime = 0 before running the second model?
Thank you again for your help.
Ben
Old   December 3, 2020, 07:19
Hi Ben,
If it is a restart, you do not need a ramp time.
The rampTime filter was created to be able to replicate what happens in laboratory, where first waves are normally filtered.
Best Regards,
IHFOAM Team
bknorris likes this.
Old   December 3, 2020, 09:49
Question numerical diffusion error
  #356
Grivalszki Péter
GrivalszkiP is on a distinguished road
Hi!
I'm trying to simulate our wave flume with flap wavemaker. In my simulations, waves smearing quite quick. How can I decrease this numerical diffusion error?
Main parameters:
- flap wavemaker:
motionType flap;
x0 (0 0 0);
n (1 0 0);
waveHeight 0.05;
initialDepth 0.15;
wavePeriod 0.55;
rampTime 2.0;
wavePhase 0;
- k-Omega SST turbulence model
- 5 mm gridsize around water surface (flume is 0,5 m wide)
- MULES, (isoAdvector makes weird errors...) with
nAlphaCorr 2;
nAlphaSubCycles 3;
cAlpha 2;
Thank you:
Peter
GrivalszkiP is offline   Reply With Quote
Old   December 9, 2020, 10:19
Hi Peter
A first idea would be to deal with the over-prediction of the turbulence kinetic energy. Please, take a look to the "New multiphase turbulence stabilization" (link), based on the works B.Devolder and B.E.Larsen & D.R.Fuhrman.
Best Regards,
IHFOAM Team
GrivalszkiP and bknorris like this.
Old   January 20, 2021, 16:46
Benjamin Norris
Hi IHFOAM team,
I have another question regarding the Irregular Wave Model if I may.
I have set up an irregular wave model with 156 wave components that were discretized from a spectrum of water surface elevations recorded by a pressure gauge. The input spectrum initially consists of 320 components, but I limit the output to 156 components by filtering out very long-period waves (f < 0.0156 Hz) and very short-period waves (f > 0.5 Hz). [Please refer to attached figure]. Accordingly, the waveProperties input for the model has periods ranging from 64 s to 2 s, with corresponding heights, and phases. I've set the directions = 0 because the model is quasi-2D in the y-dimension, and waves propagate along the x-z dimension.
I first run a "hot start" model using a rampTime = 128 (2*largest wave period), save the last output of the model ('reconstructPar -time 128'), and then run another model from this time until 512 s has elapsed. I've included a plot of the modeled water surface elevations at the model inlet and at the point in the domain that I'm interested in sampling ('Location of Observations'). It looks to me like the largest waves occur around 60 s and 400 s (orange line), so the max period is 320 s and not 64 s.
Do you have any insight as to what might be causing this behavior?
Thank you in advance, and again for fielding my other questions!
Best,
Ben
File Type: png HR_V4_irregularWaveModelInputSpectrum.png (18.8 KB, 30 views)
Old   April 2, 2021, 05:58
Default 2D irregular wave motion in waveProperties?
  #359
Victor Baconnet
victor13165 is on a distinguished road
Hi Ben,
  • i,j : Phase (rad)
Regards,
IHFOAM Team
Hello IHFOAM Team,
Thank you for your work and this fantastic irregular wave model.
I understand that the input data has to be in the form of matrices with i lines and j columns, to generate 3D irregular waves.
Is it possible to "mimic" 2D irregular waves (only in the x direction) by giving the input data as column matrices with 1 column and i lines? In this case, the waveDirs vector would be only zeros.
As an example, this is what such a file would look like, with i=50 (i deleted the majority of the lines to make it shorter, but you get the idea):
|  \\    /   O peration     | Version:  v2006                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      waveProperties;
INLET
    alpha            alpha.water;
    waveModel        irregularMultiDirectional;
    nPaddle          1;
    rampTime         18.0;
    activeAbsorption yes;
    wavePeriods
    50
(0.9910438094089652)
(2.299969595420805)
    waveHeights
    50
(0.0038454296589595753)
(0.0025547066897806297)
    wavePhases
    50
(4.419270036678733)
(2.246040856529946)
    waveDirs
    50
(0.0)
(0.0)
What do you think? Should I still give input data as matrices but make all the columns the same, while setting waveDirs as 0?
