#61 |
Karthik Thyagarjan
Rep Power: 7 ![]() |
Hey guys
I did manage to build 2D refinement for OF6, ill clean up the sources and tar the files here soon. But there seems to significant mesh effects, in case of reactingFoam( modified to include dynamic mesh), I have tested it and the flow field changes quite a bit from non dynamic meshes. P.S thanks Luca, the sources were quite helpful. |
#62 | |
Rep Power: 14 ![]() |
Dear Luca,
Thank you very much for your work. It can work very well in our case. BTW, is it possible modify the code in order to be used for 1D AMR modelling? Thanks a lot. Quote:
#63 | |
Nguyen Duy Trong
Rep Power: 12 ![]() |
Have you tried to compile your source with OpenFOAM v5? I would like to know the suitability of your code with OpenFOAM v5. |
#64 | ||
For the current version of AMR in openfoam, how does it deal with the parallel load balancing? Because when the mesh is refined, the number of the cells in each processor will be different. Finally, one of the processors may take longer time for each time step than others. Any comments?
#65 | ||
X
Did anyone manage to overcome this issue? Thanks in advance! |
#66 | |
Hello Luca!
Amazing work! Is it now inside foam-extend-4.1? Because that's what was missing the last 6 years. I tried it once myself, but didn't get far. Now my bubbles might work with AMR!! Nice! Now [two things] one thing: - How can I cite you? second thing was: - Do you have an idea, why the solver complains with Code:
[5] --> FOAM FATAL ERROR: [5] Number of cells in mesh:2103 does not equal size of cellLevel:12668 This might be because of a restart with inconsistent cellLevel. ---- I got this solved by deleting the *.gz files in the basedir/constant/polyMesh. Then The AMR takes the correct ones. Best regards from the cavitation working group in Göttingen, Germany Quote:
#67 | |
Luca Cornolti
Rep Power: 10 ![]() |
Thank you,
sharing the code was a good way to make the time I spent on it more meaningful. Obviously, I didn't write articles about it and I don't need to be cited for this, but collaborations on modeling multiphase flows are always welcome. The code of the dynamic mesh refinement is quite messy, it seems that it was written a lot of years ago and never updated. In fact, the style of this code is far from the object oriented one which characterizes most of other OpenFOAM classes, I mean the hexRef8.C file has about 5400 lines! Moreover, there were comments like "crappy way to do ..." (in the 1706 version) and some checking loops which seem redundant in my opinion. Even Weller once answered to a request about the dynamic mesh refinement algorithm with something like: I didn't write this class, so I won't touch it. Some months ago , the developers of foam-extend (essentially Dr. Vukčević) rewrote this part of the code completely in a more object oriented style. You can find this development in the nextRelease branch of the git repository of foam-extend 4. I Attached an example of the setup which use this new refinement class (dynamicPolyRefinementFvMesh) for the interDyFoam solver of foam-extend. Unlike my developments, this class is not able to handle wedge cells, but overall it is written in a much better way, as I just modified the original code instead of rewriting it as they did and it should be done. I don't known if there are also benefits with respect to the computation time, you could check and tell us. The porting of the new developments of foam-extend to the other version of OpenFOAM is not straightforward, but it would be nice to do that and to try to extend the algorithm capability to allow mesh refinement only in the directions of high gradients instead of all directions. Quote:
#68 |
Rep Power: 13 ![]() |
I ported the library released with the paper to v1812: Rettenmaier, Daniel, et al. "Load balanced 2D and 3D adaptive mesh refinement in OpenFOAM." SoftwareX 10 (2019): 100317.git clone https://github.com/HenningScheufler/multiDimAMR.git Best, Henning |
#69 | |
vstron
#70 | |
vstron
