[swak4Foam] setFields or funkySetFields with STL file? |
February 21, 2013, 05:52 |
Vincent RIVOLA
Rep Power: 18 |
Dear all,
Is it possible to use an STL file in order to assign some value to the pressure field for example for points which are inside one closed shape described by an STL file? If yes, how should I proceed? Thanks |
February 21, 2013, 12:29 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
It is somewhere on my "cool things that I implement once I need them"-list
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 18:25 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
