[swak4Foam] groovyBC
Like Tree3Likes
Old   July 24, 2015, 03:53
saeed rashidzade
mordab is on a distinguished road
Originally Posted by mordab View Post
Hi all,
I tried to simulate a cavity in below temperature conditions:
Right & Left Wall:
Th-(Th-Tc)*y/L
Floor:
T=Th
ceiling:
gradT=0
so I changed 0/T file like this:
boundaryField
floor
type fixedValue;
value uniform 1;
rightWall
type groovyBC;
variables "y=pos().y; ymax=max(pos().y); T@floor=Th; Tc=0;";
valueExpression "Th-(Th-Tc)*y/ymax";
value uniform 0;
leftWall
type groovyBC;
value uniform 0;
movingWall
type zeroGradient;
but when I run, got the error message:
swak4Foam: Allocating new repository for sampledGlobalVariables
--> FOAM Warning :
From function ConcretePluginFunction<DriverType>::exists
in file lnInclude/ConcretePluginFunction.C at line 121
Constructor table of plugin functions for PatchValueExpressionDriver is not initialized
--> FOAM FATAL ERROR:
Parser Error for driver PatchValueExpressionDriver at "1.1-2" :"field Th not existing or of wrong type"
"Th-(Th-Tc)*y/ymax"
Context of the error:
- From dictionary: /home/saeed/Desktop/porousCavity/0/T.boundaryField.rightWall
Evaluating expression "Th-(Th-Tc)*y/ymax"
From function parsingValue
in file lnInclude/CommonValueExpressionDriverI.H at line 1189.
FOAM exiting
did I use groovyBC correctly?
what should I do?
Thanks
finally I found the trouble, I should not use space in variables
TML likes this.
mordab is offline   Reply With Quote
groovybc, swak4foam
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 08:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 07:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 04:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 08:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 09:49
