March 27, 2018, 04:56 |
#141 |
Peter
Rep Power: 10 |
Thanks a lot!
I tried with version 1712 - and it works. Very nice tool! |
December 20, 2018, 23:10 |
FieldValueExpressionParser
#142 |
Elham
Rep Power: 16 |
I have an installed version of OpenFoam-2.3.0 on supercomputer. I have the following error while tried to install swak4Foam Code:
No file 'swakConfiguration'. Python etc won't work. See README for details Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems Checking swak4Foam-version and generating file Swak version is 0.4.1 Bison is version 2.7.12-4996 Flex is version 2.5.37 (Minor version: 37) OpenFOAM-version: Major 2 Minor 3 Patch 0 (-1 == x / 0) Fork: openfoam No change to swak4FoamParsers/foamVersion4swak.H SOURCE=FieldValueExpressionParser.yy ; rm -f Make/crayxcGccDPOpt/FieldValueExpressionParser.C Make/crayxcGccDPOpt/FieldValueExpressionParser.tab.hh; mkdir $$; cd $$; [ -n "" ] && sleep 30; bison -ra -v -d ../$SOURCE ; mv *.tab.cc ../Make/crayxcGccDPOpt/FieldValueExpressionParser.C ; sed -i.bak "s/position.hh/FieldValueExpressionParser_position.hh/" location.hh ; mv location.hh ../lnInclude/FieldValueExpressionParser_location.hh ; mv stack.hh ../lnInclude/FieldValueExpressionParser_stack.hh ; mv position.hh ../lnInclude/FieldValueExpressionParser_position.hh ; sed -i.bak "s/stack.hh/FieldValueExpressionParser_stack.hh/;s/location.hh/FieldValueExpressionParser_location.hh/" FieldValueExpressionParser.tab.hh ;mv *.hh ../lnInclude ; touch -r ../$SOURCE ../lnInclude/FieldValueExpressionParser*.hh ; cd ..; rm -r $$; if [ -z "" ]; then echo -e "\n\nIf compilation of the grammers takes prohibitivly long set SWAK_COMPILE_GRAMMAR_OPTION to something like -O1\n\n" ; fi; CC -Dcrayxc -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wno-unused-local-typedefs -O3 -DNoRepository -ftemplate-depth-100 -IMake/crayxcGccDPOpt -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/surfMesh/lnInclude -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/sampling/lnInclude -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/fileFormats/lnInclude -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/triSurface/lnInclude -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/dynamicMesh/lnInclude -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/lagrangian/basic/lnInclude -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/surfMesh/lnInclude -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/meshTools/lnInclude -IlnInclude -I. -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude -I/group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/OSspecific/POSIX/lnInclude -fPIC -c Make/crayxcGccDPOpt/FieldValueExpressionParser.C -o Make/crayxcGccDPOpt/FieldValueExpressionParser.o If compilation of the grammers takes prohibitivly long set SWAK_COMPILE_GRAMMAR_OPTION to something like -O1 In file included from /group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/DimensionedField.H:342:0, from /group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricField.H:44, from /group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricScalarField.H:38, from /group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricFields.H:34, from /group/director2080/emohammadi/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/volFields.H:37, from ../FieldValueExpressionParser.yy:47: .... FieldValueExpressionParser.tab.cc: In member function 'parserField::FieldValueExpressionParser::token_number_type parserField::FieldValueExpressionParser::yytranslate_(int)': FieldValueExpressionParser.tab.cc:16827:24: warning: use of old-style cast [-Wold-style-cast] FieldValueExpressionParser.dep:644: recipe for target 'Make/crayxcGccDPOpt/FieldValueExpressionParser.o' failed make: *** [Make/crayxcGccDPOpt/FieldValueExpressionParser.o] Error 1 Parser library did not compile OK. No sense continuing as everything else depends on it The log file is attached. Thanks in advance for any help. Regards, Elham |
December 21, 2018, 05:57 |
