[swak4Foam] groovy boundary condition for pressure
Old   October 14, 2013, 12:51
Default groovy boundary condition for pressure
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
i'm using groovy boundary condition to express velocity as a relation of pressure difference of pressure of two regions. the problem is that velocity is vector field while pressure is scalar so, there is a problem to express vector value as a relation of scalar value. i think that if i use gradp instead of p it will be helpful but openfoam can't understand gradp since it is not stored in file.
any one can help me figuring out a solution for this problem.
Ahmed Khattab is offline   Reply With Quote
Old   October 14, 2013, 18:29
Assistant Moderator
Bernhard Gschaider
Originally Posted by rebel ahmed View Post
If you look at http://openfoamwiki.net/index.php/Co...her_field_are: then you'll find that snGrad(p) gives you the gradient of p in the normal()-direction
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 15, 2013, 03:26
ahmed
Dear gschaider,
thanks for your reply, i tried this Boundary condition for velocity
               type            groovyBC;
               valueExpression "(pUpperFlow-pMiddleFlow)/(mu)";
               variables "pUpperFlow{patch'upperFlow_to_upperFilter}=snGrad(p);pMiddleFlow{patch'middleFlow_to_upperFilter/middleFlow}=snGrad(p);";
               value uniform (0 0 0);
and this is the error message:
[2] --> FOAM FATAL ERROR: [3]
[3]
[3] --> FOAM FATAL ERROR:
[3] The expected return type vector is different from the stored result type "scalar"
[1] The expected return type vector is different from the stored result type "scalar"
[1]
[1]
[1]     From function tmp<Field<Type> > ExpressionResult::getResult()
[1]
[2] The expected return type vector is different from the stored result type "scalar"
Old   October 15, 2013, 06:30
Assistant Moderator
Bernhard Gschaider
Dear gschaider,
               type            groovyBC;
[3]
[1]
[1]
[1]
As I said below: snGrad is the gradient IN THE DIRECTION NORMAL TO THE BOUNDARY. So it is a scalar. To get the actual vector multiply it with normal()
Old   November 14, 2015, 21:18
Saurabh Tandon
STutexas is on a distinguished road
Hi
I am a new Openfoam user and I have a question about the snGrad operator. In the post you describe the use of operator on a scalar field. But if the operator is applied to a vector field would it give a tensor?
STutexas is offline   Reply With Quote
groovy, pressure, scalar, vector, velocity
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Boundary condition not met, although fully converged Zerzura FLUENT 0 January 20, 2016 05:21
Radiation interface hinca CFX 15 January 26, 2014 18:11
