[Other] OpenFOAM Installation for navalFoam
Like Tree5Likes
Old   June 23, 2014, 09:00
Default Unknown AMG policy AAMG
  #21
yong zhao
fluid126 is on a distinguished road
I also have this problem, how did you solve this problem. thank you/
Originally Posted by mary mor View Post
Besides, about navalFoam I ran the tutorials. the procedures are Ok until running navalFoam.
It says:
--> FOAM FATAL ERROR:
Valid AMG policies are :
1
PAMG
There's no AAMG policy defined in my OpenFOAM1.6-ext that is used in fvSolution. Can I download it? or Can I change it to PAMG?
Thanks
Best
fluid126 is offline   Reply With Quote
Old   June 23, 2014, 09:07
maryam morta
mary mor is on a distinguished road
Hi
I changed it to PAMG and run it.
mary mor is offline   Reply With Quote
Old   July 28, 2017, 06:26
Default Problem installation OpenFoam
  #23
Lucas Delcourt
ldelcourt is on a distinguished road
Hi everyone,
I know this thread is a bit old but my question fit perfectly with this one.
I am doing some free surface calculations and with the classic OpenFoam I had a lot of instabilities close to the hull, because I was using a too high Courant number to initialize the simulations. I have seen all the work done especially concerning the convecting scheme to adopt (HRIC, BRICS, CICSAM) which allows to have a higher courant number and also have a faster convergence.
So I was interested in the navalFoam package. I installed the foam-extended4.0 release to be able to use the package, but I am facing probem trying to compile it...
Here is the message after trying
wmake all
could not open file tetFemMatrices.H for source file threeDofMotion/threeDofMotion.C
could not open file tetPointFields.H for source file threeDofMotion/threeDofMotion.C
could not open file faceTetPolyPatch.H for source file threeDofMotion/threeDofMotion.C
could not open file fixedValueTetPolyPatchFields.H for source file threeDofMotion/threeDofMotion.C
Making dependency list for source file floatingBody/floatingBody.C
Making dependency list for source file sixDofMotion/sixDofMotion.C
could not open file tetFemMatrices.H for source file floatingBody/floatingBody.C
could not open file tetPointFields.H for source file floatingBody/floatingBody.C
could not open file faceTetPolyPatch.H for source file floatingBody/floatingBody.C
could not open file tetFemMatrices.H for source file sixDofMotion/sixDofMotion.C
could not open file tetPointFields.H for source file sixDofMotion/sixDofMotion.C
could not open file faceTetPolyPatch.H for source file sixDofMotion/sixDofMotion.C
could not open file fixedValueTetPolyPatchFields.H for source file floatingBody/floatingBody.C
could not open file fixedValueTetPolyPatchFields.H for source file sixDofMotion/sixDofMotion.C
Making dependency list for source file sixDofTopoMotion/sixDofTopoMotion.C
could not open file tetFemMatrices.H for source file sixDofTopoMotion/sixDofTopoMotion.C
could not open file tetPointFields.H for source file sixDofTopoMotion/sixDofTopoMotion.C
could not open file faceTetPolyPatch.H for source file sixDofTopoMotion/sixDofTopoMotion.C
could not open file fixedValueTetPolyPatchFields.H for source file sixDofTopoMotion/sixDofTopoMotion.C
Making dependency list for source file floatingBodyFvMesh/floatingBodyFvMesh.C
could not open file tetFemMatrices.H for source file floatingBodyFvMesh/floatingBodyFvMesh.C
could not open file tetPointFields.H for source file floatingBodyFvMesh/floatingBodyFvMesh.C
could not open file faceTetPolyPatch.H for source file floatingBodyFvMesh/floatingBodyFvMesh.C
could not open file fixedValueTetPolyPatchFields.H for source file floatingBodyFvMesh/floatingBodyFvMesh.C
Making dependency list for source file rasVofForceAndTorque/rasVofForceAndTorqueFunctionObject.C
could not open file tetFemMatrices.H for source file threeDofMotionSubset/threeDofMotionSubset.C
could not open file tetPointFields.H for source file threeDofMotionSubset/threeDofMotionSubset.C
could not open file faceTetPolyPatch.H for source file threeDofMotionSubset/threeDofMotionSubset.C
could not open file fixedValueTetPolyPatchFields.H for source file threeDofMotionSubset/threeDofMotionSubset.C
Making dependency list for source file CICSAM/CICSAM.C
Making dependency list for source file CICSAM/CICSAMDC.C
Making dependency list for source file fvPatchFields/movingWallSlip/movingWallSlipFvPatchVectorField.C
Making dependency list for source file numericalBeach/numericalBeach.C