#143 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I think the problem is that around the time of 2.3 the behaviour of "a & b" with a and b being symmetrical tensors changed. Your OpenFOAM-version says that the result is a general tensor while swak4Foam assumes that it will be a symmetrical tensors. The quickest solution would be to remove the offending rule from the grammar and hope that you never need it. Go to FieldValueExpressionParser.yy and line 3162 in that. The rule starts with a line starting with a pipe symbol ("|"). Remove the rule that the line is in (just all the lines until the next rule). In my experience 93.5% of all applications of swak4Foam don't involve tensor arithmetics so you might be fine
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
December 24, 2018, 21:51 |
#144 | |
Elham
Rep Power: 16 |
I have deleted the rule and try to compil;e but still have the same error. I have attached the FieldValueExpressionParser.yy file. I am wondering if I should remove some more rules since the other rules around are similar to the one that I removed. Thanks for your attention. Elham |
December 25, 2018, 14:47 |
#145 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
No. The other rules should be fine. Before trying anything else do ./Allwclean and recompile. Maybe the intermediate file from the grammar was not correctly produced/written Anyway: check the log if it is really exactly the same error BTW: the current develop-branch in the repository compiles with 2.3. But it uses the necessary workarounds
December 25, 2018, 14:53 |
#146 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Just checked my sources. The workaround is needed in 2 other places. So maybe ypur error message was similar but not the same (because it stumbled on those cases). Check the line in the error messages (look for the string "error:". Near that is the actual places it happened)
May 17, 2020, 11:24 |
#147 |
Divyesh Variya
Rep Power: 8 |
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam7/src/finiteVolume/lnInclude -I/opt/openfoam7/src/surfMesh/lnInclude -I/opt/openfoam7/src/sampling/lnInclude -I/opt/openfoam7/src/fileFormats/lnInclude -I/opt/openfoam7/src/triSurface/lnInclude -I/opt/openfoam7/src/dynamicMesh/lnInclude -I/opt/openfoam7/src/lagrangian/basic/lnInclude -I/opt/openfoam7/src/surfMesh/lnInclude -I/opt/openfoam7/src/meshTools/lnInclude -I../filesThatAreOnlyInSomeDistributions/OutputFilerDropin/ -IlnInclude -I. -I/opt/openfoam7/src/OpenFOAM/lnInclude -I/opt/openfoam7/src/OSspecific/POSIX/lnInclude -fPIC -c entryToExpression/dimensionedScalarEntryToExpression.C -o Make/linux64GccDPInt32Opt/entryToExpression/dimensionedScalarEntryToExpression.o entryToExpression/dimensionedScalarEntryToExpression.C: In member function ‘virtual Foam::string Foam::dimensionedScalarEntryToExpression::toExpr(const Foam::entry&)’: entryToExpression/dimensionedScalarEntryToExpression.C:65:27: error: binding reference of type ‘Foam::Istream&’ to ‘const Foam::Istream’ discards qualifiers dimensionedScalar val(pe); ^~ In file included from /opt/openfoam7/src/OpenFOAM/lnInclude/dimensionedType.H:344:0, from /opt/openfoam7/src/OpenFOAM/lnInclude/dimensionedScalar.H:38, from entryToExpression/dimensionedScalarEntryToExpression.C:36: /opt/openfoam7/src/OpenFOAM/lnInclude/dimensionedType.C:124:1: note: initializing argument 1 of ‘Foam::dimensioned<Type>::dimensioned(Foam::Istream&) [with Type = double]’ Foam::dimensioned<Type>::dimensioned ^~~~ /opt/openfoam7/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/entryToExpression/dimensionedScalarEntryToExpression.o' failed make: *** [Make/linux64GccDPInt32Opt/entryToExpression/dimensionedScalarEntryToExpression.o] Error 1 Parser library did not compile OK. No sense continuing as everything else depends on it Requirements for Library not satisfied. I see no sense in going on Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard I am trying to install swak4foam in openFOAMv7. Getting above error, can anyone help me? Thanks in Advance
Divyesh Variya |
May 17, 2020, 18:51 |
#148 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Which version of the sources is this? Currently only the development version supports OF7
May 23, 2020, 19:09 |
#149 | |
Hasan Celik
Rep Power: 10 |
Hello divyesh, maybe you can try like the way I explained here? It worked for me.
