January 5, 2013, 07:45 |
#261 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi
It looks as if it cannot find the header files in waves2Foam/src/lnInclude. Maybe the relative path from the utilities should be defined differently in CAELinux? Even though it does not make sense, since waveFoam is compiled. Well, nonetheless, I believe you should completely delete the version (or rename) you have on your computer and then do a completely fresh checkout as stated on the wiki (http://openfoamwiki.net/index.php/Contrib/waves2Foam) Regards, Niels |
January 5, 2013, 13:07 |
#262 |
carlos
Rep Power: 15 |
I have compiled in a different instalation (OF 210) and managed to get waveFoam working, but faild on some pre and post processing due to missing files. What I need is a clean and complete package for waves2Foam. Where can I download it? I have tried sourceforge but can not find it. Thanks once again! Carlos. |
January 5, 2013, 13:24 |
#263 |
Rep Power: 37 |
Please read the "Download and Installation" section on the Wiki, which I linked above.
- Niels |
January 5, 2013, 13:42 |
#264 |
carlos
Rep Power: 15 |
Thanks Niels, I have found it, downloaded and it went like a charm.
Very sorry for taking your time due to my ignorance. Best, Carlos. |
January 5, 2013, 13:45 |
#265 |
Rep Power: 37 |
You are welcome. I have to agree with you that it confuses the matter that a static (read: "old") and altered version of waves2Foam is floating around.
Well, now it has been documented and can be read by all other potential users. Kind regards, Niels |
January 6, 2013, 18:34 |
#266 |
Mohammad Ghandali
Rep Power: 13 |
Hi Dear Niels
first i appreciate of your works and your academic personality . im very begginer in openfoam read the openfoam wiki instruction of waves2foam installation But when i run allwmake in terminal i found these in terminal is it normal? '/home/mohammad/OpenFOAM/mohammad-2.0.1/platforms/linux64GccDPOpt/lib/libwaves2Foam.so' is up to date. ./Allwmake: line 47: cd: applications/solvers/solvers201: No such file or directory make[1]: Entering directory `/home/mohammad/projects/waves2Foam/applications/utilities/misc' make[2]: Entering directory `/home/mohammad/projects/waves2Foam/applications/utilities/misc/matlab' make[3]: Entering directory `/home/mohammad/projects/waves2Foam/applications/utilities/misc/matlab/postprocessing' make[3]: Nothing to be done for `application'. make[3]: Leaving directory `/home/mohammad/projects/waves2Foam/applications/utilities/misc/matlab/postprocessing' make[3]: Entering directory `/home/mohammad/projects/waves2Foam/applications/utilities/misc/matlab/preprocessing' make[3]: Nothing to be done for `application'. make[3]: Leaving directory `/home/mohammad/projects/waves2Foam/applications/utilities/misc/matlab/preprocessing' make[2]: Leaving directory `/home/mohammad/projects/waves2Foam/applications/utilities/misc/matlab' make[1]: Leaving directory `/home/mohammad/projects/waves2Foam/applications/utilities/misc' make[1]: Entering directory `/home/mohammad/projects/waves2Foam/applications/utilities/postProcessing' make[2]: Entering directory `/home/mohammad/projects/waves2Foam/applications/utilities/postProcessing/surfaceElevation' make[2]: `/home/mohammad/OpenFOAM/mohammad-2.0.1/platforms/linux64GccDPOpt/bin/surfaceElevation' is up to date. make[2]: Leaving directory `/home/mohammad/projects/waves2Foam/applications/utilities/postProcessing/surfaceElevation' make[1]: Leaving directory `/home/mohammad/projects/waves2Foam/applications/utilities/postProcessing' make[1]: Entering directory `/home/mohammad/projects/waves2Foam/applications/utilities/preProcessing' make[2]: Entering directory `/home/mohammad/projects/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make[2]: `/home/mohammad/OpenFOAM/mohammad-2.0.1/platforms/linux64GccDPOpt/bin/relaxationZoneLayout' is up to date. make[2]: Leaving directory `/home/mohammad/projects/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make[2]: Entering directory `/home/mohammad/projects/waves2Foam/applications/utilities/preProcessing/setWaveField' make[2]: `/home/mohammad/OpenFOAM/mohammad-2.0.1/platforms/linux64GccDPOpt/bin/setWaveField' is up to date. make[2]: Leaving directory `/home/mohammad/projects/waves2Foam/applications/utilities/preProcessing/setWaveField' make[2]: Entering directory `/home/mohammad/projects/waves2Foam/applications/utilities/preProcessing/setWaveParameters' make[2]: `/home/mohammad/OpenFOAM/mohammad-2.0.1/platforms/linux64GccDPOpt/bin/setWaveParameters' is up to date. make[2]: Leaving directory `/home/mohammad/projects/waves2Foam/applications/utilities/preProcessing/setWaveParameters' make[1]: Leaving directory `/home/mohammad/projects/waves2Foam/applications/utilities/preProcessing' p.s: when i run wave flume tutorial i run blockmesh and it works when i run parafoam i suddenly get out and disapeared.. beforehand thank you for your helping Mohammad |
