March 21, 2013, 05:24 |
#21 | |
Dongyue Li
Rep Power: 18 |
I have download this and do the comment, //#define FOAM_LOOKUPCLASS_NO_CONST it compiles okay in my foam 2.2.0. And run funkySetFields -time 0 It works! Thanks you all you guys especially Gschaider.you did a splenedid work.! Well, I tried to make the velocity of alpha 0 field to be (0 -0.1 0) Code:
FoamFile { version 2.0; format ascii; class dictionary; object funkySetFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // expressions ( internalFields { field alpha1; expression "1"; condition "pow(pos().x,2) + pow(pos().y-0.15,2) <= pow(0.15,2)/4";//f x^2+(y-0.0015)^2<0.0015^2/4 keepPatches 1; } internalFields { field U; expression "(0 -0.1 0)"; condition "pow(pos().x,2) + pow(pos().y-0.15,2) <= pow(0.15,2)/4";//f x^2+(y-0.0015)^2<0.0015^2/4 keepPatches 1; } ); Code:
Create time Create mesh for time = 0 Time = 0 Using funkySetFieldsDict Part: internalFields Modifying field alpha1 of type volScalarField Putting "1" into field alpha1 at t = "0" if condition "pow(pos().x,2) + pow(pos().y-0.15,2) <= pow(0.15,2)/4" is true Keeping patches unaltered Setting 284 of 8000 cells Writing to "alpha1" Part: internalFields Modifying field U of type volVectorField Putting "(0 0 0)" into field U at t = "0" if condition "pow(pos().x,2) + pow(pos().y-0.15,2) <= pow(0.15,2)/4" is true --> FOAM FATAL ERROR: Parser Error for driver FieldValueExpressionDriver at "1.4" :"syntax error, unexpected number" "(0 0 0)" ^ -----| Context of the error: - Driver constructed from scratch Evaluating expression "(0 0 0)" From function parsingValue in file lnInclude/CommonValueExpressionDriverI.H at line 1039. FOAM exiting Thanks in advanvce. Last edited by sharonyue; March 21, 2013 at 08:18. |
March 24, 2013, 12:16 |
#22 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi sharonyue,
Best regards, Bruno
March 24, 2013, 16:52 |
#23 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
(vectors, for technical reasons, have a different syntax in swak) Of course Bruno is right here: a new problem deserves a new thread
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
March 24, 2013, 21:58 |
#24 | |
Dongyue Li
Rep Power: 18 |
April 1, 2013, 13:51 |
#25 |
angel
Rep Power: 17 |
First at all, I want to thanks you all you guys especially Gschaider.you did a splendid work.! and many tanks for your work in swak4foam. I have update to latest version of OF (Version 2.2.0) and i have tried to install swak4foam as you mention 1º hg clone http://openfoam-extend.hg.sourceforg...tend/swak4Foam 2º hg update port 2.0.x 3º copy swakConfiguration.example to swakConfiguration 4º comment the line //#define FOAM_LOOKUPCLASS_NO_CONST 5º Compile with this result file (allwmakelog file) But when i try to use an example that run perfect in previous version of OF 2.0+swak4foam, I obtain the following error: %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% --> FOAM FATAL ERROR: Not implemented From function simpleFunctionObject::movePoints in file simpleFunctionObject/simpleFunctionObject.H at line 160. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::functionObjectList::movePoints(Foam:olyMes h const&) at ??:? #3 Foam:olyMesh::movePoints(Foam::Field<Foam::Vecto r<double> > const&) at ??:? #4 Foam::fvMesh::movePoints(Foam::Field<Foam::Vector< double> > const&) at ??:? #5 Foam::solidBodyMotionFvMesh::update() at ??:? #6 at ??:? #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 at ??:? Abortado (`core' generado) %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% The controldic is: libs ( //"libOpenFOAM.so" // keeps paraFoam happy "libtwoPhaseInterfaceProperties.so" "libinterfaceProperties.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" ); functions { liquid_Vol { type swakExpression; valueType internalField; accumulations (sum); expression "alpha1*vol()"; //verbose true; //autowrite true; } }; Does anyone know how to handle this? Thanks in advance. Angel, |
April 1, 2013, 17:10 |
