[swak4Foam] Contrib/swak4Foam
Like Tree3Likes
Old   June 21, 2012, 05:05
Smile
  #21
Julien
Djub is on a distinguished road
My lieges ,
Bruno:
mpirun (Open MPI) 1.3.2
Bernhard:
You are right: I have found
/opt/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/openmpi-system/libPstream.so
BUT the environment variable $FOAM_MPI_LIBBIN does NOT exist!
Another problem: I just don't know what do you mean about "have a bug-report on the mantis with the changes required to Make/option". I would like to help, but how?
Djub is offline   Reply With Quote
Old   June 21, 2012, 11:15
Assistant Moderator
Bernhard Gschaider
Originally Posted by wyldckat View Post
Hi Bernhard and Julien,
@Bernhard:
What can I say, I'm helping people on the forum instead of playing WoW
Greatly appreciated. You don't have a Facebook-account as well I guess
Old   June 21, 2012, 15:51
Assistant Moderator
Bernhard Gschaider
Originally Posted by Djub View Post
My lieges ,
Please don't use such fancy words. I must assume that you're making fun of me
Bernhard:
Like it says at http://openfoamwiki.net/index.php/Co...oam#Bugreports at the Mantis of openfoam-extend http://sourceforge.net/apps/mantisbt...e_status_id=90
wyldckat likes this.
Old   June 21, 2012, 17:23
Retired Super Moderator
Bruno Santos
I do have a Facebook account, but I only use it as a photo album and to somewhat stay in touch with people
As for the bug issue: I'm not so sure this is an actual bug There are too many tell tale signs of something not working properly in this OpenFOAM installation!
edit: I forgot to mention: Julien, what about your "~/.bashrc" file? What does the OpenFOAM related section look like?
Old   June 21, 2012, 20:37
Assistant Moderator
Bernhard Gschaider
That may be right. My assumption was (and I think I saw that before) that some linkers (or some flags) don't link implicitly libraries like meshTools and triSurface to applications. And I thought "Including these won't hurt anyone"
Old   June 22, 2012, 06:19
Julien
Hi!
@Bernhard: I apologize. It was a kind of "private joke" with Bruno since when I played Warcraft, some orcs were saying "My Liege ?". And it was also out of deference to you (with absolutely no irony)
@Bruno: the only link from bash to OpenFoam is its last line:
source /opt/OpenFOAM-2.1.0/etc/bashrc
Old   June 22, 2012, 16:15
Assistant Moderator
Bernhard Gschaider
No problem. My posting was with irony
Old   June 23, 2012, 16:16
Bruno Santos
@Julien:
Mmm... openSUSE 11.4, x86_64 and only installed OpenFOAM 2.1.0 from repositories... you must have installed something else or have something else activated in your terminal environment, for this to be not working the way it should!
The "missing libraries" issue was something that only happened when Ubuntu 11.04 or 11.10 or when Fedora 16 came out (can't really be certain) which brought a new fancy ld that forcefully needs that people properly define all of the necessary library dependencies.
But openSUSE 11.4 didn't have this issue, at least not that I remember. So, it's possible that either you or some application needed this kind of setting... and changed the system's default ld options.
Another question: how exactly were you able to install Open-MPI 1.3.2? Last time I saw, it had disappeared from the openSUSE Science repositories...
Old   June 25, 2012, 05:42
Julien
Sorry Bruno, I have no idea... It a new job for me: I am using a computer allready installed...
Old   February 18, 2013, 22:50
Default interFoamWithSources could not be compiled
  #30
Albert Tong
tfuwa is on a distinguished road
Hi All,
I compiled the swak4Foam a while ago and it worked smoothly.
However, when I wclean all and ./Allwmake it again yesterday, the interFoamWithSources solver could not be compiled. The following is the message from a second time of ./Allwmake.
./Allwmake
No simpleFuctionsObject existing. Press ENTER to continue compilation or abort and download it with the downloadSimpleFunctionObjects.sh script
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswak4FoamParsers.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libgroovyBC.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakFunctionObjects.so' is up to date.
   simpleSwakFunctionObjects not compiled because no simpleFunctionObjects installation found
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakTopoSources.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakSourceFields.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libgroovyStandardBCs.so' is up to date.
make: `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/bin/linux64GccDPOpt/funkySetFields' is up to date.
make: `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/bin/linux64GccDPOpt/funkySetBoundaryField' is up to date.
make: `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/bin/linux64GccDPOpt/replayTransientBC' is up to date.
make: `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/bin/linux64GccDPOpt/funkyDoCalc' is up to date.
