[Helyx OS] Helyx-OS (GUI for SnappyHexMesh
Like Tree44Likes
Old   January 8, 2016, 13:45
Olivier Rouch
roucho is on a distinguished road
Send a message via MSN to roucho
Hi Foamers,
It's been a week, now. Did anybody have any news from either SourceForge or Engys, concerning Helyx-OS?
Thanks!
roucho is offline   Reply With Quote
Old   January 9, 2016, 11:25
Retired Super Moderator
Bruno Santos
Greetings to all!
I haven't gotten an answer from Daniel yet (as I mentioned in my previous post #179), but the Dynaflow website (who are partners with Engys in some projects, according to one of the pages I read) has the following note:
Originally Posted by http://www.dynaflow.com/software/helyx-os-download
The Helyx-OS download page is temporarily unavailable.
We are sorry for the inconvenience.
So whatever is going on, they are not yet at liberty to say.
Best regards,
Bruno
Old   January 22, 2016, 14:41
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
@Rao_BuidlingDesign @Trilby Tim @roucho @wyldckat
Just to follow up on the discussion, HELYX-OS is back online with a new project page (http://engys.github.io/HELYX-OS/) and we have migrated from SourceForge to github. I posted an announcement earlier. Please use the new issue tracker if you would like to report an issue.
elvis, wyldckat, JR22 and 1 others like this.
chegdan is offline   Reply With Quote
Old   February 1, 2016, 09:58
Trilby Tim is on a distinguished road
Cheers! Yes, I noticed it was back and have just downloaded and installed it, looks good!
chegdan likes this.
Trilby Tim is offline   Reply With Quote
Old   March 2, 2016, 04:46
Default Helyx-os
  #185
Shai Aser
shaiashe is on a distinguished road
Im using HELYX OS v2.3.1, and when I start a new case, I get this msg in the terminal:
0 - pool-3-thread-1 - ERROR IOUtils - Error reading file /home/user/.HELYX-OS/tmp/tmp_1456908133/dictData/HELYX-OS/createCase.mapFieldsDict: File '/home/user/.HELYX-OS/tmp/tmp_1456908133/dictData/HELYX-OS/createCase.mapFieldsDict' does not exist
2 - pool-3-thread-1 - ERROR IOUtils - Error reading file /home/user/.HELYX-OS/tmp/tmp_1456908133/dictData/HELYX-OS/createCase.customNodeDict: File '/home/user/.HELYX-OS/tmp/tmp_1456908133/dictData/HELYX-OS/createCase.customNodeDict' does not exist
anyone know how to fix this?
thanks,
shaiashe is offline   Reply With Quote
Old   March 5, 2016, 20:21
Daniel P. Combest
Hi shaiashe,
What is your platform? How did you install HELYX-OS? It is looking for a folder in your home directory that it uses to hold temporary files/settings and cannot find the folder.
Old   March 29, 2016, 08:31
Andrew
Antech is on a distinguished road
Hello.
I tried to use Helyx-OS with snappyHexMesh as an alternative to Ansys Meshing that we usually use for our industrial cases. Generated mesh is visually OK except for distored edges. I remember that I fixed it with surfaceFeatureExtract but I cannot find an option to run tis utility automatically from Helyx-OS GUI. I can edit the mesh script and add surfaceFeatureExtract but it requires it's dictionary to run. This leads to inconvenient mesh creation procedure (compared with Ansys Meshing that generates good meshes but not acceptable hexa). Is there an option to launch surfaceFeatureExtract correctly using Helyx-OS GUI or I need to tweak case files by hand anyway?
Thanks.
[ Moderator note: Moved from http://www.cfd-online.com/Forums/ope...penfoam-2.html ]
Antech is offline   Reply With Quote
Old   March 29, 2016, 10:10
Daniel P. Combest
Andrew,
No problem, HELYX-OS can extract feature edges like you have done in the past.
  1. Within HELYX-OS, go to your surface and select it with the right mouse button.
  2. Navigate and select Lines>Extract to bring up the extract feature lines dialogue.
  3. Adjust the feature angle and hit apply to visualize the extracted lines. TIP: To see the lines better you can hide the surface in the tree to the left by unchecking the surface under geometry.
  4. When you are happy with what has been extracted, hit save and then you will find the extracted line under the lined entry in the tree. There you can perform some distance refinement, including refinement directly on the lines i.e. refine at a distance of 0.
Good luck and I hope this helps. There is an ongoing discussion at
http://www.cfd-online.com/Forums/ope...pyhexmesh.html
so feel free to post questions there later if you are having any issues (this thread may be moved there too).
