July 1, 2019, 13:30 |
#281 |
Chiara Viola
Rep Power: 7 |
Hi IHFOAM,
thank you for answer me. Here are available the snapshots of it, since the domain is quite long than the height I also made a detailed snapshot of one critical wave where is possible to see the breaking. Best regards, Chiara |
July 2, 2019, 02:29 |
#282 | |
IHFOAM The Environmental Hydraulics Institute "IHCantabria"
Rep Power: 9 |
I recommend you to take a look to the tutorial number 3: https://ihfoam.ihcantabria.com/source-code/tutorials/ Just by changing the dimensions to your specific case it should work straight forward. Regards, IHFOAM Team
http://ihfoam.ihcantabria.com/ |
July 2, 2019, 06:29 |
#283 | |
Chiara Viola
Rep Power: 7 |
Thank you so much for suggesting me these tutorials, I didn't checked before. Firstly I want try to finish the tutorial with the original dimensions but when I run snappyHexMesh I have one problem that is the same I had in the previous trials when I wanted to use the empty patches in my geometry (this is why I changed then the boundaries but I don't know if I took the good ones because in my mind they describe a good situation). When SHM is at the morphing phase, especially in the scaling iteration step, it stops to work. I mean the SHM is working if I check in the 'top' command but it doesn't go ahead in showing some results... in my previous trial I waited for 3 days without any result and I had to force the killing process I have no idea how to solve this problem, I tried also to follow this steps https://openfoamwiki.net/index.php/M...Examples/2DsHM (and in order to avoid the problem regarding the morphing phase I used a patch instead of empty boundaries) but then when I wanted to run faceSet I got 'command not found'. Here there is the snapshot of my terminal. Regards, Chiara |
July 24, 2019, 06:13 |
#284 | |
Chiara Viola
Rep Power: 7 |
Hi IHFOAM Team, I solved my problem with the geometry but I still have convergence problem in my simulation. When I run the tutorial everything goes well but when I apply my dike my simulation is not able to finish the run. I post here my best result that is having wave generation for all domain and a part of a promenade, then when the water impact to the storm wall my simulation explodes and stop to run. I tried to re run again from the latest time step but it doesn't change and I have floating point exception error but the message doesn't say where. I have tried the StokesV and Solitary wave theory. Here's my last time steps: Code:
Interface Courant Number mean: 7.52871716e-05 max: 0.49483746 deltaT = 0.000303030303 Time = 12.48121 PIMPLE: iteration 1 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834572 Min(alpha.water) = -3.56215196e-18 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834567 Min(alpha.water) = -4.81435309e-15 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834561 Min(alpha.water) = -3.16737612e-18 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet Updating shallowWaterAbsorption wave model for patch outlet DICPCG: Solving for p_rgh, Initial residual = 0.00129628034, Final residual = 8.454475e-05, No Iterations 2 time step continuity errors : sum local = 1.62441265e-06, global = -1.61430925e-10, cumulative = -0.000302494024 DICPCG: Solving for p_rgh, Initial residual = 0.000101904608, Final residual = 9.57877951e-06, No Iterations 5 time step continuity errors : sum local = 1.84077961e-07, global = -1.52568624e-10, cumulative = -0.000302494176 DICPCG: Solving for p_rgh, Initial residual = 2.58305186e-05, Final residual = 9.90149424e-08, No Iterations 40 time step continuity errors : sum local = 1.90277147e-09, global = -1.3610308e-10, cumulative = -0.000302494313 DILUPBiCG: Solving for epsilon, Initial residual = 7.42801644e-05, Final residual = 8.44475079e-09, No Iterations 3 DILUPBiCG: Solving for k, Initial residual = 4.0146251e-05, Final