[swak4Foam] groovy BC
Old   April 10, 2014, 07:20
Default groovy BC
zohreh imani nejad
imani is on a distinguished road
hi
who can help me
i model a hot room with groovy BC
i have problem about T file
my T file is as below
dimensions [0 0 0 1 0 0 0];
internalField uniform 293;
boundaryField
floor
type fixedValue;
value uniform 283.15; // floor temperature :10 'C
ceiling
type groovyBC;
valueExpression "291"; //291 is air inlet tempareture
gradientExpression "0";// consider the rest of celing insulated
fractionExpression "pos().x > 2.65 && pos().x < 2.95 && pos().z > 2.23 && pos().z < 2.38 ? 1 : 0";
value uniform 293;
fixedWall-1
type groovyBC;
valueExpression "318"; // temperature of skiriting heater
gradientExpression "0"; // the rest of wall consider insulated if it is internal wall
fractionExpression "pos().y < 0.15 ? 1 : 0";
value uniform 293;
fixedWall-2
type groovyBC;
value uniform 293;
fixedWall-3
type groovyBC;
value uniform 293;
fixedWall-4
type groovyBC;
variables "Kwall=0.25;Kglazing=1.2;Qwall=-8.5;Qglazing=-40.8;";// taken from table 3
gradientExpression "(pos().y > 0.3 && pos().y < 2.3) && ((pos().x > 0.7 && pos().x < 2.3) || (pos().x > 3 && pos().x < 4.6)) ? Qglazing/Kglazing : Qwall/Kwall";// in external wall which containts windows, BC is constant negative heat flux
value uniform 293;
but i want to change the skritingBoard condition
i want to give it a constant flux condition
how i can do it?
i know it's Q and K
thanks
imani is offline   Reply With Quote
Old   April 13, 2014, 08:43
Assistant Moderator
Bernhard Gschaider
Originally Posted by imani View Post
hi
who can help me
boundaryField
fixedWall-4
type groovyBC;
value uniform 293;
how i can do it?
i know it's Q and K
thanks
Could you be more specific? What is "the skritingBoard condition". What would be "constant flux condition"? You can't mean "constant heat flux" as you've already implemented such a thing for fixed-wall-4 (constant gradient that depends on the heat flux and conductivity)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
[swak4Foam] Groovy BC - time dependend Inlet Tobi OpenFOAM Community Contributions 20 August 27, 2020 10:22
[swak4Foam] How to use groovy Boundary conditions Zhiheng Wang OpenFOAM Community Contributions 8 November 6, 2019 10:28
[swak4Foam] groovy BC - which value is used ThorgrimmCFD OpenFOAM Community Contributions 2 May 7, 2015 05:06
[swak4Foam] groovy BC Ahmed Khattab OpenFOAM Community Contributions 4 November 7, 2013 08:51
[swak4Foam] using groovy boundry condition in multiphase problom javad814 OpenFOAM Community Contributions 1 November 30, 2011 17:29
