[swak4Foam] Time varying non uniform velocity gradient, groovyBC?
Old   October 30, 2012, 13:38
Default Time varying non uniform velocity gradient, groovyBC?
ic3wall is on a distinguished road
Hi all,
As the title says, I have to impose a non uniform velocity gradient on a given patch that will vary for each iteration based on another variable. I searched a bit to find a similar boundary condition that I could modify to achieve what I want ... but didn't find anything interesting except "fixedFluxPressureFvPatchScalarField" which is still far from what I want.
I also read a bit about groovyBC (skaw4foam), but I'm still not convinced that it would be the best choice.
I'm certainly not the first one dealing with such a boundary condition..
What would you suggest ?
ic3wall is offline   Reply With Quote
Old   November 14, 2012, 18:26
Assistant Moderator
Bernhard Gschaider
Originally Posted by ic3wall View Post
Hi all,
Define "best choice"
I think that you either program such a boundary condition yourself or use groovyBC. An intermediate solution would be codedFixedGradient, but last time I checked there was no such BC (and using other fields is way easier in groovyBC ... I think)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