residual = 7.85378951e-09, No Iterations 3 ExecutionTime = 4890.13 s ClockTime = 4898 s forces theForce write: Sum of forces Total : (13.3724271 -2.27757378e-19 -10.0306079) Pressure : (4.50642118 -2.3383332e-19 -10.9364174) Viscous : (8.86600596 6.07594186e-21 0.905809559) Sum of moments Total : (-0.250765197 244.537017 -0.334310679) Pressure : (-0.273410436 261.033131 -0.11266053) Viscous : (0.022645239 -16.4961143 -0.221650149) Courant Number mean: 0.000966970543 max: 0.654489614 Interface Courant Number mean: 7.52755711e-05 max: 0.493488506 deltaT = 0.000303030303 Time = 12.48152 PIMPLE: iteration 1 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834556 Min(alpha.water) = -2.43254777e-12 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834551 Min(alpha.water) = -2.99407269e-12 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -2.77249818e-12 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet Updating shallowWaterAbsorption wave model for patch outlet DICPCG: Solving for p_rgh, Initial residual = 0.999998938, Final residual = 0.0992890547, No Iterations 176 time step continuity errors : sum local = 1793.50201, global = -164.053246, cumulative = -164.053548 DICPCG: Solving for p_rgh, Initial residual = 0.0100297232, Final residual = 0.000976588103, No Iterations 34 time step continuity errors : sum local = 5383.89001, global = 22.1393125, cumulative = -141.914236 DICPCG: Solving for p_rgh, Initial residual = 0.623030872, Final residual = 8.75604326e-08, No Iterations 444 time step continuity errors : sum local = 1.29516877, global = 0.0317167913, cumulative = -141.882519 DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 4.91728767e-08, No Iterations 305 DILUPBiCG: Solving for k, Initial residual = 0.999992114, Final residual = 7.28249599e-08, No Iterations 72 ExecutionTime = 4893.86 s ClockTime = 4902 s forces theForce write: Sum of forces Total : (-5.9421823e+11 1.75389677e-07 -1.82111202e+12) Pressure : (2.9596292e+10 3.46827344e-09 -1.2693774e+11) Viscous : (-6.23814522e+11 1.71921404e-07 -1.69417428e+12) Sum of moments Total : (-4.55278005e+10 4.3443861e+13 1.48554558e+10) Pressure : (-3.1734435e+09 3.04254594e+12 -739907300) Viscous : (-4.2354357e+10 4.0401315e+13 1.55953631e+10) Courant Number mean: 21088154.1 max: 1.9642191e+10 Interface Courant Number mean: 5037.41204 max: 3.06992413e+09 deltaT = 1.00278883e-14 Time = 12.48152 PIMPLE: iteration 1 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -2.53696869e-18 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -2.4194413e-18 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -2.30736125e-18 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet Updating shallowWaterAbsorption wave model for patch outlet DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0896010676, No Iterations 3 time step continuity errors : sum local = 3.710663e-06, global = -1.46078069e-06, cumulative = -141.88252 DICPCG: Solving for p_rgh, Initial residual = 0.0191976271, Final residual = 0.0018107842, No Iterations 74 time step continuity errors : sum local = 3.64633761e-07, global = -3.25543309e-08, cumulative = -141.88252 DICPCG: Solving for p_rgh, Initial residual = 0.00533186821, Final residual = 9.77861893e-08, No Iterations 360 time step continuity errors : sum local = 1.38141453e-11, global = -4.31509092e-13, cumulative = -141.88252 DILUPBiCG: Solving for epsilon, Initial residual = 0.801888953, Final residual = 2.63354537e-09, No Iterations 3 DILUPBiCG: Solving for k, Initial residual = 0.999999981, Final residual = 4.47189636e-08, No Iterations 43 ExecutionTime = 4895.68 s ClockTime = 4904 s forces theForce write: Sum of forces Total : (-7.31340554e+22 0.0797159682 -3.69161797e+20) Pressure : (-7.31340526e+22 0.0796140194 -3.69161615e+20) Viscous : (-2.75274944e+15 0.000101948765 -1.8237216e+14) Sum of moments Total : (-9.22904493e+18 -3.82515413e+22 1.82835138e+21) Pressure : (-9.22904037e+18 -3.82515441e+22 1.82835132e+21) Viscous : (-4.559304e+12 2.7142395e+15 6.8818736e+13) Courant Number mean: 0.000629044872 max: 0.650828439 Interface Courant Number mean: 1.6464218e-07 max: 0.0907623825 deltaT = 1.00151238e-14 Time = 12.48152 PIMPLE: iteration 1 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -2.19710685e-18 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -2.09212415e-18 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -1.99216095e-18 Max(alpha.water) = 1.00002689 Updating Boussinesq wave model for patch inlet Updating shallowWaterAbsorption wave model for patch outlet DICPCG: Solving for p_rgh, Initial residual = 0.817942023, Final residual = 0.0813433379, No Iterations 5 time step continuity errors : sum local = 1.25065719e-05, global = 1.16963171e-05, cumulative = -141.882509 DICPCG: Solving for p_rgh, Initial residual = 5.70953114e-23, Final residual = 5.70953114e-23, No Iterations 0 time step continuity errors : sum local = 0.000117355497, global = 2.11170735e-05, cumulative = -141.882487 DICPCG: Solving for p_rgh, Initial residual = 6.66554354e-23, Final residual = 6.66554354e-23, No Iterations 0 time step continuity errors : sum local = 0.000137005676, global = 3.14480127e-05, cumulative = -141.882456 DILUPBiCG: Solving for epsilon, Initial residual = 0.119912403, Final residual = 2.97545097e-19, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.997356728, Final residual = 3.52026066e-08, No Iterations 4 ExecutionTime = 4896.46 s ClockTime = 4904 s forces theForce write: Sum of forces Total : (9.32326856e+23 0.0920065607 -1.60711805e+26) Pressure : (9.32326781e+23 0.0941689421 -1.60711805e+26) Viscous : (7.47411626e+16 -0.00216238142 -2.4296042e+17) Sum of moments Total : (-4.01779512e+24 3.86779306e+27 -2.33081714e+22) Pressure : (-4.01779511e+24 3.86779306e+27 -2.33081695e+22) Viscous : (-6.0740105e+15 5.89375131e+18 -1.86852906e+15) Courant Number mean: 0.00101005327 max: 0.744973995 Interface Courant Number mean: 2.50833444e-07 max: 0.0927142531 deltaT = 8.73833249e-15 Time = 12.48152 PIMPLE: iteration 1 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -1.91882256e-18 Max(alpha.water) = 1.00050606 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -1.84818658e-18 Max(alpha.water) = 1.00107257 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -1.78015334e-18 Max(alpha.water) = 1.00163869 Updating Boussinesq wave model for patch inlet Updating shallowWaterAbsorption wave model for patch outlet DICPCG: Solving for p_rgh, Initial residual = 0.717370409, Final residual = 0.000186916172, No Iterations 2 time step continuity errors : sum local = 8.94336731e+14, global = -0.0785260696, cumulative = -141.960982 DICPCG: Solving for p_rgh, Initial residual = 0.00316221348, Final residual = 7.17413295e-06, No Iterations 2 time step continuity errors : sum local = 2.79883007e+13, global = -0.0024559532, cumulative = -141.963438 DICPCG: Solving for p_rgh, Initial residual = 2.97251623e-05, Final residual = 3.00371123e-08, No Iterations 5 time step continuity errors : sum local = 2.37052366e+11, global = 0.0635588623, cumulative = -141.899879 DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 2.09460599e-08, No Iterations 28 DILUPBiCG: Solving for k, Initial residual = 0.241911001, Final residual = 1.04959446e-09, No Iterations 10 bounding k, min: -3.05627363e+17 max: 3.29820016e+47 average: 1.22708212e+44 ExecutionTime = 4897.43 s ClockTime = 4905 s forces theForce write: Sum of forces Total : (-7.03043443e+23 0.552046284 -1.03919052e+23) Pressure : (-7.03005298e+23 0.105959373 -1.03899035e+23) Viscous : (-3.81447451e+19 0.44608691 -2.00164777e+19) Sum of moments Total : (-2.5979763e+21 2.07342438e+24 1.75760861e+22) Pressure : (-2.59747589e+21 2.07296483e+24 1.75751324e+22) Viscous : (-5.00411943e+17 