[swak4Foam] groovyBC for coupled boundary condition |
July 3, 2014, 12:41 |
Rep Power: 12 |
Dear foamers,
I would like to set up the boundary condition for P that is coupled to the variable T. For example: dP ----- = - T dn on a specific patch (lets say floor) I did try, floor { type groovyBC; gradientExpression "-thetaFloor"; fractionExpression "0"; variables "thetaFloor{floor}=T;"; value uniform 0; } But then I get --> FOAM Warning : From function ExpressionResult::getUniformInternal(const label size,bool noWarn) in file ExpressionResult/ExpressionResultI.H at line 332 The minimum value -47.6319 and the maximum 41.4594 differ. I will use the average -0.120515 every time step. What am I doing wrong? |
July 3, 2014, 17:14 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The problem of remote variables having to be uniform was discussed numerous times (I won't repeat this here especially as you don't need a remote)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
July 6, 2014, 02:34 |
Rep Power: 12 |
Thanks it works.
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
[swak4Foam] Boundary condition set using groovyBC or codedFixedValue | behzad-cfd | OpenFOAM Community Contributions | 17 | December 19, 2017 13:30 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
[swak4Foam] turbulence boundary condition in groovyBC. | immortality | OpenFOAM Community Contributions | 6 | January 7, 2013 04:19 |
