[swak4Foam] using of field pressure values at groovyBC |
November 23, 2012, 11:30 |
Ehsan
Rep Power: 27 |
I must explain more obvious.I need to use pressure in boundary neighbour cells copy on the boundary.how can I do this in groovyBC?
Im in a urgent situation.please help! |
November 23, 2012, 13:54 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
http://openfoamwiki.net/index.php/Co...her_field_are: Code:
internalField(p)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
November 23, 2012, 18:10 |
Ehsan
Rep Power: 27 |
thank you very much.
I'd seen that page before but since not related example was there I didn't have attention to it. Thank you again. Another less easy question! How is it possible to simulate a p0 and T0 boundary condition without having velocity field with openfoam.just these stagnation properties are known. Thank you again. |
potential flows, helmholtz decomposition and other stuffs | pigna | Main CFD Forum | 1 | October 26, 2017 09:34 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 14:04 |
Incompressible Flow: Retrieving Pressure from Velocity Field | lordvon | Main CFD Forum | 9 | July 6, 2013 12:24 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 23:02 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