4.59551807e+20 9.53618626e+17) Courant Number mean: 2.08521425e+11 max: 3.69068888e+16 Interface Courant Number mean: 107316.023 max: 4.83529043e+11 deltaT = 1.53898535e-31 Time = 12.48152 PIMPLE: iteration 1 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -1.78015334e-18 Max(alpha.water) = 1.00163869 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -1.78015334e-18 Max(alpha.water) = 1.00163869 Updating Boussinesq wave model for patch inlet MULES: Solving for alpha.water MULES: Solving for alpha.water Phase-1 volume fraction = 0.193834545 Min(alpha.water) = -1.78015334e-18 Max(alpha.water) = 1.00163869 Updating Boussinesq wave model for patch inlet Updating shallowWaterAbsorption wave model for patch outlet DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.0842359784, No Iterations 8 time step continuity errors : sum local = 2.37705522e-05, global = 4.14086539e-14, cumulative = -141.899879 DICPCG: Solving for p_rgh, Initial residual = 5.11844107e-33, Final residual = 5.11844107e-33, No Iterations 0 time step continuity errors : sum local = 0.000645155463, global = 4.14087039e-14, cumulative = -141.899879 DICPCG: Solving for p_rgh, Initial residual = 4.94251612e-33, Final residual = 4.94251612e-33, No Iterations 0 time step continuity errors : sum local = 0.000622980949, global = 4.14086442e-14, cumulative = -141.899879 DILUPBiCG: Solving for epsilon, Initial residual = 0.101291878, Final residual = 1.67129654e-17, No Iterations 1 bounding epsilon, min: -9.00014567e+47 max: 1.09716542e+74 average: 7.27482569e+70 DILUPBiCG: Solving for k, Initial residual = 0.999900355, Final residual = 6.97592886e-08, No Iterations 15 bounding k, min: -8.8532324e+34 max: 1.36702156e+61 average: 3.88712176e+57 ExecutionTime = 4898.28 s ClockTime = 4906 s forces theForce write: Sum of forces Total : (1.88604209e+40 2.85303407e+16 1.38770322e+39) Pressure : (1.88604209e+40 2.85303407e+16 1.38770322e+39) Viscous : (-7.49750031e+19 0.0711033385 1.45478639e+20) Sum of moments Total : (3.46925806e+37 -2.19577983e+40 -4.71510522e+38) Pressure : (3.46925806e+37 -2.19577983e+40 -4.71510522e+38) Viscous : (3.63696598e+18 -3.54626942e+21 1.87437508e+18) Code:
blockMesh surfaceFeatureExtract snappyHexMesh -overwrite extrudeMesh autoPatch 10 -overwrite *manually changing of the name and patch type in constant/polyMesh/boundary* copy the 0.orig folder in 0 setFields decomposePar mpirun -np 4 interFoam -parallel Please can you have a look to my case and help my to figure out what is wrong and how can I finish my simulations? I would be very grateful to you if you could do it. Best regards, Chiara in this link you can find all my case https://www.dropbox.com/sh/d9r4tpok9...PRxSrxnpa?dl=0 |
July 24, 2019, 11:48 |
#285 |
Rep Power: 8 |
Hi IHFOAM,
do you have any plans to implement the recommendations by Higuera in your next version? https://arxiv.org/abs/1810.03492 Thanks Last edited by Ramsay; July 24, 2019 at 18:38. |
July 31, 2019, 03:50 |
Post-process of IHFoam
#286 |
Matte Wang
Rep Power: 8 |
Hello, IHFoam
I am running the case of TUTORIAL 6: REGULAR WAVES INTERACTION WITH A FLOATING STRUCTURE (3D) on http://ihfoam.ihcantabria.com. Eventually, I have finished the calculation and get similar graphics as document mentioned. However, I am still confusing about the postProcessing after calculation. 1. How can I get six degrees of freedom of floatingObject from log.OverWaves? 2. What should I do if I want to obtain the wave height on every time step? It seems that the IHFoam provides a function named freeSurface for postProcessing, but the result is a STL files. I don't know how to cope with it. Could you please give me some detailed information? Best regards, Aunura |
July 31, 2019, 04:13 |
#287 | |
Rep Power: 9 |
Hi Aunura
