April 18, 2013, 11:25 |
build problem swak4Foam OF 2.2.0
Cathelain
Rep Power: 13 |
I would like to apply 2nd order Stokes waves on the inlet of a wave tank.
I downloaded Swak4Foam 2.x release 0.2.3.tar.gz. I added the patch swakFixFor20x. I have (see below) after compiling Allwmake. My first question is: this folder doesn't need to be in the "run" directory right? I tried to implement my wave tank (I included "libOpenFOAM.so" and "libgroovyBC.so" in controlDict) and when I launch the application, it seems to be that OF can't find the librairies. Thank you for your help openfoam@openfoam-VirtualBox:~/OpenFOAM/openfoam-2.2.0/swak4Foam_2.x_release_0.2.1$ ./Allwmake No 'swakConfiguration'. Python etc won't work Checking swak4Foam-version and generating file Traceback (most recent call last): File "./maintainanceScripts/makeSwakVersionFile.py", line 8, in <module> output = Popen(["hg", "branch"], stdout=PIPE).communicate()[0] File "/usr/lib/python2.7/subprocess.py", line 679, in __init__ errread, errwrite) File "/usr/lib/python2.7/subprocess.py", line 1259, in _execute_child raise child_exception OSError: [Errno 2] No such file or directory Bison is version 2.5 Flex is version 2.5.35 (Minor version: 35) OpenFOAM-version: Major 2 Minor 2 Patch 0 No change to swak4FoamParsers/foamVersion4swak.H SOURCE=repositories/SetsRepository.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/sampling/lnInclude -I/opt/openfoam220/src/triSurface/lnInclude -I/opt/openfoam220/src/lagrangian/basic/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/SetsRepository.o In file included from repositories/SetsRepository.H:48:0, from repositories/SetsRepository.C:34: /opt/openfoam220/src/sampling/lnInclude/sampledSet.H:47:22: fatal error: coordSet.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/SetsRepository.o] Error 1 SOURCE=groovyBCFvPatchFields.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt -I/opt/openfoam220/src/finiteVolume/lnInclude -I../swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/groovyBCFvPatchFields.o In file included from groovyBCFvPatchField.H:48:0, from groovyBCFvPatchFields.H:37, from groovyBCFvPatchFields.C:36: ../swak4FoamParsers/lnInclude/PatchValueExpressionDriver.H:60:45: fatal error: PatchValueExpressionParser.tab.hh: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/groovyBCFvPatchFields.o] Error 1 SOURCE=manipulateField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I../swak4FoamParsers/lnInclude -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -I/opt/openfoam220/src/sampling/lnInclude -I/opt/openfoam220/src/triSurface/lnInclude -I/opt/openfoam220/src//postProcessing/functionObjects/utilities/lnInclude -I/opt/openfoam220/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/manipulateField.o In file included from manipulateField.C:30:0: ../swak4FoamParsers/lnInclude/FieldValueExpressionDriver.H:19:45: fatal error: FieldValueExpressionParser.tab.hh: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/manipulateField.o] Error 1 SOURCE=patch/patchAverageFunctionObject/patchAverageFunctionObject.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -I/opt/openfoam220/src/sampling/lnInclude -I/opt/openfoam220/src/triSurface/lnInclude -I/opt/openfoam220/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam220/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/openfoam220/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam220/src/thermophysicalModels/SLGThermo/lnInclude -I/opt/openfoam220/src/thermophysicalModels/properties/solidMixtureProperties/lnInclude -I/opt/openfoam220/src/thermophysicalModels/properties/liquidMixtureProperties/lnInclude -I/opt/openfoam220/src/thermophysicalModels/properties/solidProperties/lnInclude -I/opt/openfoam220/src/thermophysicalModels/properties/liquidProperties/lnInclude -I/opt/openfoam220/src/regionModels/regionModel/lnInclude -I/opt/openfoam220/src/regionModels/surfaceFilmModels/lnInclude -I/opt/openfoam220/src/turbulenceModels -I/opt/openfoam220/src/transportModels -I/opt/openfoam220/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/patchAverageFunctionObject.o In file included from lnInclude/simpleFunctionObject.H:40:0, from