After spending enough time (weeks), I was able to run this code successfully. Now another issue pops up with reconstructPar and reconstructParMesh. Feeling desperate, need your help of@of-VirtualBox:~/FOAMRUN/inject$ reconstructParMesh -latestTime -mergeTol 1e-05 /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : reconstructParMesh -latestTime -mergeTol 1e-05 Date : Jul 03 2020 Time : 16:52:55 Host : "of-VirtualBox" PID : 2740 Case : /home/of/FOAMRUN/inject nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time This is an experimental tool which tries to merge individual processor meshes back into one master mesh. Use it if the original master mesh has been deleted or if the processor meshes have been modified (topology change). This tool will write the resulting mesh to a new time step and construct xxxxProcAddressing files in the processor meshes so reconstructPar can be used to regenerate the fields on the master mesh. Not well tested & use at your own risk! Merge tolerance : 1e-05 Write tolerance : 1e-06 Doing geometric matching on correct procBoundaries only. This assumes a correct decomposition. Found 4 processor directories Reading database "inject/processor0" Reading database "inject/processor1" Reading database "inject/processor2" Reading database "inject/processor3" Setting master time to 0.04 Reading points from "inject/processor0" for time = 0.04 Reading points from "inject/processor1" for time = 0.04 Reading points from "inject/processor2" for time = 0.04 Reading points from "inject/processor3" for time = 0.04 Overall mesh bounding box : (0 0 -3.48955e-06) (7.99239e-05 0.00063 3.48955e-06) Relative tolerance : 1e-05 Absolute matching distance : 6.35088e-09 Constructing empty mesh to add to. Reading mesh to add from "inject/processor0" for time = 0.04 Adding to master mesh #0 Foam::error: ![]() #1 Foam::sigSegv::sigHandler(int) in "/home/of/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::face::normal(Foam::Field<Foam::Vector<double > > const&) const in "/home/of/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::wedgePolyPatch::initTransforms() in "/home/of/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::wedgePolyPatch::wedgePolyPatch(Foam::wedgePo lyPatch const&, Foam: ![]() #6 Foam::wedgePolyPatch::clone(Foam: ![]() #7 Foam: ![]() ![]() ![]() #8 in "/home/of/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/reconstructParMesh" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 in "/home/of/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/reconstructParMesh" Segmentation fault (core dumped) |
#71 | |
it should work with version openfoam v1812 from openfoam.com |
#72 |
George
Rep Power: 0 ![]() |
I downloaded Henning's port of the 2D mesh refinement for openfoam v1812 but can't get it to run in parallel. Each time I run the Allrun files for the tutorials I keep on running into this error Code:
Selecting dynamicFvMesh dynamicMultiDimRefineBalancedFvMesh [0] [0] [0] --> FOAM FATAL IO ERROR: [0] Entry 'operation' not found in dictionary "/mnt/c/Users/pcygh2/Documents/OpenFoam_cases/OpenFOAM-v1812/capillaryRisePlates2D/constant/dynamicMeshDict.adaptCriteria" [0] [0] file: /mnt/c/Users/pcygh2/Documents/OpenFoam_cases/OpenFOAM-v1812/capillaryRisePlates2D/constant/dynamicMeshDict.adaptCriteria [0] [0] From function bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType::option, bool) const [with T = Foam::word] [0] in file /opt/OpenFOAM/OpenFOAM-v1812/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 201. [0] FOAM parallel run exiting cheers |
#73 |
Felix Funk
Hey,
I want to do a adaptive mesh refinement in only x and y direction. However in OpenFoam 8 the mesh will always cut in 8 peaces. I tried the code from Ajit Kumar but got the same error like dzordz: --> FOAM FATAL ERROR: cell 689 of level 0 does not seem to have 8 points of equal or lower level I also tried to implement the meshRefinement2D_of6.tar.gz of Luca but didnt compile. Did someone wrote a new version for OpenFoam 8 ? Thanks, |
#74 |
I updated the readme of the project that explains the refinement selection.