1) There are several threads in the forum where everything is explained; I have added just two of them: How to plot pitch motion for free decay test? Orientation tensor of 6DoF solver 2) You should add some free-surface sensors. Please, take a look to the system/controlDict of, for example, ~/OpenFOAM/OpenFOAM-v1812/tutorials/multiphase/interFoam/laminar/waveExampleStokesII 3) Open the stl's with paraview, you will be able to make a video of the free surface evolution during the simulation...or maybe transform them to .csv format, for example, and do some nice postprocessing. Best Regards, IHFOAM Team
July 31, 2019, 06:14 |
#288 | |
Rep Power: 9 |
You should first, create a mesh with no refinement (but with enough discretization), and run a preliminary simulation. Then, do some specific refinement near the free surface or near the dike wall. and run a realistic case. Best Regards, IHFOAM Team
July 31, 2019, 09:16 |
Problems with StokesI in a 2D wave Flume
#289 |
Lea Fehn
Rep Power: 7 |
Hey IHFOAM,
i am simulating relgular StokesI deep water waves (H=0,25m and T=5s) in a 2D wave flume with 20m water depth, but i do not get good results. There are crazy velocites in the water body an also the the wavehights are variing. I copied everything from the Turorial waveExampleStokesI in OpenFOAm v1712. I already tried different meshes. Am i doing anything wrong? I attach some pictures and the case folders Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: plus | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object wavesProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // inlet { alpha alpha.water; waveModel StokesI; nPaddle 1; waveHeight 0.25; waveAngle 0.0; rampTime 5; activeAbsorption yes; wavePeriod 5; } outlet { alpha alpha.water; waveModel shallowWaterAbsorption; nPaddle 1; } // ************************************************************************* // |
August 2, 2019, 05:35 |
#290 |
Matte Wang
Rep Power: 8 |
Thank you, IHFoam. I have already got what I want using the method mentioned in these threads. However, I still have one question.
I have to deploy many free surface sensor to ensure the free surface I got smooth enough. You know, if I deploy a sensor every 0.1 meters in X direction while the length of water flume is up to 20 meters. It‘s too tedious for me to add them one by one in controlDict. Therefore, I want to know that is there any other method for me to deploy these sensors? |
August 2, 2019, 13:55 |
#291 |
Lea Fehn
Rep Power: 7 |
Hello again IHFoam-Team,
I would really appreciate your help bacuase I am writing my diploma thesis. Otherwise I will discuss the results that i got so far. Have a nice weekend and thanks in advanced Lea |
August 9, 2019, 04:50 |
#292 | |
Chiara Viola
Rep Power: 7 |
I tried several cell dimensions and my simulation worked only for cells of 8 cm or more (that means it's very unrealistic because I even can't see the waves and the overtopping). Now I'm trying to refine for a realistic case but I don't know the procedure and how to do that. I tried to re-run blockMesh, I tried to re-run also snappy but with no results. I thought about refineMesh utility but the problem for me is that snappy keeps the non refined geometry so the angle between bathymetry and dike and also all the wall are not representing the real case with the right dimensions (the wall results warped and lower). Could you please suggest me what should I do in order to refine and run the realistic case? Best regards, Chiara |
August 16, 2019, 10:19 |
#293 | |
Rep Power: 8 |
Why don't you use this function in your controlDict instead of the line functions? It will give you .stl files of surface elevation through whole domain at each time step which you can plot with Matlab or import to and view with Salome. HTML Code:
freeSurface { type surfaces; functionObjectLibs ( "libsampling.so" ); writeControl outputTime; outputInterval 1; surfaceFormat stl; interpolationScheme cellPoint; surfaces ( topFreeSurface { type isoSurface; isoField alpha.water; isoValue 0.5; interpolate true; } ); fields ( alpha.water ); } |
