[swak4Foam] groovyBC error: velocity profile (2D) >> what's wrong?
Old   June 18, 2014, 17:04
Default groovyBC error: velocity profile (2D) >> what's wrong?
Tommy Sp
vitorspadeto is on a distinguished road
groovyBC error
Hi everybody!
I'm trying to implement a parabolic velocity profile to my inlet (2D), cordinates: (x,z) . Inlet is located between the coordinates z= 0 and z=0.001. the parabolic equation for this profile is
Velocity_x_direction = 99*z - 98072*z².
This equation in this range of points (between z= 0 and z=0.001) give the exact velocity profile that I need.
I already add "libs" lines in the end of ControlDict file (I'm using swak4Foam to use GroovyBC):
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     icoFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime        10;
deltaT          0.1;
writeControl    adjustableRunTime;
writeInterval  1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  yes;
maxCo           1;
maxAlphaCo      1;
 maxDeltaT       1;
libs (
      "libOpenFOAM.so"
      "libsimpleSwakFunctionObjects.so"
      "libswakFunctionObjects.so"
      "libgroovyBC.so"
And this is my U file, with the profile velocity:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
     type            groovyBC;
     variables "zp=pts().z;    velocity=(99.036*zp-98072.289*pow(zp,2));";
     valueExpression "velocity";
    value           uniform (0.02 0 0);
    outlet
        type            zeroGradient; // At the outlet the velocity is unknown so we take the gradient of velocity as zero here
    wall
        type            fixedValue;
	value		uniform (0 0 0); // we use the no slip condition at the walls so u = v = 0
 frontAndBack
        type            empty;
This is the error that appeared on the terminal:
HTML Code:
sp@sp-945GCM-S2C:~/PGSPAD/exemplos_para_o_PG/blood/Newtonian$ icoFoam
|  \\    /   O peration     | Version:  2.2.0                                 |
Build  : 2.2.0-5be49240882f
Exec   : icoFoam
Date   : Jun 18 2014
Time   : 17:01:52
Host   : "sp-945GCM-S2C"
PID    : 4579
Case   : /home/sp/PGSPAD/exemplos_para_o_PG/blood/Newtonian
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Time = 0.1
Courant Number mean: 0.00555556 max: 10
word::stripInvalid() called for word velocity
    For debug level (= 2) > 1 this is considered fatal
Abortado (imagem do núcleo gravada)
What Should I do to correct this error?
THANKS FRIENDS!
vitorspadeto is offline   Reply With Quote
Old   June 18, 2014, 17:24
Assistant Moderator
Bernhard Gschaider
Originally Posted by vitorspadeto View Post
groovyBC error
Hi everybody!
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
startTime       0;
stopAt          endTime;
endTime        10;
deltaT          0.1;
writeInterval  1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
timeFormat      general;
timePrecision   6;
adjustTimeStep  yes;
maxCo           1;
maxAlphaCo      1;
 maxDeltaT       1;
libs (
      "libOpenFOAM.so"
      "libgroovyBC.so"
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    inlet
     type            groovyBC;
    outlet
    wall
        type            fixedValue;
 frontAndBack
        type            empty;
HTML Code:
Exec   : icoFoam
Date   : Jun 18 2014
Time   : 17:01:52
PID    : 4579
nProcs : 1
Create time
Reading field p
Reading field U
Starting time loop
Time = 0.1
THANKS FRIENDS!
The problem is probably the spaces between ";" and "velocity".
Which version of swak4Foam are you using? I thought that problem was already fixed
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 18, 2014, 17:35
Tommy Sp
swak4Foam 0.3.0
Inserting "normal()"
inlet
type groovyBC;
variables "zp=pts().z;velocity=((99.036*zp)-98072.289*pow(zp,2))*normal();";
value uniform (1 0 0);
new error:
 --> FOAM FATAL ERROR:
 Parser Error for driver PatchValueExpressionDriver at "1.10-11" :"syntax error, unexpected pointScalarID"
"((99.036*zp)-98072.289*pow(zp,2))*normal()"
Context of the error:
- From dictionary: /home/sp/PGSPAD/exemplos_para_o_PG/blood/Newtonian/0/U.boundaryField.inlet
  Evaluating expression "((99.036*zp)-98072.289*pow(zp,2))*normal()"
    From function parsingValue
    in file lnInclude/CommonValueExpressionDriverI.H at line 1181.
FOAM exiting
Old   June 18, 2014, 19:36
Assistant Moderator
Bernhard Gschaider
swak4Foam 0.3.0
inlet
type groovyBC;
new error:
FOAM exiting
Scalar constants are "on the faces". To use them on points you'll have to wrap them in toPoint().
Anyway: leave that. I think you want to use pos() instead of pts().
Old   June 19, 2014, 16:31
Smile
Tommy Sp
thanks gschaider!
Problem Solved! Now beginners can use this post to learn more about swak4Foam/GroovyBC!
[swak4Foam] problem with Velocity Profile with groovyBC ssss OpenFOAM Community Contributions 1 August 7, 2014 15:44
[swak4Foam] whats wrong with this groovyBC expression in parenthesis? immortality OpenFOAM Community Contributions 11 June 5, 2013 08:54
[swak4Foam] is this expression as bolean sentence wrong in groovyBC? immortality OpenFOAM Community Contributions 6 March 8, 2013 06:24
[swak4Foam] "field U not existing or of wrong type" groovyBC error. immortality OpenFOAM Community Contributions 1 February 4, 2013 16:08
reactingFoam - wrong (temperature) profile megacrout OpenFOAM 1 August 1, 2011 06:11