lnInclude/simpleDataFunctionObject.H:40, from lnInclude/timelineFunctionObject.H:40, from lnInclude/patchFunctionObject.H:40, from lnInclude/patchFieldFunctionObject.H:40, from patch/patchAverageFunctionObject/patchAverageFunctionObject.H:40, from patch/patchAverageFunctionObject/patchAverageFunctionObject.C:28: /opt/openfoam220/src/OpenFOAM/lnInclude/functionObject.H: In instantiation of ‘static Foam::autoPtr<Foam::functionObject> Foam::functionObject::adddictionaryConstructorToTa ble<functionObjectType>::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&) [with functionObjectType = Foam:atchAverageFunctionObject]’: /opt/openfoam220/src/OpenFOAM/lnInclude/functionObject.H:86:9: required from ‘Foam::functionObject::adddictionaryConstructorToT able<functionObjectType>::adddictionaryConstructor ToTable(const Foam::word&) [with functionObjectType = Foam:atchAverageFunctionObject]’ patch/patchAverageFunctionObject/patchAverageFunctionObject.C:44:1: required from here /opt/openfoam220/src/OpenFOAM/lnInclude/functionObject.H:86:9: error: cannot allocate an object of abstract type ‘Foam:atchAverageFunctionObject’ In file included from patch/patchAverageFunctionObject/patchAverageFunctionObject.C:28:0: patch/patchAverageFunctionObject/patchAverageFunctionObject.H:51:7: note: because the following virtual functions are pure within ‘Foam:atchAverageFunctionObject’: In file included from lnInclude/simpleFunctionObject.H:40:0, from lnInclude/simpleDataFunctionObject.H:40, from lnInclude/timelineFunctionObject.H:40, from lnInclude/patchFunctionObject.H:40, from lnInclude/patchFieldFunctionObject.H:40, from patch/patchAverageFunctionObject/patchAverageFunctionObject.H:40, from patch/patchAverageFunctionObject/patchAverageFunctionObject.C:28: /opt/openfoam220/src/OpenFOAM/lnInclude/functionObject.H:164:22: note: virtual void Foam::functionObject::updateMesh(const Foam::mapPolyMesh&) /opt/openfoam220/src/OpenFOAM/lnInclude/functionObject.H:167:22: note: virtual void Foam::functionObject::movePoints(const Foam:olyMesh&) /opt/openfoam220/src/OpenFOAM/lnInclude/functionObject.H: In static member function ‘static Foam::autoPtr<Foam::functionObject> Foam::functionObject::adddictionaryConstructorToTa ble<functionObjectType>::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&) [with functionObjectType = Foam:atchAverageFunctionObject]’: /opt/openfoam220/src/OpenFOAM/lnInclude/functionObject.H:86:9: warning: control reaches end of non-void function [-Wreturn-type] make: *** [Make/linux64GccDPOpt/patchAverageFunctionObject.o] Error 1 SOURCE=EvolveSolidParticleCloudFunctionObject.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -I/opt/openfoam220/src/sampling/lnInclude -I/opt/openfoam220/src/triSurface/lnInclude -I/opt/openfoam220 [...] |
April 18, 2013, 12:06 |
#2 | ||||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
So everything points to: you may have downloaded the right release, but compiled the wrong one
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
April 18, 2013, 12:28 |
Cathelain
Rep Power: 13 |
Ok, thank you! I dont know where I found this release... but anyway, now I compiled the good one (2.3), I still have some errors:
openfoam@openfoam-VirtualBox:~/OpenFOAM/openfoam-2.2.0/Swak4Foam_2.x_release_0.2.3$ ./Allwmake No 'swakConfiguration'. Python etc won't work Checking swak4Foam-version and generating file Bison is version 2.5 Flex is version 2.5.35 (Minor version: 35) OpenFOAM-version: Major 2 Minor 2 Patch 0 (-1 == x) No swak4FoamParsers/foamVersion4swak.H. Generated wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file helpers/printSwakVersion.C Making dependency list for source file repositories/SurfacesRepository.C Making dependency list for source file repositories/MeshesRepository.C Making dependency list for source file repositories/SetsRepository.C Making dependency list for source file repositories/GlobalVariablesRepository.C Making dependency list for source file namedEnums/MeshInterpolationOrder.C Making dependency list for source file namedEnums/LogicalAccumulationNamedEnum.C Making dependency list for source file namedEnums/NumericAccumulationNamedEnum.C Making dependency list for source file