So I downloaded compiled the latest version with no improvement.
./Allwmake
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam-version and generating file
Traceback (most recent call last):
  File "./maintainanceScripts/makeSwakVersionFile.py", line 8, in <module>
    output = Popen(["hg", "branch"], stdout=PIPE).communicate()[0]
  File "/usr/lib/python2.7/subprocess.py", line 679, in __init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1239, in _execute_child
    raise child_exception
OSError: [Errno 2] No such file or directory
Bison is version 2.4.1
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 1 Minor 7 Patch 1
No change to swak4FoamParsers/foamVersion4swak.H
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libsimpleFunctionObjects.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libsimpleLagrangianFunctionObjects.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libsimpleSwakFunctionObjects.so' is up to date.
SWAK_PYTHON_INCLUDE not defined .... no Python-Integration
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakMeshQualityFunctionPlugin.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakLocalCalculationsFunctionPlugin.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakRandomFunctionPlugin.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakFvcSchemesFunctionPlugin.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakThermoTurbFunctionPlugin.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakTransportTurbFunctionPlugin.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakSurfacesAndSetsFunctionPlugin.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakLagrangianCloudSourcesFunctionPlugin.so' is up to date.
'/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt/libswakVelocityFunctionPlugin.so' is up to date.
make[1]: Entering directory `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/swak4Foam_1.x_release_0.2.1/Utilities/funkyDoCalc'
make[1]: `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/bin/linux64GccDPOpt/funkyDoCalc' is up to date.
make[1]: Leaving directory `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/swak4Foam_1.x_release_0.2.1/Utilities/funkyDoCalc'
make[1]: Entering directory `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/swak4Foam_1.x_release_0.2.1/Utilities/funkySetBoundaryField'
make[1]: `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/bin/linux64GccDPOpt/funkySetBoundaryField' is up to date.
make[1]: Leaving directory `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/swak4Foam_1.x_release_0.2.1/Utilities/funkySetBoundaryField'
make[1]: Entering directory `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/swak4Foam_1.x_release_0.2.1/Utilities/funkySetFields'
make[1]: `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/bin/linux64GccDPOpt/funkySetFields' is up to date.
make[1]: Leaving directory `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/swak4Foam_1.x_release_0.2.1/Utilities/funkySetFields'
make[1]: Entering directory `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/swak4Foam_1.x_release_0.2.1/Utilities/replayTransientBC'
make[1]: `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/bin/linux64GccDPOpt/replayTransientBC' is up to date.
make[1]: Leaving directory `/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/swak4Foam_1.x_release_0.2.1/Utilities/replayTransientBC'
Please point out the reason and guild me to compile interFoamWithSources. Cheers.
Kind regards,
Albert
tfuwa is offline   Reply With Quote
Old   February 18, 2013, 22:59
Albert Tong
Hi again,
When I tried to compile interFoamWithSources separately, the error message is
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/transportModels     -I/opt/openfoam171/src/transportModels/incompressible/lnInclude     -I/opt/openfoam171/src/transportModels/interfaceProperties/lnInclude     -I/opt/openfoam171/src/turbulenceModels/incompressible/turbulenceModel     -I/opt/openfoam171/src/finiteVolume/lnInclude     -I../../../Libraries/swak4FoamParsers/lnInclude/     -I../../../Libraries/swakSourceFields/lnInclude/ -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/interFoamWithSources.o -L/opt/openfoam171/lib/linux64GccDPOpt \
         -ltwoPhaseInterfaceProperties     -linterfaceProperties     -lincompressibleTransportModels     -lincompressibleTurbulenceModel     -lincompressibleRASModels     -lincompressibleLESModels     -lfiniteVolume     -L/home/tfuwa/OpenFOAM/tfuwa-1.7.1/lib/linux64GccDPOpt     -lswak4FoamParsers     -lswakSourceFields -lOpenFOAM -liberty -ldl   -lm -o /home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/bin/linux64GccDPOpt/interFoamWithSources
/opt/openfoam171/lib/linux64GccDPOpt/libinterfaceProperties.so: undefined reference to `typeinfo for Foam::alphaContactAngleFvPatchScalarField'
collect2: ld returned 1 exit status
make: *** [/home/tfuwa/OpenFOAM/tfuwa-1.7.1/applications/bin/linux64GccDPOpt/interFoamWithSources] Error 1
Thanks in advance for your help.