#26 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I think the problem is my fault. The new API requires that the functionObjects have methods that say "Hey. I know how to behave during mesh-movement". I said "OK. Fair enough. But I'm not sure if all my function objects are really up to it. So I'll include a dummy implementation that will blow up. So I'll know I'll have to check". And then I forgot about it. That's why it blew up in YOUR face. Quick fix: go to the file Libraries/simpleFunctionObjects/simpleFunctionObject/simpleFunctionObject.H search for the line Code:
notImplemented("simpleFunctionObject::updateMesh"); Code:
// notImplemented("simpleFunctionObject::updateMesh");
May 7, 2013, 06:31 |
swak4Foam installation
#27 |
Claudio
Rep Power: 14 |
Dear Foamers,
I have similar problems with the installation of swak4Foam, with the last version. I create a new post here http://www.cfd-online.com/Forums/ope...tml#post425801 if you prefer, or answer directly in this one. I attached the log of ./Allwmake Thank you in advance for your help! Best regards, Claudio |
July 21, 2013, 14:07 |
swak4foam installation
#28 |
sebastian n
Rep Power: 13 |
Hi Foamers,
i failed to install Swak4Foam_release_0.2.3 on my system. I am using Openfoam 2.2.0 on Ubuntu 12.04 LTS; i installed bison 2.5 and flex 2.5.35 and i did ./Allwmake; i added my wmake.txt file. Best regards, gruenertee |
July 21, 2013, 14:14 |
#29 | |
Bruno Santos
Rep Power: 128 |
Greetings gruenertee,
According to your description, it looks like you did not read the warning sign Quote:
If you do not know how or simply do not want to use SVN, then you can download the latest 0.2.4 from here: https://github.com/wyldckat/swak4foam/archive/OF22X.zip Best regards, Bruno
July 22, 2013, 04:50 |
#30 |
sebastian n
Rep Power: 13 |
wyldckat, I am very grateful for your pointing out the swak4foam version 0.2.4 for Openfoam 2.2.0; The installation process was successfully working.
July 23, 2013, 04:04 |
#31 |
Rep Power: 13 |
Hi All,
I tried to install swak4foam from the link: https://github.com/wyldckat/swak4foam/archive/OF22X.zip However I got the following error: I/opt/openfoam220/src/sampling/lnInclude -I/opt/openfoam220/src/meshTools/Libraries/swak4FoamParsers/lnInclude/ -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/funkySetFields.o -L/opt/openfoam220/platforms/linuxGccDPOpt/lib \ -lfiniteVolume -lmeshTools -L/home/basu/OpenFOAM/basu-2.2.0/platforms/linuxGccDPOpt/lib -lswak4FoamParsers -lOpenFOAM -ldl -lm -o /home/basu/OpenFOAM/basu-2.2.0/platforms/linuxGccDPOpt/bin/funkySetFields make[1]: Leaving directory `/home/basu/OpenFOAM/basu-2.2.0/Swak4Foam_2.x_release_0.2.3/Utilities/funkySetFields' Making dependency list for source file replayTransientBC.C make[1]: Entering directory `/home/basu/OpenFOAM/basu-2.2.0/Swak4Foam_2.x_release_0.2.3/Utilities/replayTransientBC' SOURCE=replayTransientBC.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/cfdTools/lnInclude -I/opt/openfoam220/src/cfdTools/general/lnInclude -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/replayTransientBC.o g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/cfdTools/lnInclude -I/opt/openfoam220/src/cfdTools/general/lnInclude -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/replayTransientBC.o -L/opt/openfoam220/platforms/linuxGccDPOpt/lib \ -lfiniteVolume -lmeshTools -lOpenFOAM -ldl -lm -o /home/basu/OpenFOAM/basu-2.2.0/platforms/linuxGccDPOpt/bin/replayTransientBC make[1]: Leaving directory `/home/basu/OpenFOAM/basu-2.2.0/Swak4Foam_2.x_release_0.2.3/Utilities/replayTransientBC' If you want to use swakCoded-function object or compile software based on swak set the environment variable SWAK4FOAM_SRC to /home/basu/OpenFOAM/basu-2.2.0/Swak4Foam_2.x_release_0.2.3/Libraries (most people will be fine without setting that variable) It would be great if anybody can provide some help.. (I am using FOAM 2.2.0, Bison 2.5, Flex 2.5.35) |
July 23, 2013, 04:40 |
#32 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The rest of the output looks fine. If you want to be sure rerun Allwmake. You should only see a the lines about the libraries being created and the above message
July 23, 2013, 07:02 |
#33 |
Rep Power: 13 |
Ok .. got it.. Thanx
July 29, 2013, 12:24 |
Compilation error
#34 | |
Rep Power: 14 |
Hey! I tried to compile swak4foam but get a lot of errors. Tried the commenting in swak.H but did not work. Any other suggestions? I use OpenFoam2.2.x and swak4foam0.2.3!