June 19, 2020, 15:56 |
OpenFOAM v1912 Ubuntu 20.04
#150 | |||
Kiran Sripathy
i am facing trouble in compiling swak4Foam for OpenFOAM v1912. I have tried the default, develop and p1912 branches in the mercurial repository with no success. One of the error messays state that: Quote:
And, the compilation stops at: Quote:
Best wishes, Kiran Sripathy. |
September 23, 2020, 01:33 |
Installation Errors of develop version on of7
#151 |
Yuke Li
Dear Sir/Madam,
This is Yuke. I've installed OpenFOAM 7 on my computer (Ubuntu 20.04.1 LTS). When I was installing swak4FOAM, an error keeps coming after wclean several times. I haven't found any solutions from the Internet. Please help me fix this. I followed the installation instruction, as in Folder: ~/OpenFOAM/yuke-7/ 1) hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam swak4Foam 2) cd swak4Foam && hg update develop 3) ./Allwmake > log.make 2>&1 4) ./Allwmake > log.make 2>&1 The attached is what was written in log.make profile. The first several lines of log profile is " Current OpenFOAM version is 7. Previously compiled for OpenFOAM (7) No file 'swakConfiguration'. Python etc won't work. See README for details Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems Checking swak4Foam-version and generating file Swak version is 20xx.yy.0 hg info: 58b9a1dfa14c (develop) tip No 'bear' installed Bison: /usr/bin/bison Flex: /usr/bin/flex Bison at /usr/bin/bison is version 3.5.1 (Major 3 Minor 5) Flex is version 2.6.4 (Minor version: 4) OpenFOAM-version: Major 7 Minor 0 Patch -1 (-1 == x / 98) Fork: org No change to swak4FoamParsers/foamVersion4swak.H Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem " Last several lines are " wmake funkySetAreaFields OpenFOAM.org version 7 OpenFOAM.org version 7 make[1]: Entering directory '/home/yuke/OpenFOAM/yuke-7/swak4Foam/Utilities/funkySetAreaFields' OpenFOAM.org version 7 g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam7/src/finiteVolume/lnInclude -I/opt/openfoam7/src/finiteArea/lnInclude -I/opt/openfoam7/src/meshTools/lnInclude -I/opt/openfoam7/src/sampling/lnInclude -I../../Libraries/swakFiniteArea/lnInclude/ -I../../Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/opt/openfoam7/src/OpenFOAM/lnInclude -I/opt/openfoam7/src/OSspecific/POSIX/lnInclude -fPIC -c funkySetAreaFields.C -o Make/linux64GccDPInt32Opt/funkySetAreaFields.o funkySetAreaFields.C:39:10: fatal error: faCFD.H: No such file or directory 39 | #include "faCFD.H" | ^~~~~~~~~ compilation terminated. make[1]: *** [/opt/openfoam7/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/funkySetAreaFields.o] Error 1 make[1]: Leaving directory '/home/yuke/OpenFOAM/yuke-7/swak4Foam/Utilities/funkySetAreaFields' make: *** [/opt/openfoam7/wmake/makefiles/apps:39: funkySetAreaFields] Error 2 If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /home/yuke/OpenFOAM/yuke-7/swak4Foam/Libraries (most people will be fine without setting that variable) " Thanks in advance. Best, Yuke |
September 24, 2020, 16:35 |
#152 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I think the only problem is that funkySetAreaField should not compile on your machine: it needs the finiteArea-stuff which only foam-extend and the ESI release have. So there is a problem in the compilation script that I have to fix (so that it doesn't try to compile the utility on OpenFOAM from CFD-direct) If there are no other problems then you should be fine
October 3, 2020, 10:27 |
#153 | |
Kiran Sripathy
Just wanted to remind that I am still facing this issue. I also tried compiling swak4FOAM for other versions of OpenFOAM - v1906, v2006, but the same issue persists. My operating system is ubuntu 20.04. swak4FOAM was running fine with OpenFOAM v1906 when I was using ubuntu 18.04 on my PC. Also, I didnt face any issues when I installed swak4FOAM and OpenFOAM v1906 last year on my university's cluster which has CentOS. Do I need to take extra precautions when I am compiling swak4FOAM on ubuntu 20.04? Or are there some other issues with my setup? Best wishes, Kiran Sripathy. |