Kind regards,
Albert
Old   February 19, 2013, 11:24
Assistant Moderator
Bernhard Gschaider
Originally Posted by tfuwa View Post
Hi again,
That is a problem with OpenOFAM. Some time back some stuff was split off into a separate library which must be explicitly linked. Try with this Make/options:
EXE_INC = \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
    -I$(LIB_SRC)/transportModels/interfaceProperties/lnInclude \
    -I$(LIB_SRC)/turbulenceModels/incompressible/turbulenceModel \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I../../../Libraries/swak4FoamParsers/lnInclude/ \
EXE_LIBS = \
    -ltwoPhaseInterfaceProperties \
    -linterfaceProperties \
    -lincompressibleTransportModels \
    -lincompressibleTurbulenceModel \
    -lincompressibleRASModels \
    -lincompressibleLESModels \
    -lfiniteVolume \
    -lsampling \
    -lmeshTools \
    -L$(FOAM_USER_LIBBIN) \
    -lswak4FoamParsers \
    -lswakSourceFields
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 23, 2013, 09:46
  #33
Albert Tong
Hi Bernhard,
I just gave up the installation of interFoamWithSources on OF1.7.1 and moved to OF2.1.1, as after changing options to your suggestion, there were still some errors for OF1.7.1.
After downloading the swak4Foam files from your wiki page (1st link here, "can be downloaded here for OpenFOAM 2.x and OpenFOAM 1.x. "). The installation for swak4Foam itself is ok. I got these in /bin
funkyDoCalc  funkySetBoundaryField  funkySetFields   replayTransientBC
and those in /lib
libgroovyBC.so                   libswakFunctionObjects.so               libswakSourceFields.so
libgroovyStandardBCs.so               libswakFvcSchemesFunctionPlugin.so           libswakSurfacesAndSetsFunctionPlugin.so
libsimpleFunctionObjects.so           libswakLagrangianCloudSourcesFunctionPlugin.so  libswakThermoTurbFunctionPlugin.so
libsimpleLagrangianFunctionObjects.so  libswakLocalCalculationsFunctionPlugin.so       libswakTopoSources.so
libsimpleSwakFunctionObjects.so        libswakMeshQualityFunctionPlugin.so           libswakTransportTurbFunctionPlugin.so
libswak4FoamParsers.so               libswakRandomFunctionPlugin.so               libswakVelocityFunctionPlugin.so
However, when moved to interFoamWithSources(at swak4Foam_2.x_release_0.2.1/Examples/InterFoamWithSources/interFoamWithSources/)
wmake all
the error messages appears as following.
This could be simple for you but I really have no idea what is wrong. Please comment on this. Thanks heaps.
Making dependency list for source file interFoamWithSources.C
could not open file mappedWallPolyPatch.H for source file interFoamWithSources.C
could not open file mappedPolyPatch.H for source file interFoamWithSources.C
could not open file FixedValuePointPatchField.H for source file interFoamWithSources.C
could not open file ZeroGradientPointPatchField.H for source file interFoamWithSources.C
could not open file CalculatedPointPatchField.H for source file interFoamWithSources.C
SOURCE=interFoamWithSources.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -I/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/transportModels -I/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/incompressible/lnInclude -I/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/transportModels/interfaceProperties/lnInclude -I/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/turbulenceModels/incompressible/turbulenceModel -I/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/sampling/lnInclude -I../../../Libraries/swak4FoamParsers/lnInclude/ -I../../../Libraries/swakSourceFields/lnInclude/ -IlnInclude -I. -I/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64Gcc44DPOpt/interFoamWithSources.o
In file included from ../../../Libraries/swak4FoamParsers/lnInclude/FieldValueExpressionDriverI.H:13,
                 from ../../../Libraries/swak4FoamParsers/lnInclude/FieldValueExpressionDriver.H:448,
                 from ../../../Libraries/swakSourceFields/lnInclude/expressionSource.H:45,
                 from interFoamWithSources.C:49:
/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/mappedWallFvPatch.H:39:33: error: mappedWallPolyPatch.H: No such file or directory
In file included from ../../../Libraries/swak4FoamParsers/lnInclude/FieldValueExpressionDriverI.H:14,
/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/mappedFvPatch.H:39:29: error: mappedPolyPatch.H: No such file or directory
In file included from ../../../Libraries/swak4FoamParsers/lnInclude/FieldValueExpressionParser_location.hh:44,