Old   March 30, 2016, 09:00
Andrew
chegdan
Hello, thanks for you suggestion! I tried this and I can see lines. I press the Save button, the Wall_line object appears in the GUI tree. I save the project and try to build the mesh but an error occures:
fileName::stripInvalid() called for invalid fileName Wall_line.eMesh
Sorry, but, IMHO, there is a bug. I searched the case dir and found "Wall_line .eMesh" file with the trailing space in the name (obviously the space is illegal in this name so the mesher exits with error). OK, I deleted lines in GUI and recreated them. They was automatically named "Wall_line " (with trailing space). OK, I renamed them to "Test" and I see no spaces in the GUI edit box, but there visually even several trailing spaces in the tree item name . If I click on the "Lines" group in the tree the "Wall_line " or "Test " item name disappears at all. Is it some compatibility issue? Is this (line extract) feature widely used?
OS: CentOS 6.7 x64
HelyxOS 2.3.0
OpenFOAM 2.3.0
I added an attachment with screenshots.
I built the mesh despite of GUI behavior (lines element in the tree without name). Now the Wall_line.eMesh in triSurface dir has correct name but the mesh is still distored on edges (see my previous picture). I don't need a refinement on edges, I just need them to correspond to geometry (to be sharp). Should I switch some option?
Old   March 30, 2016, 10:23
Daniel P. Combest
Antech,
I'll investigate further on the issue. Though a trailing space is in the name in the GUI, things are written correctly and I am able to get a mesh using the eMesh. I can see that it will delete the name if I click around a bit so I will report this behavior to the developer and see if we can improve it.
Concerning your issue of snapping, this could be many things. Not enough refinement is the most common issue, hence the use of the eMesh with a higher level at a distance of zero. Make sure that the Options>snapping>explicit snap feature is true to use the emesh files. Also you could increase the number of snap feature iterations inside of Options>snapping.
Last edited by wyldckat; April 2, 2016 at 11:52. Reason: removed link to the announcement thread, after having moved posts to this thread
Old   March 30, 2016, 11:42
Andrew
chegdan
Thanks for your answer.
Explicit snap feature is on. It was a Resolve Feature Angle that was set to 100 degree to cope with refinement at corners that is not needed and increase the mesh size. I set the resolve feature angle to default 30 degrees and voila - the edges are sharp but now they has undesired refinement I'm now playing with some sHM parameters in my spare time...
Old   March 30, 2016, 12:14
Daniel P. Combest
Antech,
Ah yes, I assumed you didn't mess with the feature angle. Honestly the default settings work well for a majority of cases. There is a nice talk by Andrew Jackson on the different settings within SHM.
Old   June 6, 2016, 11:53
Bruno
MBttR is on a distinguished road
Originally Posted by chegdan View Post
Hi shaiashe,
Hi Daniel,
I am not shaiashe but it seems you never got a reply. Well, here I am with the exact same problem!
I installed HELYX-OS according to the directions posted here. I am running OpenFOAM 2.4.0 on Ubuntu 15.10 on a VirtualBox machine on Windows 10 64 bit.
On the first boot of HELYX-OS, it asked for the core folder, here I gave:
/home/bruno/OpenFOAM/OpenFOAM-2.4.0
And ParaView Executable (of this I'm not sure if it is correct):
/home/bruno/OpenFOAM/ThirdParty-2.4.0/platforms/linux64Gcc/ParaView-4.1.0/bin/paraview
For this last one, there's also a ParaView folder in the ThirdParty folder so I was not sure.
Otherwise it seems to run fine, although it shows some behaviour which I'm not sure is normal;
I just tried opening the Cavity example from the OpenFOAM Tutorials, and it doesn't seem to read the existing blockMeshDict file. It just ignores this and creates a mesh according to whatever is dictated in HELXY-OS. I'm not sure if this is supposed to happen? The mesh I create in HELYX-OS does get read into ParaView later down the line though, so that's something.
Thanks!
Bruno
chegdan likes this.
MBttR is offline   Reply With Quote
Old   June 6, 2016, 12:28
Daniel P. Combest
Bruno,
Thanks for the report on your installation process. As for not reading in the constant/polyMesh/blockMeshDict file, HELYX OS expects that the blockMeshDict is in system. Most *Dict files are in the system directory (e.g. controlDict, snappyHexMeshDict, topoSetDict, etc.) but the blockMesh application has always looked in the constant/polymesh folder. HELYX OS reads/creates blockMeshDict files in the system directory (for consistency) and when blockMesh is run, it uses the command
blockMesh -dict ./system/blockMeshDict
to pass the correct dictionary in the system folder. Also, as for ParaView. Users do not need to point to the installation of ParaView in the thirdparty folder at all and can download ParaView (a newer version if you like) and just simply point HELYX-OS to that ParaView executable. This will easily allow users to update their install of ParaView if there is a new feature that you want to use.