I hope that my enquiry is clear enough. I'm happy to give more details if needed.
Cheers,
Victor
EDIT: My question is pretty much similar to Benjamin's question above, sorry for that. After some testing, it looks like the simulation is running with 1-column matrices as inputs, and waveDirs(i,j) = 0 (also thanks to Benjamin's attached waveProperties file), but I am running into the same issue of maximum period being too large compared to the desired maximum period.
Last edited by victor13165; April 9, 2021 at 05:36. Reason: Similar question posted above : clarifications
victor13165 is offline   Reply With Quote
Old   April 20, 2021, 10:10
Default mangroveInteraction
  #360
Dylan James
dylan_OF is on a distinguished road
hi,IHFOAM Team,
Thank you for your work.
I want to simulate plants and wave interaction.
I can run the case mangroveInterantion on OpenFOAM-v2012 smoothly, But my simulation results can not match the results in the paper.(Maza, M., et al., Tsunami wave interaction with mangrove forests: A 3-D numerical approach, Coast. Eng. (2015), http://dx.doi.org/10.1016/j.coastaleng.2015.01.002)
as shown
G6 point of paper
G6 point of my
I just only modified the number of grids in the grid file, and other files did not change, the code is as follows.
blockMeshDict
|  \\    /   O peration     | Version:  v2012                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
scale   1;
vertices
    ( 0.0 0.0 0.0)
    ( 7.0 0.0 0.0)
    ( 7.0 0.55 0.0)
    ( 0.0 0.55 0.0)
    ( 0.0 0.0 0.5)
    ( 7.0 0.0 0.5)
    ( 7.0 0.55 0.5)
    ( 0.0 0.55 0.5)
blocks
    hex (0 1 2 3 4 5 6 7) (700 14 50) simpleGrading (1 1 1)
edges
boundary
    left
        type patch;
        faces
            (0 4 7 3)
    right
        type patch;
        faces
            (1 5 6 2)
    ground
        type wall;
        faces
            (0 1 2 3)
    top
        type patch;
        faces
            (4 5 6 7)
    sides
        type patch;
        faces
            (0 1 5 4)
            (3 2 6 7)
mergePatchPairs
controDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
scale   1;
vertices
    ( 0.0 0.0 0.0)
    ( 7.0 0.0 0.0)
    ( 7.0 0.55 0.0)
    ( 0.0 0.55 0.0)
    ( 0.0 0.0 0.5)
    ( 7.0 0.0 0.5)
    ( 7.0 0.55 0.5)
    ( 0.0 0.55 0.5)
blocks
edges
boundary
    left
        type patch;
        faces
            (0 4 7 3)
    right
        type patch;
        faces
            (1 5 6 2)
    ground
        type wall;
        faces
            (0 1 2 3)
    top
        type patch;
        faces
            (4 5 6 7)
    sides
        type patch;
        faces
            (0 1 5 4)
            (3 2 6 7)
mergePatchPairs
fvOptions
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvOptions;
Mangroves
    type            multiphaseMangrovesSource;
    active          yes;
    multiphaseMangrovesSourceCoeffs
        regions
            region1
                cellZone        c0;
                a               0.01;
                N               560;
                Cm              1;
                Cd              1.52;
TurbulenciaMangroves
    type            multiphaseMangrovesTurbulenceModel;
    active          yes;
    multiphaseMangrovesTurbulenceModelCoeffs
        regions
            region1
                cellZone        c0;
                a               0.01;
                N               560;
                Ckp             1;
                Cep             3.5;
                Cd              1.52;
The version I used is OF-V2012,
How can I modify this example so that my results match those of the paper?
dylan_OF is offline   Reply With Quote
Divergence detected in AMG solver: k when udf loaded google9002 Fluent UDF and Scheme Programming 3 November 8, 2019 00:34
udf problem jane Fluent UDF and Scheme Programming 37 February 20, 2018 05:17
UDF velocity profile willroca Fluent UDF and Scheme Programming 2 January 10, 2016 04:13
Error messages atg enGrid 7 August 30, 2013 12:16
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