January 11, 2021, 09:15 |
Install swak4Foam in OpenFOAM-v2012
#154 |
Vincy
Rep Power: 5 |
log.make:
Some scripts require a binary 'python' to be installed It doesn't matter if this is Python 2 or 3 This problem is caused by Linux distros that install 'python2' and/or 'python3' but no python On such distros usually a packages exists that links 'python' to one of those It's the latest version: OpenFOAM-v2012, and I install the swak4Foam development version, getting above error, can anyone help me? Thanks in Advance |
January 11, 2021, 11:08 |
#155 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The problem is not swak4Foam. The problem is your distro: usually Linux-distros have an executable "python" that points to either "python2" or "python3". The scripts in swak are written in such a way that they work with both of them. Ubuntu has decided in its newest version that there is no "python". Only "python2" and/or "python3" To fix that it has to be made sure that "python" points to one of the two. The ways to do that is
August 31, 2021, 18:28 |
#156 | |
alberto
Rep Power: 10 |
Could you solve it? |
December 26, 2021, 13:13 |
some scripts require binary python to be installed error while compiling swak4foam
#157 |
Thokala Divya
Rep Power: 4 |
please kindly help to resolve following error
chinni@LAPTOP-105VVDC2:~/OpenFOAM/OpenFOAM-v2012/applications/swak4Foam$ openfoam2012 Traceback (most recent call last): File "/usr/lib/command-not-found", line 28, in <module> from CommandNotFound import CommandNotFound File "/usr/lib/python3/dist-packages/CommandNotFound/CommandNotFound.py", line 19, in <module> from CommandNotFound.db.db import SqliteDatabase File "/usr/lib/python3/dist-packages/CommandNotFound/db/db.py", line 5, in <module> import apt_pkg ImportError: /home/chinni/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /lib/x86_64-linux-gnu/libapt-pkg.so.6.0) chinni@LAPTOP-105VVDC2:~/OpenFOAM/OpenFOAM-v2012/applications/swak4Foam$ ./AllwmakeAll This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-installation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work bison-3.4.tar.gz already downloaded Untarring bison-sources checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /usr/bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... no checking whether make supports nested variables... no checking whether make supports nested variables... (cached) no checking whether make supports the include directive... no checking for gcc... gcc checking whether the C compiler works... no configure: error: in `/home/chinni/OpenFOAM/OpenFOAM-v2012/applications/swak4Foam/privateRequirements/compilation/bison-3.4': configure: error: C compiler cannot create executables See `config.log' for more details ./maintainanceScripts/compileRequirements.sh: line 31: make: command not found ./maintainanceScripts/compileRequirements.sh: line 31: make: command not found Bison not compiled. Check output lua-5.3.5.tar.gz already downloaded Untarring lua-sources sed: can't read bak: No such file or directory sed: can't read bak: No such file or directory sed: can't read bak: No such file or directory ./maintainanceScripts/compileRequirements.sh: line 66: make: command not found ./maintainanceScripts/compileRequirements.sh: line 68: make: command not found If there were problems during compilation install the readline-devel package (name may be different on platforms) Lua not compiled. Check output Add /home/chinni/OpenFOAM/OpenFOAM-v2012/applications/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically Some scripts require a binary 'python' to be installed It doesn't matter if this is Python 2 or 3 This problem is caused by Linux distros that install 'python2' and/or 'python3' but no python On such distros usually a packages exists that links 'python' to one of those |
January 7, 2022, 00:54 |
Swak4Foam stopped compiling
#158 |
Thokala Divya
Rep Power: 4 |
I am using OpenFOAM v-2106. I am encountering the following problem while compiling swak4Foam. can anyone help me in doing it.