the composedAdaptCriteria enables to combine multiple functions with logical operators e.g. and or |
#75 |
Bas Nieuwboer
Dear Henning,
I tried out the code and I think it is really nice development for speeding up VOF-simulations. I am experienced with openfoam, but just started out with VOF simulations and came across some issues with the multiDimAMR-code I wanted to share with you in the hope you might be able to solve them for me and the community. 1: I downloaded the master branch from your personal git: https://github.com/HenningScheufler/multiDimAMR.git to compile with openfoam 2006 patch 200727 and I got two error messages: Code:
dynamicMultiDimRefineFvMesh/dynamicMultiDimRefineFvMesh.C:598:46: error: ‘class Foam::HashTable<int, int, Foam::Hash<int> >::const_iterator’ has no member named ‘object’ const label oldPointi = iter.object(); Code:
dynamicMultiDimRefineFvMesh/dynamicMultiDimRefineFvMesh.C:1290:56: error: no matching function for call to ‘Foam::dynamicMultiDimRefineFvMesh::writeObject(Foam::IOstreamOption::streamFormat&, Foam::IOstreamOption::versionNumber&, Foam::IOstreamOption::compressionType&, const bool&) const’ dynamicFvMesh::writeObject(fmt, ver, cmp, valid) 2: For me the damBreak case crashed, when using the ptscotch method in the balanceParDict. As a solution I used the kahip method. For me the question rose if ptscotch works when openfoam v2012 is used. I also wondered what determines when one needs to use kahip? And why is it not the standard method if it is most stable? 3: The AMR method does work well with iso-advector as you already mentioned to openfoam in https://develop.openfoam.com/Develop.../-/issues/1955 . I hope this will be picked up quickly by the development team. Also I hope this AMR-code will be included into the openfoam distribution or the community codes. Is this something you are aiming for? 4. After running a decomposed test case, I ran into trouble reconstructing the case. As a novice in this area I hoped to find the answer in the tutorial cases, but those are not reconstructed. Would it be possible to include a reconstruction method in the tutorial cases. I found a working method at this forum: Problems with reconstructParMesh and reconstructPar in 15 . Could you incorporate that in the allrun file? Or do you have a better method that can be included? I hope you will find my comments insightful and want to look into them. Thank you again for sharing this with the openfoam community. |
#76 |
Thanks for the feedback!
1. I updated the Readme 2. Openfoam is not able to handle meshes with zero cells the decompositions method sometimes if the base mesh has a low number of cells puts zero cells into a processor resulting in a crash. In my experience kahip was not so suspectible to this issue. Also the decomposition method should only affect the memory usage and speed of the simulation no its results the choice is not that important. 3. If you want to test AMR with a geometricVoF method this might be a helpful reference but it currently only works with of1812 https://arxiv.org/abs/2103.00870 https://github.com/DLR-RY/TwoPhaseFlow AMR is a crucial technology for the simulation of multiphase flow and also has numerous other benefits. But the current release multiDimAMR is far from production ready 4. I quick workaround to the check the results is to use the "decomposed Mode" by touch test.foam # test or some other name only .foam matters paraview test.foam |
#77 |
Bas Nieuwboer
Dear Henning,
Thank you for the answers. For now, I'll stick with the standard openfoam implementation of the VOF method together with multiDimAMR. I hope that you keep on working on developing multiDimAMR to get it production ready in the future. Bas |
#78 | |
Rep Power: 5 ![]() |
I tried to use your package with Openv2112. When compiling, few errors occur in hexRefNew.C. Do you plan to update your package to the latest ESI variant? |
#79 |
Update:
With Branch v2012 only the utility testUpdate is not compiled correctly. The rest works. |
#80 |
Giancarlo Esposito
Rep Power: 4 ![]() |
Hello guys, thanks for the nice contribution. Does the code updated by Luca work also for OF7?
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[Workbench] mesh refinement of vortex tube using workbench | aqsa1590 | ANSYS Meshing & Geometry | 3 | December 25, 2014 08:57 |
[snappyHexMesh] snapEdge - failure | Tobi | OpenFOAM Meshing & Mesh Conversion | 33 | March 18, 2014 03:58 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
