[swak4Foam] outputTime in Swak function
Like Tree5Likes
Old   October 6, 2022, 13:08
Default write every timeStep
  #21
F42
F42 is on a distinguished road
I want swakExpressionAverageDistribution to output at every timeStep even when I am using a higher writeInterval for the overall simulation.
I tried
writeInterval always;
as well as "timeStep" and "runTime" as the writeControl arguments but it still only outputs at solver write intervals.
It works for the regular patchAverage function object though.
What am I doing wrong?
(foamVersion v2206)
Thank you
F42 is offline   Reply With Quote
Error in compiling new drag model k.farnagh OpenFOAM Programming & Development 13 May 21, 2016 04:08
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