This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-installation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work Bison already installed/compiled Bison successfully compiled Lua already installed/compiled Lua successfully compiled Add /usr/lib/openfoam/openfoam2106/applications/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically Current OpenFOAM version is v2106. Previously compiled for OpenFOAM (v2106) /usr/lib/openfoam/openfoam2106/applications/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison) Reading variables from 'swakConfiguration' Looking for Python 2 Looking for Python 3 Found Python 3.8 Configuring Python 3.8 Using python3.8 at /usr/bin/python3.8-config for python3 Using our own Lua at /usr/lib/openfoam/openfoam2106/applications/swak4Foam/privateRequirements Checking swak4Foam-version and generating file Swak version is 202x.yy.0 hg info: ea7680cdcf8b (develop) tip No 'bear' installed Bison: /usr/lib/openfoam/openfoam2106/applications/swak4Foam/privateRequirements/bin/bison Flex: /usr/bin/flex Bison at /usr/lib/openfoam/openfoam2106/applications/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4) Flex is version 2.6.4 (Minor version: 4) OpenFOAM-version: Major 2106 Minor 0 Patch 0 (-1 == x / 0) Fork: com No change to swak4FoamParsers/foamVersion4swak.H Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem wmake libso swak4FoamParsers /usr/lib/openfoam/openfoam2106/build/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/options:69: /usr/lib/openfoam/openfoam2106/build/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory make: *** No rule to make target '/usr/lib/openfoam/openfoam2106/build/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/../myflex'. Stop. /usr/lib/openfoam/openfoam2106/build/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/options:69: /usr/lib/openfoam/openfoam2106/build/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/../myflex: No such file or directory make: *** No rule to make target '/usr/lib/openfoam/openfoam2106/build/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/../myflex'. Stop. wmake error: file '/usr/lib/openfoam/openfoam2106/build/linux64GccDPInt32Opt/applications/swak4Foam/Libraries/swak4FoamParsers/sourceFiles' could not be created in /usr/lib/openfoam/openfoam2106/applications/swak4Foam/Libraries/swak4FoamParsers Parser library did not compile OK. No sense continuing as everything else depends on it Requirements for Library not satisfied. I see no sense in going on Check the README before you go on to ask. And search: Most likely your problem occurred to 5 other people before and has been solved on the MessageBoard |
January 8, 2022, 07:51 |
#159 |
Ashutosh
Rep Power: 5 |
You are trying to write in /usr/lib/openfoam which is not writable without root.
Try this mkdir -p $FOAM_RUN then execute Allwmake script |
January 18, 2022, 07:53 |
#160 |
wangchuanwei
compile error, swak4foam |
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 11:59 |
[swak4Foam] and twoPhaseEulerFoam | mnikku | OpenFOAM Community Contributions | 1 | February 19, 2016 05:21 |
source term in near wall cell | rajcfd | OpenFOAM Pre-Processing | 5 | February 1, 2016 10:31 |
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 | kobayashi | OpenFOAM Community Contributions | 2 | January 5, 2014 17:33 |
[swak4Foam] fails in parallel with -otherTime? | Phicau | OpenFOAM Community Contributions | 3 | June 26, 2013 13:00 |