ExpressionDriverWriter.C Making dependency list for source file ExpressionResult/ExpressionResult.C Making dependency list for source file ExpressionResult/StoredExpressionResult.C Making dependency list for source file ExpressionResult/DelayedExpressionResult.C Making dependency list for source file setsAndSurfaces/swakRegistryProxySurface.C Making dependency list for source file setsAndSurfaces/swakRegistryProxySet.C Making dependency list for source file FieldValueExpressionParser.yy could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionParser.yy could not open file directMappedFvPatch.H for source file FieldValueExpressionParser.yy could not open file directMappedWallFvPatch.H for source file FieldValueExpressionParser.yy could not open file directMappedPointPatch.H for source file FieldValueExpressionParser.yy could not open file FixedValuePointPatchField.H for source file FieldValueExpressionParser.yy could not open file ZeroGradientPointPatchField.H for source file FieldValueExpressionParser.yy could not open file CalculatedPointPatchField.H for source file FieldValueExpressionParser.yy Making dependency list for source file PatchValueExpressionParser.yy could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionParser.yy could not open file directMappedPatchBase.H for source file PatchValueExpressionParser.yy Making dependency list for source file SubsetValueExpressionParser.yy could not open file SubsetValueExpressionParser.tab.hh for source file SubsetValueExpressionParser.yy Making dependency list for source file CommonValueExpressionDriver.C Making dependency list for source file makeSwakDataEntry.C Making dependency list for source file FieldValueExpressionLexer.ll could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionLexer.ll could not open file directMappedFvPatch.H for source file FieldValueExpressionLexer.ll could not open file directMappedWallFvPatch.H for source file FieldValueExpressionLexer.ll could not open file directMappedPointPatch.H for source file FieldValueExpressionLexer.ll could not open file FixedValuePointPatchField.H for source file FieldValueExpressionLexer.ll could not open file ZeroGradientPointPatchField.H for source file FieldValueExpressionLexer.ll could not open file CalculatedPointPatchField.H for source file FieldValueExpressionLexer.ll Making dependency list for source file FieldValueExpressionDriver.C could not open file FieldValueExpressionParser.tab.hh for source file FieldValueExpressionDriver.C could not open file directMappedFvPatch.H for source file FieldValueExpressionDriver.C could not open file directMappedWallFvPatch.H for source file FieldValueExpressionDriver.C could not open file directMappedPointPatch.H for source file FieldValueExpressionDriver.C could not open file FixedValuePointPatchField.H for source file FieldValueExpressionDriver.C could not open file ZeroGradientPointPatchField.H for source file FieldValueExpressionDriver.C could not open file CalculatedPointPatchField.H for source file FieldValueExpressionDriver.C Making dependency list for source file PatchValueExpressionLexer.ll could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionLexer.ll could not open file directMappedPatchBase.H for source file PatchValueExpressionLexer.ll Making dependency list for source file PatchValueExpressionDriver.C could not open file PatchValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C could not open file directMappedPatchBase.H for source file PatchValueExpressionDriver.C could not open file FieldValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C could not open file directMappedFvPatch.H for source file PatchValueExpressionDriver.C could not open file directMappedWallFvPatch.H for source file PatchValueExpressionDriver.C could not open file directMappedPointPatch.H for source file PatchValueExpressionDriver.C could not open file FixedValuePointPatchField.H for source file PatchValueExpressionDriver.C could not open file ZeroGradientPointPatchField.H for source file PatchValueExpressionDriver.C could not open file CalculatedPointPatchField.H for source file PatchValueExpressionDriver.C could not open file SubsetValueExpressionParser.tab.hh