[Other] Multi species mass transport library [update] |
August 26, 2015, 10:47 |
#82 |
Rep Power: 11 |
Hello People,
I am trying to compile the diffusivityModels library(code version of 2.1.x ) and I am getting this error In file included from diffusivityModel/diffusivityModel.C:27:0: diffusivityModel/diffusivityModel.H:40:25: fatal error: porousZones.H: No such file or directory compilation terminated. make: *** [Make/linuxGccDPOpt/diffusivityModel.o] Error 1 from where shall I bring this file porousZones.H ? Thanks Ali |
August 26, 2015, 14:46 |
#83 | |
Rep Power: 11 |
fatal error: multiSpeciesTransportModel.H: No such file or directory any suggestions ? thank you Ali Last edited by khalifa; September 1, 2015 at 14:37. |
September 10, 2015, 19:27 |
#84 |
Rep Power: 11 |
Dear Foamers, Thank you so much for your contributions in producing these libraries and developing them to be working with openFoam 2.3.1.
I am trying now to add dynamicMeshing feature to the solver , to combine between multispecies transport and dynamic meshing in one solver. I have a version of reactingFoam with dynamic meshing edits and it works, and I tried to copy the the codes I found related to dynamic meshing to the modifiedReactingFoam solver and compiled successfully, yet no dynamic mesh is created even though the iteration goes on without errors and the criteria for dynamic meshing was achieved! I am attaching the solver which have the dynamic meshing working , and I wish if someone can help to combine it with the modifiedReactingFoam ! regards |
October 13, 2015, 12:37 |
#85 | |
Rep Power: 11 |
any news regarding this or the energy equation ? I have tested the solver for 2.3.1 and I would say there is clearly a problem related with the energy equation. did you conclude to any fixes or so ? Thanks |
February 19, 2016, 03:19 |
#86 |
Yan Wang
Rep Power: 11 |
Anyone know if this multi species transport library has any update? Or anyone has done some work based on it?
Thanks, Yan
Blog: http://blog.sina.com.cn/multiphyzks RG:https://www.researchgate.net/profile/Yan_Wang154 |
May 15, 2016, 14:48 |
#87 |
I think the molar fraction update is no problem.
psi = rho/P; not "psi=1/(Ri*T) Ri " is gas constant for specie i based on the code of psiThermo.C 93 Foam::tmp<Foam::volScalarField> Foam:siThermo::rho() const 94 { 95 return p_*psi_; 96 } The energy equation has some problem because of Enthalpy Diffusion. We need to include the Enthalpy Diffusion term in the equation. If we change all the species Cp are the same. The temperature solution would be OK. The energy equation should be: fvScalarMatrix EEqn ( fvm::ddt(rho, e) + fvm::div(phi, e) + fvc::ddt(rho, K) + fvc::div(phi, K) + fvc::div(fvc::absolute(phi/fvc::interpolate(rho), U), p, ”div(phiv,p)”) - fvm::laplacian(turbulence->alphaEff(), e) +sum[fvm::laplacian(hj*Di,m, Yi)] == fvOptions(rho, e) ); hj is the specific heat of ith species. I don't how to implement the term into the energy equation: sum[fvm::laplacian(hj*Di,m, Yi)] If someone know how to do it please let us know. |
June 21, 2016, 06:05 |
diffusion flux calculation
#88 |
Wang Wei
Rep Power: 10 |
Hi, I have a question about mass diffusion flux per specie Ji.
I found the code in multiSpeciesTransportModel.C Code:
Foam::surfaceScalarField Foam::multiSpeciesTransportModel::j ( const Foam::label i ) { return n(i) - fvc::interpolate(thermo_.composition().Y(i)) * turbulence_.phi(); } Code:
ni = yEqn().flux(); Code:
J[i]=fvc::interpolate(-rho*Dim[i])*(fvc::interpolate(fvc::grad(Yi)) & mesh.Sf()); |
June 21, 2016, 07:10 |
#89 | |
Wang Wei
Rep Power: 10 |
forAll(Y,i) { EEqn+=fvm::laplacian(hj*Dim,Y[i]); } |
June 21, 2016, 07:16 |
#90 |
Wang Wei
Rep Power: 10 |
Hi, Wang Yan, I am using version3.0 openfoam, and I am working on modifing the existing reactingFoam with adding mass diffusion model. It is hard for me to update the library.