I included a part here and attached the whole error message as word. Hope somebody can help. Thanks a lot in advance! Errormessage: Quote:
July 29, 2013, 13:26 |
#35 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Anyway: the error message says that there is a installation problem with the bison-version in your ThirdParty-tools (did you add this bison yourself or does it come with the prepackaged ThirdParty-stuff?). Hard to tell what is actually the problem. I'd suggest to use the bison from the operating system
September 10, 2013, 12:28 |
#36 | |
Anton Kidess
Rep Power: 30 |
Just did a checkout via hg and bumped into the same issue. Is there a reason for keeping around that line?
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
September 10, 2013, 17:55 |
#37 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Nostalgia and old installations. But you're right: should be commented out by default.
September 12, 2013, 16:03 |
#38 | |
alex
Rep Power: 17 |
Hi. What is suposed to change in this file? I have comment it (with a //), I have maintained without change and never works. I have also patched with the swak2Foam_024_OF22x_49808a1c.gz file but the compilations always crashes... Code:
... ../FieldValueExpressionParser.yy:5492:13: error: ‘yylloc’ was not declared in this scope ../FieldValueExpressionParser.yy:5499:13: error: ‘yylloc’ was not declared in this scope ../FieldValueExpressionParser.yy:5507:13: error: ‘yylloc’ was not declared in this scope ../FieldValueExpressionParser.yy:5514:13: error: ‘yylloc’ was not declared in this scope make: *** [Make/linux64GccDPOpt/FieldValueExpressionParser.o] Error 1 Parser library did not compile OK. No sense continuing as everything else depends on it Requirements for Library not satisfied. I see no sense in going on Thanks, Carlos |
September 12, 2013, 17:25 |
#39 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
October 1, 2013, 14:32 |
#40 | ||
Fernando
Rep Power: 13 |
I'm using the version cloned from the wiki's SVN, patched and with the line mentioned on the above post commented out, and I've tried it with OpenFOAM 2.2.1 and 2.2.x I've also tried the developement version, with no luck Code:
No 'swakConfiguration'. Python etc won't work Checking swak4Foam-version and generating file File "./maintainanceScripts/makeSwakVersionFile.py", line 27 print "Keeping the last real version number",verstring ^ SyntaxError: invalid syntax Bison is version 3.0 Flex is version 2.5.37 (Minor version: 37) OpenFOAM-version: Major 2 Minor 2 Patch 1 (-1 == x) No swak4FoamParsers/foamVersion4swak.H. Generated wmakeLnInclude: linking include files to ./lnInclude (...) ../FieldValueExpressionParser.yy:5499:13: nota: in expansion of macro ‘sameSize’ lnInclude/swakChecks.H:63:92: error: ‘yylloc’ no se declaró en este ámbito #define sameSize(a,b) {Foam::string err=Foam::swakAssertSameSize(a,b); if(err!="") { error(yylloc,err); YYERROR; }} ^ ../FieldValueExpressionParser.yy:5507:13: nota: in expansion of macro ‘sameSize’ lnInclude/swakChecks.H:63:92: error: ‘yylloc’ no se declaró en este ámbito #define sameSize(a,b) {Foam::string err=Foam::swakAssertSameSize(a,b); if(err!="") { error(yylloc,err); YYERROR; }} ^ ../FieldValueExpressionParser.yy:5514:13: nota: in expansion of macro ‘sameSize’ make: *** [Make/linux64GccDPOpt/FieldValueExpressionParser.o] Error 1 Parser library did not compile OK. No sense continuing as everything else depends on it Requirements for Library not satisfied. I see no sense in going on |
compile error, swak4foam |
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 11:59 |
[swak4Foam] and twoPhaseEulerFoam | mnikku | OpenFOAM Community Contributions | 1 | February 19, 2016 05:21 |
source term in near wall cell | rajcfd | OpenFOAM Pre-Processing | 5 | February 1, 2016 10:31 |
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 | kobayashi | OpenFOAM Community Contributions | 2 | January 5, 2014 17:33 |
[swak4Foam] fails in parallel with -otherTime? | Phicau | OpenFOAM Community Contributions | 3 | June 26, 2013 13:00 |