for source file PatchValueExpressionDriver.C Making dependency list for source file SubsetValueExpressionLexer.ll could not open file SubsetValueExpressionParser.tab.hh for source file SubsetValueExpressionLexer.ll Making dependency list for source file SubsetValueExpressionDriver.C could not open file SubsetValueExpressionParser.tab.hh for source file SubsetValueExpressionDriver.C Making dependency list for source file SetSubsetValueExpressionDriver.C could not open file SubsetValueExpressionParser.tab.hh for source file SetSubsetValueExpressionDriver.C Making dependency list for source file CellSetValueExpressionDriver.C could not open file SubsetValueExpressionParser.tab.hh for source file CellSetValueExpressionDriver.C Making dependency list for source file FaceSetValueExpressionDriver.C could not open file SubsetValueExpressionParser.tab.hh for source file FaceSetValueExpressionDriver.C Making dependency list for source file CellZoneValueExpressionDriver.C could not open file SubsetValueExpressionParser.tab.hh for source file CellZoneValueExpressionDriver.C Making dependency list for source file FaceZoneValueExpressionDriver.C could not open file SubsetValueExpressionParser.tab.hh for source file FaceZoneValueExpressionDriver.C Making dependency list for source file SampledSurfaceValueExpressionDriver.C could not open file SubsetValueExpressionParser.tab.hh for source file SampledSurfaceValueExpressionDriver.C Making dependency list for source file SampledSetValueExpressionDriver.C could not open file SubsetValueExpressionParser.tab.hh for source file SampledSetValueExpressionDriver.C Making dependency list for source file initSwakFunctionObject.C Making dependency list for source file plugins/CommonPluginFunction.C Making dependency list for source file plugins/FieldValuePluginFunction.C could not open file FieldValueExpressionParser.tab.hh for source file plugins/FieldValuePluginFunction.C could not open file directMappedFvPatch.H for source file plugins/FieldValuePluginFunction.C could not open file directMappedWallFvPatch.H for source file plugins/FieldValuePluginFunction.C could not open file directMappedPointPatch.H for source file plugins/FieldValuePluginFunction.C could not open file FixedValuePointPatchField.H for source file plugins/FieldValuePluginFunction.C could not open file ZeroGradientPointPatchField.H for source file plugins/FieldValuePluginFunction.C could not open file CalculatedPointPatchField.H for source file plugins/FieldValuePluginFunction.C Making dependency list for source file plugins/PatchValuePluginFunction.C could not open file PatchValueExpressionParser.tab.hh for source file plugins/PatchValuePluginFunction.C could not open file directMappedPatchBase.H for source file plugins/PatchValuePluginFunction.C Making dependency list for source file plugins/CellSetValuePluginFunction.C could not open file SubsetValueExpressionParser.tab.hh for source file plugins/CellSetValuePluginFunction.C Making dependency list for source file plugins/CellZoneValuePluginFunction.C could not open file SubsetValueExpressionParser.tab.hh for source file plugins/CellZoneValuePluginFunction.C Making dependency list for source file plugins/FaceSetValuePluginFunction.C could not open file SubsetValueExpressionParser.tab.hh for source file plugins/FaceSetValuePluginFunction.C Making dependency list for source file plugins/FaceZoneValuePluginFunction.C could not open file SubsetValueExpressionParser.tab.hh for source file plugins/FaceZoneValuePluginFunction.C Making dependency list for source file plugins/SampledSetValuePluginFunction.C could not open file SubsetValueExpressionParser.tab.hh for source file plugins/SampledSetValuePluginFunction.C Making dependency list for source file plugins/SampledSurfaceValuePluginFunction.C could not open file SubsetValueExpressionParser.tab.hh for source file plugins/SampledSurfaceValuePluginFunction.C SOURCE=helpers/printSwakVersion.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/sampling/lnInclude -I/opt/openfoam220/src/fileFormats/lnInclude -I/opt/openfoam220/src/triSurface/lnInclude -I/opt/openfoam220/src/surfMesh/lnInclude -I/opt/openfoam220/src/lagrangian/basic/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/printSwakVersion.o SOURCE=repositories/SurfacesRepository.