Thanks for the report and please post if you have any more issues.
Old   June 6, 2016, 19:46
Bruno
Thanks Daniel! Will check it out as soon as I hit the office, but seems logical enough. Just wondering, how does HELYX-OS know it has to call blockMesh? Without a GUI, I tell the terminal to run blockMesh, but is it also stated somewhere in some system file that I was not yet aware of? Or does it do a random search for any file containing *Dict in the name? In case of the latter, what happens if there are two meshDicts available?
Cheers!
Old   June 6, 2016, 20:17
Daniel P. Combest
Bruno,
Good question. It knows to call blockMesh since it must call it when you use snappyHexMesh. When you hit create, it calls blockMesh and then calls snappyHexMesh.
Old   June 7, 2016, 05:40
Bruno
Bruno,
Hmm, my bad, I hadn't noticed HELYX-OS was for snappyHexMesh, should've read the title better Found the script where I could change that though.
Anyway, as expected it now loads the mesh fine when I move it to the system folder, but it ignores the names of the boundaries (hence movingWall, fixedWalls, frontAndBack) assigned to it in blockMeshDict. They get replaced by ffminx to ffmaxz. It magically read them correctly once, but I have no idea how I got that to happen.
It seems to load Runtime Controls input fine, with the correct inputs for startTime, endTime and intervals, but I think the Boundary Conditions are ignored as it gives No-Slip condition to everything. I also can't find my Initial Conditions, the Fields Initialisation tab is just empty, so I can't even see if my initial velocity and pressure are read correctly.
To summarize, keeping with the cavity tutorial, what would be the way to start from scratch and open this case in HELYX-OS? I thought, from scratch, just move blockMeshDict to the system folder and that's it, but I'm starting to think there's more to it?
Hope it all still makes sense. Thanks Daniel!
Old   June 21, 2016, 06:24
Bruno
Hi Daniel,
I was wondering if you have already found what the following error meant upon launching Helyx-OS? I have not used it since my last post, went back and dove into snappyHexMesh first as it seemed relevant to know the basis, but now I'm wanting to give Helyx-OS another try, as it seems helpful in trying to get a mesh to work properly.
It seems to launch OK but I'm not sure if I will run into fatal errors in the future. This is printed in the terminal:
0 - pool-3-thread-1 - ERROR IOUtils - Error reading file /home/user/.HELYX-OS/tmp/tmp_14566500559/dictData/HELYX-OS/createCase.mapFieldsDict: File '/home/user/.HELYX-OS/tmp/tmp_14566500559/dictData/HELYX-OS/createCase.mapFieldsDict' does not exist
2 - pool-3-thread-1 - ERROR IOUtils - Error reading file /home/user/.HELYX-OS/tmp/tmp_14566500559/dictData/HELYX-OS/createCase.customNodeDict: File '/home/user/.HELYX-OS/tmp/tmp_14566500559/dictData/HELYX-OS/createCase.customNodeDict' does not exist
*edit*
Another question;
It seems Helyx-OS will only do MRF, but no rotating mesh, correct?
Old   July 6, 2016, 13:29
Daniel P. Combest
if the GUI did not crash then do not worry about the warnings in the terminal. Make sure you have the most up to date version
The next version that is coming out will have support for dynamic mesh. Those that attended OFW11 have a pre-release of HELYX-OS that will make its way to the github page in the coming weeks.
Old   July 11, 2016, 12:32
Danny Jierian
djierian is on a distinguished road
Is there an estimated release date you can provide? I am extremely interested in this feature! I'm sure many other people are as well.
djierian is offline   Reply With Quote
cases setup, preprocessor, snappyhexmesh
Helyx-OS Open Source GUI for OpenFOAM eugene OpenFOAM Announcements from Other Sources 31 March 9, 2020 17:55
TUI Commands from GUI? Carlos FLUENT 6 May 22, 2013 19:05
User Defined GUI Frederik FLUENT 0 June 23, 2006 17:12
Command Line vs. GUI Menus Go FLUENT 0 June 8, 2005 17:05
GUI window settings cmv Siemens 0 February 7, 2005 07:22
