[swak4Foam] piecewise linear inlet profile: swak4foam?
Old   March 9, 2013, 11:33
Default piecewise linear inlet profile: swak4foam?
Marcus Letzel
letzel is on a distinguished road
Dear All,
my current task is the initialization of the streamwise velocity component Ux both at the inlet patch and for the internalField.
Input data is an atmospheric boundary layer profile of Ux measured at discrete heights above ground by a wind tunnel experiment. Uy and Uz are zero.
From the discrete measurements I would like to construct a piecewise linear vertical profile of Ux. At present, the input data are stored in a data file with the following content
0.0  0.00
2.0  1.12
5.0  1.36
10.0 1.56
15.0 1.68
20.0 1.78
30.0 1.92
40.0 2.02
where the first column is the height in m above ground and the second column is the streamwise velocity component Ux in m/s.
Which is the best way to input this piecewise linear profile into OpenFoam? Is there a clever way to use swak4foam for this task?
Best regards,
Marcus
letzel is offline   Reply With Quote
Old   March 9, 2013, 12:52
Assistant Moderator
Bernhard Gschaider
Originally Posted by letzel View Post
Dear All,
0.0  0.00
2.0  1.12
5.0  1.36
10.0 1.56
15.0 1.68
20.0 1.78
30.0 1.92
40.0 2.02
Best regards,
Marcus
If it was in time you could use timeVaryingUniform from standard-OpenFOAM. But swak4Foam has something based on that technology: lookuptables. For instance you declare a lookuptable heightData which you can then use in an expression like this "vector(heightData(pos().z),0,0)"
See the case Examples/groovyBC/wobbler on how to declare the lookuptable and the format of the data-file
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 24, 2014, 12:39
Tobias Adam
Tobias Adam is on a distinguished road
Is there a possibility to use a standard atmospheric layer for the inlet?
Right now I donīt know the exact inflow conditions except for the maximal velocity = 6 and minimal velocity =0 at the ground, so I don want to use this table function...
Best regards Tobi
Tobias Adam is offline   Reply With Quote
Old   July 2, 2014, 18:49
Assistant Moderator
Bernhard Gschaider
Best regards Tobi
What do you mean with "standard atmospheric layer"?
Old   July 3, 2014, 06:32
Tobias Adam
I guess standard atmospheric layer was the wrong word.
I wanted to ask for a realistic inflow condition, with changing velocity depending on the height. I thought about a parabolic velocity function depending on the height, but did not find good examples or parameters.
My problem is, I donīt know much about the roughness of the area in front of my simulated area. so I wanted to ask for some standard values or functions to create such an inflow condition with no-slip-condition for the ground.
Best regards Tobi
Old   July 3, 2014, 16:43
Assistant Moderator
Bernhard Gschaider
Best regards Tobi
Finding a good relation for the flow is your responsibility. swak only helps you implementing it. For an example see Examples/groovyBC/pulsedPitzDaily
experimental data, inlet profile, internalfield, swak4foam
Disappearing mass when using udf inlet profile divergence Fluent UDF and Scheme Programming 5 January 2, 2021 15:56
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 07:45
map outlet boundary profile as an inlet condition using UDF Daniel_Khazaei Fluent UDF and Scheme Programming 2 June 20, 2016 12:53
simpleFoam: Non-uniform mesh near inlet & outlet causes incorrect velocity profile? Zaphod'sSecondHead OpenFOAM Running, Solving & CFD 0 January 28, 2015 06:17
extracting outlet velocity profile from one case to another case's inlet tonggysun OpenFOAM 2 September 13, 2013 05:19