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/sampling/lnInclude -I/opt/openfoam220/src/fileFormats/lnInclude -I/opt/openfoam220/src/triSurface/lnInclude -I/opt/openfoam220/src/surfMesh/lnInclude -I/opt/openfoam220/src/lagrangian/basic/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/SurfacesRepository.o SOURCE=repositories/MeshesRepository.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPOpt -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/sampling/lnInclude -I/opt/openfoam220/src/fileFormats/lnInclude -I/opt/openfoam220/src/triSurface/lnInclude -I/opt/openfoam220/src/surfMesh/lnInclude -I/opt/openfoam220/src/lagrangian/basic/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/MeshesRepository.o repositories/MeshesRepository.C: In member function ‘Foam::scalar Foam::MeshesRepository::setTime(const Foam::word&, Foam::scalar, Foam::label)’: repositories/MeshesRepository.C:299:59: error: no matching function for call to ‘Foam::HashTable<Foam::regIOobject*>::HashTable(Fo am::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>)’ repositories/MeshesRepository.C:299:59: note: candidates are: In file included from /opt/openfoam220/src/OpenFOAM/lnInclude/HashTable.H:555:0, from /opt/openfoam220/src/OpenFOAM/lnInclude/HashPtrTable.H:39, from /opt/openfoam220/src/OpenFOAM/lnInclude/PtrMap.H:38, from repositories/MeshesRepository.H:50, from repositories/MeshesRepository.C:37: /opt/openfoam220/src/OpenFOAM/lnInclude/HashTable.C:79:1: note: Foam::HashTable<T, Key, Hash>::HashTable(const Foam::Xfer<Foam::HashTable<T, Key, Hash> >&) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash] /opt/openfoam220/src/OpenFOAM/lnInclude/HashTable.C:79:1: note: no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘const Foam::Xfer<Foam::HashTable<Foam::regIOobject*> >&’ /opt/openfoam220/src/OpenFOAM/lnInclude/HashTable.C:55:1: note: Foam::HashTable<T, Key, Hash>::HashTable(const Foam::HashTable<T, Key, Hash>&) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash] /opt/openfoam220/src/OpenFOAM/lnInclude/HashTable.C:55:1: note: no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘const Foam::HashTable<Foam::regIOobject*>&’ In file included from /opt/openfoam220/src/OpenFOAM/lnInclude/HashTable.C:612:0, from /opt/openfoam220/src/OpenFOAM/lnInclude/HashTable.H:555, from /opt/openfoam220/src/OpenFOAM/lnInclude/HashPtrTable.H:39, from /opt/openfoam220/src/OpenFOAM/lnInclude/PtrMap.H:38, from repositories/MeshesRepository.H:50, from repositories/MeshesRepository.C:37: /opt/openfoam220/src/OpenFOAM/lnInclude/HashTableIO.C:33:1: note: Foam::HashTable<T, Key, Hash>::HashTable(Foam::Istream&, Foam::label) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash; Foam::label = int] /opt/openfoam220/src/OpenFOAM/lnInclude/HashTableIO.C:33:1: note: no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘Foam::Istream&’ In file included from /opt/openfoam220/src/OpenFOAM/lnInclude/HashTable.H:555:0, from /opt/openfoam220/src/OpenFOAM/lnInclude/HashPtrTable.H:39, from /opt/openfoam220/src/OpenFOAM/lnInclude/PtrMap.H:38, from repositories/MeshesRepository.H:50, from repositories/MeshesRepository.C:37: /opt/openfoam220/src/OpenFOAM/lnInclude/HashTable.C:35:1: note: Foam::HashTable<T, Key, Hash>::HashTable(Foam::label) [with T = Foam::regIOobject*; Key = Foam::word; Hash = Foam::string::hash; Foam::label = int] /opt/openfoam220/src/OpenFOAM/lnInclude/HashTable.C:35:1: note: no known conversion for argument 1 from ‘Foam::HashTable<const Foam::regIOobject*, Foam::word, Foam::string::hash>’ to ‘Foam::label {aka int}’ make: *** [Make/linux64GccDPOpt/MeshesRepository.o] Error 1 Parser library did not compile OK. No sense continuing as everything else depends on it Requirements for Library not satisfied. I see no sense in going on |
April 18, 2013, 14:58 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
http://www.cfd-online.com/Forums/ope...tml#post415028
April 19, 2013, 05:59 |
Cathelain
Rep Power: 13 |
Thank you very much! I couldn't run the examples given for groovyBC but I ran my own case and it seems to work!
