September 10, 2012, 07:11 |
swak4foam can not be installed
Rep Power: 15 |
I'm facing a problem when I want to 'wmake all' swak4foam: No 'swakConfiguration'. Python etc won't work Checking swak4Foam-version and generating file Bison is version 2.5 OpenFOAM-version: Major 2 Minor 1 Patch 0 No change to swak4FoamParsers/foamVersion4swak.H /opt/openfoam210/wmake/wmake: 222: /opt/openfoam210/wmake/wmake: make: not found /opt/openfoam210/wmake/wmake: 223: /opt/openfoam210/wmake/wmake: make: not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/thomas/swak4Foam/Libraries/swak4FoamParsers /opt/openfoam210/wmake/wmake: 222: /opt/openfoam210/wmake/wmake: make: not found /opt/openfoam210/wmake/wmake: 223: /opt/openfoam210/wmake/wmake: make: not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/thomas/swak4Foam/Libraries/groovyBC /opt/openfoam210/wmake/wmake: 222: /opt/openfoam210/wmake/wmake: make: not found /opt/openfoam210/wmake/wmake: 223: /opt/openfoam210/wmake/wmake: make: not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/thomas/swak4Foam/Libraries/swakFunctionObjects /opt/openfoam210/wmake/wmake: 222: /opt/openfoam210/wmake/wmake: make: not found /opt/openfoam210/wmake/wmake: 223: /opt/openfoam210/wmake/wmake: make: not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/thomas/swak4Foam/Libraries/simpleFunctionObjects /opt/openfoam210/wmake/wmake: 222: /opt/openfoam210/wmake/wmake: make: not found /opt/openfoam210/wmake/wmake: 223: /opt/openfoam210/wmake/wmake: make: not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/thomas/swak4Foam/Libraries/simpleSwakFunctionObjects /opt/openfoam210/wmake/wmake: 222: /opt/openfoam210/wmake/wmake: make: not found /opt/openfoam210/wmake/wmake: 223: /opt/openfoam210/wmake/wmake: make: not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/thomas/swak4Foam/Libraries/swakTopoSources /opt/openfoam210/wmake/wmake: 222: /opt/openfoam210/wmake/wmake: make: not found /opt/openfoam210/wmake/wmake: 223: /opt/openfoam210/wmake/wmake: make: not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/thomas/swak4Foam/Libraries/swakSourceFields /opt/openfoam210/wmake/wmake: 222: /opt/openfoam210/wmake/wmake: make: not found /opt/openfoam210/wmake/wmake: 223: /opt/openfoam210/wmake/wmake: make: not found wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/thomas/swak4Foam/Libraries/groovyStandardBCs SWAK_PYTHON_INCLUDE not defined .... no Python-Integration /opt/openfoam210/wmake/wmake: 185: /opt/openfoam210/wmake/wmake: make: not found I don't understand from the message which file is missing... Any idea? Regards Hugo |
September 11, 2012, 05:17 |
Solved
Rep Power: 15 |
OK, the reason was quite stupid: make was missing on the system...
Regards Hugo |
[swak4Foam] Installing swak4Foam 0.4.0 on ubuntu 14.04 | JFM | OpenFOAM Community Contributions | 1 | October 30, 2016 09:43 |
[swak4Foam] swak4Foam cannot be installed on foam-extend-3.2 | lxwd | OpenFOAM Community Contributions | 1 | October 11, 2016 08:24 |
[swak4Foam] fails in parallel with -otherTime? | Phicau | OpenFOAM Community Contributions | 3 | June 26, 2013 13:00 |
unable to install openfoam 1.7 using apt-get | maazhmd | OpenFOAM Installation | 7 | July 24, 2011 11:18 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
