[swak4Foam] funkySetField
Old   September 11, 2012, 05:40
Default funkySetField
newbie29 is on a distinguished road
I'm using funkySetFieldDict to define the velocity of my internal field. Unfortunately after using the funkySetField command all the other boundary conditions defined in the U-file are replaced by zeroGradient. Is there a way that funkySetField keeps the previous defined velocity boundary conditions? Otherwise it is quite time consuming to correct every single case.
See my used funkySetFieldDict:
FoamFile
    version         2.0;
    format          ascii;
    class           dictionary;
    object          funkySetFieldsDict;
expressions
    internalfield
        field U;
        expression "(18*((log(pos().z/0.0002))/(log(17/0.0002))))*vector(-0.966,0.259,0)";
Thanks for any help in advance!!!
Regards
Nils
newbie29 is offline   Reply With Quote
Old   September 11, 2012, 20:39
Assistant Moderator
Bernhard Gschaider
FoamFile
    version         2.0;
    format          ascii;
    class           dictionary;
expressions
    internalfield
        field U;
Regards
Nils
The solution exists since the first versions of funkySetFields and it is even documented at http://openfoamwiki.net/index.php/Co...and_line_usage : keepPatches (documentation is a fascinating thing ...)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 12, 2012, 02:50
thanks a lot for your hint, it woks perfectly. And shame on me!!!
Regards
Nils
funkysetfield, internal field, velocity
Bubble in zero gravity conditions sega OpenFOAM Running, Solving & CFD 59 November 25, 2011 08:21
[Technical] Cell numbering sega OpenFOAM Meshing & Mesh Conversion 1 April 20, 2010 12:32
[swak4Foam] funkySetField lions85 OpenFOAM Community Contributions 2 March 17, 2010 08:57