April 19, 2013, 08:40 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Which cases gave you problems?
April 19, 2013, 09:26 |
Cathelain
Rep Power: 13 |
I've tried the pulsedPitzDaily in the groovyBC folder. I think that's because I didn't compile the oodles solver. But groovyBC works in my case, I didn't have any errors and I have nice waves.
Thank you |
April 19, 2013, 09:42 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The functionality of oodles is now part of pisoFoam. Does it still say oodles in the 2.x-README? Thanks for the hint. I'll fix it
April 19, 2013, 10:18 |
#9 |
Cathelain
Rep Power: 13 |
You mean in the README file in the swak4Foam release folder?
I didn't find it. But I did find : **** pulsedPitzDaily solver :: pisoFoam So I've just changed "oodles" into "pisoFoam" and run the case: openfoam@openfoam-VirtualBox:~/OpenFOAM/openfoam-2.2.0/run/pulsedPitzDaily$ pisoFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0-b363e8d14789 Exec : pisoFoam Date : Apr 19 2013 Time : 14:12:08 Host : "openfoam-VirtualBox" PID : 18435 Case : /home/openfoam/OpenFOAM/openfoam-2.2.0/run/pulsedPitzDaily nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libswakPythonIntegration.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable:pen(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libswakPythonIntegration.so" Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type LESModel Selecting LES turbulence model oneEqEddy Selecting LES delta type cubeRootVol --> FOAM Warning : From function cubeRootVolDelta::calcDelta() in file cubeRootVolDelta/cubeRootVolDelta.C at line 52 Case is 2D, LES is not strictly applicable bounding k, min: 0 max: 2e-05 average: 2e-05 oneEqEddyCoeffs { ck 0.07; ce 1.05; } Starting time loop DICPCG: Solving for distance, Initial residual = 1, Final residual = 9.97476e-07, No Iterations 227 DICPCG: Solving for distance, Initial residual = 5.26588e-09, Final residual = 5.26588e-09, No Iterations 0 DICPCG: Solving for distance, Initial residual = 5.26588e-09, Final residual = 5.26588e-09, No Iterations 0 Reading/calculating field UMean Reading/calculating field pMean Reading/calculating field UPrime2Mean Reading/calculating field pPrime2Mean fieldAverage: starting averaging at time 0 Creating expression field kineticEnergy ...swak4Foam: Allocating new repository for sampledMeshes swak4Foam: Allocating new repository for sampledGlobalVariables type:volScalarField phi: phi Compressible: 0 Turbulent: 1 LES: 1 Manipulated field k in 350 cells with the expression "1e-5" swak4Foam: Setting default mesh Creating expression field turbulenceR ... "Loaded plugin functions for 'FieldValueExpressionDriver':" trans_nu: "volScalarField trans_nu()" turb_R: "volSymmTensorField turb_R()" turb_devReff: "volSymmTensorField turb_devReff()" turb_epsilon: "volScalarField turb_epsilon()" turb_k: "volScalarField turb_k()" turb_nuEff: "volScalarField turb_nuEff()" turb_nut: "volScalarField turb_nut()" type:volSymmTensorField Checking for field U in range [ -10 , 40 ] --> FOAM FATAL ERROR: Unknown function type executeIfPython Valid functions are : 77 ( CourantNo DESModelRegions Lambda2 Peclet Q addForeignMeshes addGlobalVariable calculateGlobalVariables cellSource clearExpressionField coded createSampledSet createSampledSurface dsmcFields dumpSwakExpression dynamicFunctionObjectListProxy executeIfEnvironmentVariable executeIfExecutableFits executeIfFunctionObjectPresent executeIfObjectExists executeIfSwakExpression expressionField faceSource fieldAverage fieldCoordinateSystemTransform fieldMinMax fieldValueDelta foreignMeshesFollowTime functionObjectListProxy initSwakFunctionObject loadCompressibleTurbulenceModel loadIncompressibleTurbulenceModel loadPsiThermoModel loadRhoThermoModel loadSLGThermoModel manipulateField manipulatePatchField nearWallFields panicDump patchAverage patchExpression patchFieldFlow patchIntegrate patchMassFlow patchMassFlowAverage patchProbes pressureTools probes processorField readAndUpdateFields readFields readGravitation regionSizeDistribution scalarTransport setDeltaTByTimeline sets solveLaplacianPDE solveTransportPDE streamLine surfaceInterpolateFields surfaces swakCoded swakExpression timeActivatedFileUpdate trackDictionary turbulenceFields volumeAverage volumeIntegrate volumeMinMax wallBoundedStreamLine wallShearStress writeAdditionalFields writeAndEndFieldRange writeAndEndSwakExpression writeFieldsOften yPlusLES yPlusRAS ) From function functionObject::New(const word& name, const Time&, const dictionary&) in file db/functionObjects/functionObject/functionObject.C at line 92. FOAM exiting |
April 19, 2013, 11:47 |
#10 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
April 22, 2013, 06:25 |
#11 |
Cathelain
Rep Power: 13 |
With this fix, it works now. Thank you
April 23, 2013, 07:11 |
#12 |
Cathelain
Rep Power: 13 |
Hello again!
