[swiftBlock/swiftSnap] How do you create your 2D geometries in Blender? |
Rep Power: 13 ![]() |
I am trying to use an existing 2D CAD drawing imported into Blender to create a 3D model so that I can use swiftBlock to create the blockMeshDict for OpenFOAM. From tutorials I have seen that the general way of doing this is to create faces made up of 3-4 points (http://www.youtube.com/watch?v=uLmlrc3vb1s) and then extrude the component however in my case there are a lot of points and will take a long time to create the required number of faces. Could anyone please let me know if this is the method you also use for your 2D cases or is there a much faster way of doing this?
I asked about this on the Blender forum but I have noticed that the majority of the Blender users "sculpt" their models rather than create from 2D drawings therefore, I was not able to get much help. |
I have managed to create simpler geometries without arcs and it worked fine the problems occur when I try to create it with the arcs. My other idea was to make the arc a straight line in blender and then manually change it to an arc in the created blockMeshDict file, however this did not work either as I could not create the faces using only hexahedrals in blender.
I am really struggling, could someone please help me with this by showing or explaining to me what procedure I should use to create the geometry? If a simpler alternative to Blender/swiftBlock exists for this geometry which is compatable with the solidMechanics solvers in OpenFOAM please let me know. Last edited by sur4j; January 3, 2014 at 14:48. |
Two solutions I found to this problem for anyone who encounters them in the future:
create the file *.foam | phongstar | OpenFOAM | 12 | October 14, 2018 18:06 |
SonicFoam tuto nacaAirfoil steadystate | Dorian1504 | OpenFOAM Running, Solving & CFD | 10 | October 11, 2017 17:05 |
[gmsh] How to create a 3D volume mesh using a existing surface mesh?! | RobertHB | Mesh Generation & Pre-Processing | 0 | July 20, 2017 08:12 |
[ICEM] how to create a 2d tri mesh with quad mesh in the boundary layer | seal2013 | ANSYS Meshing & Geometry | 3 | October 6, 2013 16:09 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