Making dependency list for source file fvPatchFields/linearWave/linearWaveFvPatchFields.C
Making dependency list for source file fvPatchFields/linearWaveVelocity/linearWaveVelocityFvPatchField.C
Making dependency list for source file fvPatchFields/numericalBeachFvPatchField/numericalBeachFvPatchField.C
SOURCE=TaitBryanCoordinateRotation/TaitBryanCoordinateRotation.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -g     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/incompressible/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/interfaceProperties/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/turbulenceModels     -I/home/cfd_computer/foam/foam-extend-4.0/src/turbulenceModels/LES/LESdeltas/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/topoChangerFvMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/meshTools/lnInclude          -I/home/cfd_computer/foam/foam-extend-4.0/src/tetDecompositionFiniteElement/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/tetDecompositionMotionSolver/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/ODE/lnInclude -IlnInclude -I. -I/home/cfd_computer/foam/foam-extend-4.0/src/foam/lnInclude -I/home/cfd_computer/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/TaitBryanCoordinateRotation.o
SOURCE=harmonicSolidMotion/harmonicSolidMotion.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -g     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/incompressible/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/interfaceProperties/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/turbulenceModels     -I/home/cfd_computer/foam/foam-extend-4.0/src/turbulenceModels/LES/LESdeltas/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/topoChangerFvMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/meshTools/lnInclude          -I/home/cfd_computer/foam/foam-extend-4.0/src/tetDecompositionFiniteElement/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/tetDecompositionMotionSolver/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/ODE/lnInclude -IlnInclude -I. -I/home/cfd_computer/foam/foam-extend-4.0/src/foam/lnInclude -I/home/cfd_computer/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/harmonicSolidMotion.o
SOURCE=graphSolidMotion/graphSolidMotion.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -g     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/incompressible/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/interfaceProperties/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/turbulenceModels     -I/home/cfd_computer/foam/foam-extend-4.0/src/turbulenceModels/LES/LESdeltas/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/topoChangerFvMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/meshTools/lnInclude          -I/home/cfd_computer/foam/foam-extend-4.0/src/tetDecompositionFiniteElement/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/tetDecompositionMotionSolver/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/ODE/lnInclude -IlnInclude -I. -I/home/cfd_computer/foam/foam-extend-4.0/src/foam/lnInclude -I/home/cfd_computer/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/graphSolidMotion.o
SOURCE=excentreRotationFvMesh/excentreRotationFvMesh.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -g     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/incompressible/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/interfaceProperties/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/turbulenceModels     -I/home/cfd_computer/foam/foam-extend-4.0/src/turbulenceModels/LES/LESdeltas/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/topoChangerFvMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/meshTools/lnInclude          -I/home/cfd_computer/foam/foam-extend-4.0/src/tetDecompositionFiniteElement/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/tetDecompositionMotionSolver/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/ODE/lnInclude -IlnInclude -I. -I/home/cfd_computer/foam/foam-extend-4.0/src/foam/lnInclude -I/home/cfd_computer/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/excentreRotationFvMesh.o
excentreRotationFvMesh/excentreRotationFvMesh.C:31:18: fatal error: Time.H: No such file or directory
compilation terminated.
excentreRotationFvMesh/excentreRotationFvMesh.dep:512: recipe for target 'Make/linux64GccDPOpt/excentreRotationFvMesh.o' failed
make: *** [Make/linux64GccDPOpt/excentreRotationFvMesh.o] Error 1
make: *** Waiting for unfinished jobs....