So, I have been running my case of a 2d-order Stokes wave propagating into a tank. The simulation crashed and at the beginning I thought that the crash was due to the reflection of the waves on the outlet. After some time, the quality of the free surface becomes really bad. When I increase the length of the tank, the simulation runs longer. But today the simulation crashed and a window popped up (see below). Does this mean that my simulation crashes for another reason (linked to these libraries)? How can I check if everything is okay? "The crashed program seems to use third-party or local libraries: /home/openfoam/OpenFOAM/openfoam-2.2.0/platforms/linux64GccDPOpt/lib/libgroovyBC.so /home/openfoam/OpenFOAM/openfoam-2.2.0/platforms/linux64GccDPOpt/lib/libswak4FoamParsers.so /home/openfoam/OpenFOAM/openfoam-2.2.0/platforms/linux64GccDPOpt/lib/libswakFunctionObjects.so /home/openfoam/OpenFOAM/openfoam-2.2.0/platforms/linux64GccDPOpt/lib/libsimpleSwakFunctionObjects.so /home/openfoam/OpenFOAM/openfoam-2.2.0/platforms/linux64GccDPOpt/lib/libsimpleFunctionObjects.so It is highly recommended to check if the problem persists without those first. Do you want to continue the report process anyway?" |
April 23, 2013, 08:41 |
#13 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The message may or may not indicate that there is a problem with swak. What this message translates to is "We found some library in memory that is not by us. This gives us a good reason to pretend it is not our fault. Good luck reproducing the error without this" In general I'd say that the problem is not swak per se (I mean the case starts running) but the physics implemented with it. And if that is the case you'll have a hard time reproducing the problem without it. If it takes not too long to get to the crash I'd recommend writing out all timesteps and have a look when and where the surface "explodes" BTW: don't you think that this is the wrong thread? Don't think that this is a "build problem"
April 23, 2013, 09:40 |
#14 |
Cathelain
Rep Power: 13 |
Okay, I just wanted to know about this window because usually when it crashes, it remains in the terminal so I thought that it was something "more serious".
I'm using OpenFoam on Ubuntu 12.10 on a virtual machine, this window looked like a "Ubuntu" window. But it just popped up once. Thank you |
April 23, 2013, 14:59 |
#15 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
groovybc, swak4foam |
[swak4Foam] Problem with swak4Foam and OpenFOAM 2.3.1 | behzad-cfd | OpenFOAM Community Contributions | 4 | March 25, 2017 17:19 |
[swak4Foam] Problem with triSurface.so and swak4Foam | PieterjanR | OpenFOAM Community Contributions | 2 | November 21, 2016 10:54 |
OpenFOAM gcc configuration problem | preacher | OpenFOAM Installation | 7 | March 3, 2014 23:44 |
[swak4Foam] problem on installing swak4Foam | navid2 | OpenFOAM Community Contributions | 2 | May 30, 2012 05:32 |
Build problem | Jeff | CFX | 0 | July 31, 2003 14:21 |