June 21, 2016, 11:42 |
#91 |
Hi Wang Wei,
For Hj calcualtion, you can use the function in basicSpecieMixture.H: scalar Hs ( const label speciei, const scalar p, const scalar T ) const = 0; |
June 21, 2016, 12:36 |
#92 |
Wang Wei
Rep Power: 10 |
Alan, thank you for your reply. I am working on hydrogen /air combustion simulation inside a tube. Since I use version3.0 openfoam, I can't use the library post here. So I added some codes into reactingFoam solver referring to Champan-Enskog model and Fick's model. But temperature is always out of range during calculation. Which mass transport model do you use and do you have similar problem?
August 30, 2016, 18:59 |
#93 | |
David Sommer
I'm working on a very similar application looking at high temperature reforming and combustion. I am working to implement a Fickian model and a Stefan-Maxwell diffusion model that can be used with reactingFoam and/or reactingParcelFoam. I'm using Novaresio et al.'s library, with the updates from this forum, as a starting point. I am also encountering temperature issues. I find that even if remove the MSTM source terms from the heat equation that I still get extremely high temperature fluctuations even in an 'isothermal' simulation. I'm working on creating a simple "Stefan Tube" test case and associated boundary conditions to give an easy, analytically tractable, case for debugging and validation. Feel free to private message me if you would like to collaborate on this, or I will post my progress here if I start to figure out the issues. Thanks, - Dave |
October 3, 2016, 14:10 |
#94 | |
Sheikh Ahmed
Rep Power: 11 |
First of all, thanks for your work and contributing the community. I am trying to use reactingFoam to simulate one of my combustion models using OF 2.3.1. I think the test case that you provided with the multidimensional mass transport library should work excellent for my case. Since I am a new one in this business (but learning quickly ) I need your help here. I downloaded the zip that you provided. Could you tell me how can I install that new modifiedReactingFoam version with the multi library in my existing OF. The question might be silly, but please explain me in brief the procedures. Thanks a lot in advance. |
October 4, 2016, 11:23 |
Any update
#95 | |
Sheikh Ahmed
Rep Power: 11 |
Could you (or anyone) solve the energy equation problem in the library for OF version 2.3.x? Could you please share that if you are done. It would be very much helpful for the community. |
October 5, 2016, 01:47 |
Help needed to install the multicomponent library
#96 | |
Sheikh Ahmed
Rep Power: 11 |
I tried to link the multispeciesTransport library for OF 2.3.1 and ran the ./install in that zip file. Everything looks fine but I guess my library is not linked to the solver. I checked that by removing the transportProperties file from the constant folder and still the simulation runs. I also added the libs (libdiffusivityModels.so libmultispeciesTransportModels.so) in the system/controlDict. I am really confused where I messed up. Could you PLEASE help me solving it. Thanks in advance |
October 13, 2016, 23:46 |
#97 |
Yang Dali
Dear Valerio,
I canot open the pdf file after downloaded , could you send me a copy please, many thanks! my email is 18628197569@163.com |
December 5, 2016, 13:05 |
Help requested
#98 | |
Sheikh Ahmed
Rep Power: 11 |
I was wondering if you are still in touch of the multicomponent transport. I am trying to implement not a multicomponent, but a simpler 'mixture averaged' type of transport formulation. If you could successfully implement the MULT library in your work, I expect your kind help to give me some idea. I know there are some inherent flaws in the library. Please let me know. Thanks ~Sheikh Ahmed |
March 25, 2017, 13:04 |
high-temperature-problem
#99 | |
Cloudy
Hi Dave,
Have you addressed this ''incorrectly high temperature" issue? I have also found this problem is not caused by the energy equation. If you already fixed this bug, please post here. Regards, Xin Quote:
December 20, 2017, 16:53 |
#100 | |
I tried this solver, and as the other fellows mentioned, it shows extremely high temperature which is completely wrong and even it goes out of janaf! I tried another transport models, but still there is this problem. Even with different reaction mechanism still there is high temp problem. So, I think the problem is coming from coupling energy equation with Yequation. |
Species Mole and Mass Fraction Macro | combustion | FLUENT | 18 | February 5, 2024 13:23 |
UDS and fluent internal species transport model | jinsong | FLUENT | 0 | May 3, 2018 12:37 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 23:29 |
Surface instabilities with 2-phase species transport | richard222 | Fluent Multiphase | 0 | May 4, 2016 05:06 |
Questions for a species transport problems (snapshots attached) | aleisia | FLUENT | 2 | October 9, 2011 05:40 |
