October 22, 2023, 15:26 |
#181 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Jinshi! If that is the only error then I'd say you don't have a problem unless you want to play with the Python-integration (very few people do) It is possible that the compilation of the library failed because there are no development headers for python installed (some systems don't install them as they are not strictly necessary). I'll adapt the compilation process so that there is no attempt to compiel that utility if the necessary headers are missing Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
February 7, 2024, 17:22 |
swak4Foam error installing
#182 |
Κάντε μία επιλογή…
Rep Power: 4 |
Hi!
I cannot install swak4Foam. Im using windows 10 and WSL. Here is the log file after wmake. Code:
Current OpenFOAM version is v2312. Previously compiled for OpenFOAM (v2312) /home/othonas/OpenFOAM/othonas-v2312/platforms/linux64GccDPInt32Opt/lib/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison) Reading variables from 'swakConfiguration' Automatic settings from ./swakConfiguration.automatic Looking for Python 2 Looking for Python 3 Using our own Lua at /home/othonas/OpenFOAM/othonas-v2312/platforms/linux64GccDPInt32Opt/lib/swak4Foam/privateRequirements Checking swak4Foam-version and generating file Swak version is 202x.yy.0 hg info: fde145032783 (develop) tip No 'bear' installed Bison: /home/othonas/OpenFOAM/othonas-v2312/platforms/linux64GccDPInt32Opt/lib/swak4Foam/privateRequirements/bin/bison Flex: /usr/bin/flex Bison at /home/othonas/OpenFOAM/othonas-v2312/platforms/linux64GccDPInt32Opt/lib/swak4Foam/privateRequirements/bin/bison is version 3.4 (Major 3 Minor 4) Flex is version 2.6.4 (Minor version: 4) No change to swak4FoamParsers/foamVersion4swak.H Please include the output above when reporting a problem in the compilation. It helps diagnosing the problem |
February 8, 2024, 11:36 |
#183 |
Shravan
Rep Power: 9 |
I am not fully sure of the solution. But since you are using a recent release, you can try using the following command: HTML Code:
hg update develop Thanks |
compile error, swak4foam |
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 12:59 |
[swak4Foam] and twoPhaseEulerFoam | mnikku | OpenFOAM Community Contributions | 1 | February 19, 2016 06:21 |
source term in near wall cell | rajcfd | OpenFOAM Pre-Processing | 5 | February 1, 2016 11:31 |
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 | kobayashi | OpenFOAM Community Contributions | 2 | January 5, 2014 18:33 |
[swak4Foam] fails in parallel with -otherTime? | Phicau | OpenFOAM Community Contributions | 3 | June 26, 2013 14:00 |
