[Other] HexBlocker a GUI for blockMeshDict, alpha release
Like Tree52Likes
Old   September 19, 2018, 08:57
Ekscel is on a distinguished road
Hi Wulonglong,
I didn't succeeded with newest Ubuntu 18.04, but I solved the problem by installing Ubuntu 16.04 LTS and using VTK 6.3.0 directly as it is used in the install script.
Ekscel is offline   Reply With Quote
Old   September 20, 2018, 06:29
wulonglong
wulonglong is on a distinguished road
Hi Ekscel,
My Ubuntu version is also 16.04 LTS and I am using OpenFoam-ext4.0 (Can Hexblocker install in extend version?)
Also I tried to install in OpenFoam5 but it failed again..
My OpenFoam5 is pure, it doesn't run any case yet.
Did you modify any thing ?
or just following the code in #1 ? (I run the code step by step.)
Best Regards
Wu
wulonglong is offline   Reply With Quote
Old   October 1, 2018, 07:59
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
this is not a problem related to the application of Nicola, it is related to your system. As I don´t have the issue, please search for:
Could not find a package configuration file provided by "VTK" with any of
  the following names
And you probably will find the answer on stackexchange.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   October 25, 2018, 12:16
christoph45 is on a distinguished road
Hi
I got the same error messages like Ekscel ...
I hope I can remember correctly, but this ist how I made it as an novice under ubuntu 16.04:
- clone git repo
- let install.sh download vtk & abort with error
- install everything that sound like qt4*; also libqtwebkit* (I don'tknow if this is really necessary, but after I did that, it worked..)
- ccmake in build/VTK/ with the options stated in install.sh
- make -j 4
- sudo make install
at this stage vtk seemed to be installed
rerun ./install.sh and it worked!
I'm not sure what I did differently than the script.... I tried lots of commands. I hope I could help someone here
regards
christoph45 is offline   Reply With Quote
Old   March 9, 2019, 04:40
sariew8
sariew is on a distinguished road
Hi Foamers!
i succeeded the installation of this, thus i'll introduce the point of the method.
first of all, three additional packages (gcc-, g++-4.8 and qt4-default) were installed in the present system,
and then gcc-4.8 (g++-4.8) were made update for default compiler.
secondly, the line 42 in hexBlocker/install.sh was edited the according below:
QMAKE=$(which qmake) to QMAKE=$(which qmake-qt4).
(Some users would change the L38 and L39 additionally).
finally, execute the shell script (./install.sh) for installation.
After a certain period time, all the installations would have been successful if the terminal echo the message 'exit 0'.
change the directory to hexBlocker/bin, then hit the following command:
$ ./HexBlocker
but the terminal echos the according below:
./HexBlocker: error while loading shared libraries: libvtkRenderingVolume-6.3.so.1: cannot open shared object file: No such file or directory.
This linker error will be understood with the following command:
$ ldd HexBlocker
some libraries are not found in the present environment.
so I corresponded to this error by adding link path and alias to $HOME/.bashr.
best of luck!
(my system: ubuntu18.04, gcc-4.8, of41, of1812)
sariew is offline   Reply With Quote
Old   July 15, 2019, 23:30
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
I am trying to install hexBlocker on,
Ubunu -18.04.1
gcc version 7.4.0 (I know hexblocker needs gcc-4.8)
I am facing the same installation problem,
I tried to follow the steps given by, Sariew. Still its not working.
+ echo 'error in cmake for hexBlocker'
+ exit 1
+ make -j 4
make: *** No targets specified and no makefile found. Stop.
+ echo 'error in make for hexBlocker'
+ exit 1
+ make install
make: *** No rule to make target 'install'. Stop.
+ exit 0
Could you please help me to solve the problem?
Thanks,
Sivakumar
sivakumar is offline   Reply With Quote
Old   September 7, 2019, 23:24
sariew8
Originally Posted by sivakumar View Post
Ubunu -18.04.1
+ exit 1
+ make -j 4
+ exit 1
+ make install
+ exit 0
Thanks,
Sivakumar
hi Sivakumar!!
did you change gcc to ver. 4.8?
my compilers are ...
$ gcc --version
gcc (Ubuntu 4.8.5-4ubuntu8) 4.8.5
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
$ g++ --version
g++ (Ubuntu 4.8.5-4ubuntu8) 4.8.5
blockmesh, gui, mesh, pre-processing
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 10:23
New CastNet Release: GUI Environment for OpenFOAM and CalculiX MartinB OpenFOAM Announcements from Other Sources 0 January 13, 2017 11:27
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
New CastNet release: GUI environment for OpenFOAM® ulli OpenFOAM Announcements from Other Sources 1 July 31, 2013 07:25
Openfoam Ubuntu 12.04 Unmet dependencies slls33 OpenFOAM Installation 10 April 9, 2013 05:16