August 16, 2019, 10:59 |
#294 | |
Rep Power: 8 |
Hi Lea,
You can definitely get better answers from IHFOAM team but since I saw your problem please let me mention a couple of things. 1. You have only 5 grid points for your wave height (wave height=25cm, grid=6cm) which can be a source of decreasing wave height. Please try 10 or higher. 2. Please make the aspect ratio of your grids near the free surface as close as possible to 1. Here it seems that it is equal to (6/25)=0.25. 3. You have used default configuration such as maxCo, as well as other configurations in fvSchemes that are quite diffusive. Please go through the literature and change the schemes to less diffusive ones, but do not change them to too oscillating schemes. 4. It seems that your water depth and wave length indicate intermediate water. Unfortunately, active wave absorption has a little bit reflection in intermediate water and that can also be a cause of your problem, but that should not affect your results that much. 5. Your domain is too long, 160 m. Thus, with the default configurations you will lose wave height. Since I am also an amateur in this field, the above recommendations can be wrong. Please wait for the IHFOAM team answer to make final decisions. Regards Quote:
August 16, 2019, 16:18 |
#295 |
Rep Power: 8 |
Hi IHFOAM Team,
I Hope you're doing well. I have a problem in my simulations from long time ago that I really do not know how to solve. The problem is that when I compare my theoretical surface elevation to the numerical one simulated with IHFOAM, the crests are similar to the theoretical results, however, troughs are most of the times higher than the theoretical results. Could you please give me a hint about the possible reasons behind this problem. H=0.5 m h=1.89 m T=2.5 sec Stokes I wave maker location=28 m, model is shifted 28 m For x=58 to x=86 is a sloped surface so the waves break and theoretical results my not be valid in that region. However, my question is about the x=28 m to x=58 m. |
August 23, 2019, 03:01 |
#296 | |
Rep Power: 9 |
Hi Aunura,
August 23, 2019, 03:08 |
#297 |
Rep Power: 9 |
Hi Lea,
It seems that it might be caused because you are running your case as laminar. You should re-run it with the kEpsilon turbulence model, for example. Please, take a look to any of our tutorials if you do not know how to do it: http://ihfoam.ihcantabria.com/wp-con...M_Course_3.pdf Best Regards, IHFOAM Team
http://ihfoam.ihcantabria.com/ Last edited by IHFOAM Team; August 26, 2019 at 06:29. |
August 23, 2019, 03:14 |
#298 | |
Rep Power: 9 |
Hi Chiara,
I can recommend you any of ours: - http://ihfoam.ihcantabria.com/wp-con...M_Course_4.pdf - http://ihfoam.ihcantabria.com/wp-con...M_Course_5.pdf Regards, IHFOAM Team
August 23, 2019, 03:23 |
#299 | |
Rep Power: 9 |
Hi Ramsay,
Do you have the real movement of the wavepaddle? you can use it as the input. Regards, IHFOAM Team
http://ihfoam.ihcantabria.com/ Last edited by IHFOAM Team; August 29, 2019 at 03:50. |
September 1, 2019, 03:02 |
#300 | |
Matte Wang
Rep Power: 8 |
Good idea. Thank you very much!
Another questions is a problem of debugging. Recently I want to debug OpenFOAM using gdb. Then, I turn on the WM_COMPILE_OPTION to Debug in bashrc, and compile the OpenFOAM again. However, it seems that something is wrong. The error message is: Quote:
Divergence detected in AMG solver: k when udf loaded | google9002 | Fluent UDF and Scheme Programming | 3 | November 7, 2019 23:34 |
udf problem | jane | Fluent UDF and Scheme Programming | 37 | February 20, 2018 04:17 |
UDF velocity profile | willroca | Fluent UDF and Scheme Programming | 2 | January 10, 2016 03:13 |
Error messages | atg | enGrid | 7 | August 30, 2013 11:16 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
