[swak4Foam] what does this postProcessing SWAK code do? |
#21 |
Ehsan
Rep Power: 26 ![]() |
Hi
I thought it be good that show a graph obtained by working this function as attached. then it would be a good explanation to this for readers: "saves maximum values for each cell has located on the plane and returns maximum and minimum and averages of thes maximum values in each time step during run"
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
#22 |
Rafael Marques
Rep Power: 12 ![]() |
Hi everbody,
this thread is old but i have a question about swakexpressions, i want to know what "integrate " do in accumulations? while using a cellZone? Is it a temperal or a spacial integral? and if it is a spacial integral is it a volume integral (dx,dy,dz) or is it a area integral (x,y)? the thing is i want to obtain a velcity field and i want to get the velocity*dy to get a massflow/meter, so i try to understand if i can use the integral or if i need to use the average comand for accumulations?? thank alot to everybody Rafa Marques |
#23 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer:
#24 |
Rafael Marques
Hi Bruno,
thanks a lot for your reply and i am in accordance with you, next time i do it first. But i continue with the problem because when i create a faceZone to intergrate over a face to obtain the massFlow of the water it is not possible because I the alpha ia a cell information and not depends on the face fo the cell (this is what i think). I try to explain what i did. I create a funkyexressionfield with alpha*Ux (ux is normal to the face) with a threshold of alpha>0.5, them i want to integrate this value over a face to obtain the water mass flow to get the overtopping of a wavebreaker. At the moment i am only able to get the velocity profile of the water, creating various gauges on a vertical line to sample the velocity and then i wrote a code in matlab to integrate the velocity field in dy to get the massflow per meter in every timestep, but that is really expensive computationally and time consuming because of the many file that i get when sampling in timestep. so i try to use swak4foam to do it, but without success . may be you can give me a hind how to do it? I try it to do like the example in th wiki page of swak but it doesn work because of the alpha field. thanks a lot Rafa Marques [ Moderator note: the continuation of this discussion moved to this thread: http://www.cfd-online.com/Forums/ope...swak4foam.html ] Last edited by wyldckat; September 6, 2015 at 11:42. Reason: added moderator note |
using fieldAverage library to average postprocessing | eelcovv | OpenFOAM Programming & Development | 32 | May 17, 2022 09:55 |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
Open Source Vs Commercial Software | MechE | OpenFOAM | 28 | May 16, 2011 11:02 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 10:11 |
own Code vs. commercial code | Bernhard Mueck | Main CFD Forum | 10 | February 16, 2000 10:07 |