+ wmake navalFoam
Making dependency list for source file navalFoam.C
SOURCE=navalFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/incompressible/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/interfaceProperties/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/turbulenceModels/incompressible/turbulenceModel     -I/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/meshTools/lnInclude          -I../vofDynamicMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/ODE/lnInclude -IlnInclude -I. -I/home/cfd_computer/foam/foam-extend-4.0/src/foam/lnInclude -I/home/cfd_computer/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/navalFoam.o
In file included from readControls.H:1:0,
                 from navalFoam.C:60:
/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude/readTimeControls.H: In function ‘int main(int, char**)’:
/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude/readTimeControls.H:32:1: error: ‘adjustTimeStep’ was not declared in this scope
 adjustTimeStep =
/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude/readTimeControls.H:35:1: error: ‘maxCo’ was not declared in this scope
 maxCo =
/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude/readTimeControls.H:38:1: error: ‘maxDeltaT’ was not declared in this scope
 maxDeltaT =
In file included from navalFoam.C:61:0:
correctPhi.H:37:29: error: ‘class Foam::dynamicFvMesh’ has no member named ‘solver’
         pcorrEqn.solve(mesh.solver(pd.name()));
In file included from navalFoam.C:93:0:
In file included from navalFoam.C:119:0:
pdEqn.H:49:30: error: ‘class Foam::dynamicFvMesh’ has no member named ‘solver’
             pdEqn.solve(mesh.solver("pdFinal"));
In file included from navalFoam.C:138:0:
pEqn.H:30:25: error: ‘class Foam::dynamicFvMesh’ has no member named ‘solver’
         pEqn.solve(mesh.solver(pd.name()));
pEqn.H:33:40: error: ‘class Foam::dynamicFvMesh’ has no member named ‘relaxationFactor’
     Info << "Relaxation: p = " << mesh.relaxationFactor(p.name()) << endl;
In file included from readControls.H:2:0,
                 from navalFoam.C:72:
/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude/readPIMPLEControls.H:9:10: warning: unused variable ‘momentumPredictor’ [-Wunused-variable]
     bool momentumPredictor =
/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude/readPIMPLEControls.H:12:10: warning: unused variable ‘transonic’ [-Wunused-variable]
     bool transonic =
/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude/readPIMPLEControls.H:3:9: warning: unused variable ‘nOuterCorr’ [-Wunused-variable]
     int nOuterCorr(readInt(pimple.lookup("nOuterCorrectors")));
/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude/readPIMPLEControls.H:4:9: warning: unused variable ‘nCorr’ [-Wunused-variable]
     int nCorr(readInt(pimple.lookup("nCorrectors")));
     bool transonic =
In file included from navalFoam.C:60:0:
readControls.H:28:12: warning: unused variable ‘startMotionTime’ [-Wunused-variable]
     scalar startMotionTime(readScalar(pimple.lookup("startMotionTime")));
navalFoam.dep:755: recipe for target 'Make/linux64GccDPOpt/navalFoam.o' failed
make: *** [Make/linux64GccDPOpt/navalFoam.o] Error 1
+ wmake navalFoamVariant2
Making dependency list for source file navalFoamVariant2.C
SOURCE=navalFoamVariant2.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/cfd_computer/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/incompressible/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/transportModels/interfaceProperties/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/turbulenceModels/incompressible/turbulenceModel     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/meshTools/lnInclude          -I/home/cfd_computer/foam/foam-extend-4.0/src/tetDecompositionFiniteElement/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/tetDecompositionMotionSolver/lnInclude     -I../vofDynamicMesh/lnInclude     -I/home/cfd_computer/foam/foam-extend-4.0/src/ODE/lnInclude -IlnInclude -I. -I/home/cfd_computer/foam/foam-extend-4.0/src/foam/lnInclude -I/home/cfd_computer/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/navalFoamVariant2.o
                 from navalFoamVariant2.C:61:
 adjustTimeStep =
 maxCo =
 maxDeltaT =
In file included from navalFoamVariant2.C:62:0:
correctPhi.H:44:29: error: ‘class Foam::dynamicFvMesh’ has no member named ‘solver’
In file included from navalFoamVariant2.C:94:0:
In file included from navalFoamVariant2.C:120:0:
In file included from navalFoamVariant2.C:138:0:
                 from navalFoamVariant2.C:73:
     bool transonic =
     bool transonic =
In file included from navalFoamVariant2.C:61:0:
navalFoamVariant2.dep:756: recipe for target 'Make/linux64GccDPOpt/navalFoamVariant2.o' failed
make: *** [Make/linux64GccDPOpt/navalFoamVariant2.o] Error 1
Can anyone help me?
Thanks
Lucas
ldelcourt is offline   Reply With Quote
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
[OpenFOAM.org] Installation notes: OpenFOAM 2.3.x (git repo) on OSX 10.9 opedrofunk OpenFOAM Installation 7 July 1, 2015 14:51
[Discussion] Restructuring the Installation page at openfoamwiki.net wyldckat OpenFOAM Installation 16 November 2, 2013 12:43
Trouble shooting about OpenFOAM installation in Ubuntu 12.04 Nait OpenFOAM Installation 2 December 12, 2012 11:20
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 superfxfund OpenFOAM Installation 3 November 11, 2010 03:15
