[swak4Foam] Is it possible to use "calculated" type in groovyBC?
Old   February 9, 2013, 17:42
Default Is it possible to use "calculated" type in groovyBC?
immortality's Avatar
Ehsan
immortality is on a distinguished road
the pressures and as a result velocity at outlet goes very high( velocity goes over 1000m/s) though it should be subsonic around 300-400m/s.can i set the pressure to be obtained by the solver like "calculated" type?
immortality is offline   Reply With Quote
Why Menter's SST model low-Re issue has not been seriously investigated? vkrastev OpenFOAM 58 January 8, 2018 16:20
inlet pressure is higher than outlet pressure for fan sivakumar OpenFOAM Pre-Processing 16 December 30, 2017 15:16
Wrong Boundary Conditions (maximum number of iterations) in compressibleInterDyMFoam silencebreak OpenFOAM Running, Solving & CFD 0 September 11, 2017 08:05
interFoam/kOmegaSST tank filling with printStackError/Mules simpomann OpenFOAM Running, Solving & CFD 3 February 17, 2014 18:06
T Junction Stability ignacio OpenFOAM Running, Solving & CFD 5 May 2, 2013 11:44