                 from FieldValueExpressionParser.tab.hh:65,
                 from ../../../Libraries/swak4FoamParsers/lnInclude/FieldValueExpressionDriver.H:19,
position.hh: In function ‘bool parserField::operator==(const parserField::position&, const parserField::position&)’:
position.hh:136: warning: suggest parentheses around ‘&&’ within ‘||’
/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/mappedWallFvPatch.H: In static member function ‘static const char* Foam::mappedWallFvPatch::typeName_()’:
/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/mappedWallFvPatch.H:58: error: ‘mappedWallPolyPatch’ has not been declared
/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/mappedFvPatch.H: In static member function ‘static const char* Foam::mappedFvPatch::typeName_()’:
/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/mappedFvPatch.H:58: error: ‘mappedPolyPatch’ has not been declared
/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/readTimeControls.H: In function ‘int main(int, char**)’:
/home/xlou/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/readTimeControls.H:38: warning: unused variable ‘maxDeltaT’
make: *** [Make/linux64Gcc44DPOpt/interFoamWithSources.o] Error 1
Kind regards,
Albert
Old   February 24, 2013, 08:40
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
and those in /lib
wmake all
Yeah. There's a couple of -Is missing from Make/options (fixed in the next release). Locate the files that are not found (either with find or locate) and add the directories to Make/options. I think the missing lines are
and in the link options
     -lsampling \
     -lmeshTools \
The solvers in Examples are only examples (how to add code to stock-solvers) so they're not tested regularly
Old   February 24, 2013, 20:53
Albert Tong
Hi Bernhard,
Great help, especially the tips on how to locate the missing head files. It reflects the spirit that "Give a man a fish, and you feed him for a day; show him how to catch fish, and you feed him for a lifetime." Many thanks.
     -lsampling \
     -lmeshTools \
Kind regards,
Albert
Old   February 25, 2013, 17:20
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
I'd have said it reflects the spirit "Don't bother me again" but I prefer you explanation. It makes me look like a better person than I actually am.
It occurred to me after rereading my post right now that not necessarily everyone is aware that "find" and "locate" are Unix-commands in which case it sounds like mockery.
Old   February 25, 2013, 20:33
Albert Tong
Hi Bernhard,
I hope this reply won't bother you. But sorry for the stupid questions and I appreciate your time & answers.
Kind regards,
Albert
Old   February 26, 2013, 05:27
Assistant Moderator
Bernhard Gschaider
Hi Bernhard,
Kind regards,
Albert
If it bothers me I can't be bothered to answer. So there's no need to bother that I'll be bothered by your reply.
Old   July 23, 2013, 14:51
psk
david
psk is an unknown quantity at this point
Good Day Folks,
I try to install swak4Foam in Openfoam 2.1, I follow these steps
Step 1: [ svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam/ ], copy & paste in terminal window
step 2: [ hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam ] copy & paste in terminal window
upto this step it works
step 3: [ hg update port_2.0.x ] copy & paste in terminal, I got error like this,
toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/swak4Foam$ hg update port_2.0.x
abort: no repository found in '/home/toshiba/OpenFOAM/toshiba-2.1.0/swak4Foam' (.hg not found)!
kindly let me the step 3 is necessary? just I tried.
step4: ./Allwmake --->copy & paste in terminal window, I got error like,
toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/swak4Foam$ ./Allwmake
Swak version is 0.2.4
No 'bison' found. This is absolutely essential for swak4Foam. Can't go on
Requirements for Library not satisfied. I see no sense in going on
Kindly help me
Million Thanks,
David
"Small Dream is a Crime"
psk is offline   Reply With Quote
Old   July 23, 2013, 15:05
Assistant Moderator
Bernhard Gschaider
Originally Posted by psk View Post
Good Day Folks,
Kindly help me
The only fatal thing here is the missing bison (and probably flex is missing too). Both (flex and bison) are available for virtually every Linux-distro known to man (and most of the extraterrestrial distros too). Install them via the package manager of your distro
swak4foam