January 7, 2013, 04:54 |
#267 |
Rep Power: 37 |
Hi Mohammed,
Yes, it looks correct - congrats with the painless compilation With respect to the crashing of paraFoam, it sounds like a problem, which I have heard about before, however, I have no means of helping with that. I advise you to search the Forum (using Google ) Kind regards, Niels |
January 7, 2013, 08:30 |
#268 |
Mohammad Ghandali
Rep Power: 13 |
Hi again Dear niels
thanks for your quick answer..and time you spent on my post i run wave flume tutorials and i run blockMesh and then run setWaveField in terminal and i get this error and i dont know how to debug it.. mohammad@mohammad-desktop:~$ cd /home/mohammad/Desktop/waveFlume mohammad@mohammad-desktop:~/Desktop/waveFlume$ blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : blockMesh Date : Jan 07 2013 Time : 04:01:15 Host : mohammad-desktop PID : 10052 Case : /home/mohammad/Desktop/waveFlume nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/mohammad/Desktop/waveFlume/constant/polyMesh/blockMeshDict" Creating curved edges Creating topology blocks Creating topology patches Reading patches section Creating block mesh topology Reading physicalType from existing boundary file Default patch type set to empty Check topology Basic statistics Number of internal faces : 0 Number of boundary faces : 6 Number of defined boundary faces : 6 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale 1 Writing polyMesh ---------------- Mesh Information ---------------- boundingBox: (0 -0.4 0) (18 0.2 0.1) nPoints: 43676 nCells: 21420 nFaces: 86097 nInternalFaces: 42423 ---------------- Patches ---------------- patch 0 (start: 42423 size: 60) name: inlet patch 1 (start: 42483 size: 357) name: bottom patch 2 (start: 42840 size: 60) name: outlet patch 3 (start: 42900 size: 357) name: atmosphere patch 4 (start: 43257 size: 42840) name: frontBack End mohammad@mohammad-desktop:~/Desktop/waveFlume$ setWaveField /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : setWaveField Date : Jan 07 2013 Time : 04:02:14 Host : mohammad-desktop PID : 10060 Case : /home/mohammad/Desktop/waveFlume nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 --> FOAM FATAL IO ERROR: cannot open file file: /home/mohammad/Desktop/waveFlume/system/fvSchemes at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 87. FOAM exiting PLease Help me Best Regards Mohammed |
January 7, 2013, 15:55 |
#269 |
Rep Power: 37 |
Dear Mohammed,
Please execute the "Allrun" script as Code:
./Allrun Kind regards, Niels |
January 11, 2013, 04:25 |
#270 |
Harrif
Dear Foamers,
I am curious whether any of you guys have successfully implemented turbulence models with density for waves2foam? I am simulating regular waves (without current yet) for laminar and eventually turbulent flows in waves2foam. I tried to include density in the standard k - epsilon (in OF 1.7.1), in the form of rho_ and rhoPhi in each term of k and epsilon transport equations, but the resultant wave height gets even more dampen (much quicker) than the normal density-normalised k - epsilon model. This is because of excessive production of k, epsilon and eventually nut which grow over the time. See the attached surface elevation profile for laminar, density-normalised turbulence and turbulence with density models. Perhaps you guys can shed some light about the proper implementation procedure? Thanks! Niels, I got a question about the new k - omega model in your paper, equation (6) and (7). I realised there is missing rho in beta term, sigma_d term of the omega equation and betaStar term of the k equation. Is this typo or there is no rho for some reason? Thanks! Cheers, Harrif |
January 11, 2013, 05:27 |
#271 |
Rep Power: 37 |
Dear Harrif,
Thanks for pointing out the missing rho's (there are actually more of them in eq. (6) and (7), and I am really embarrassed with that!). With respect to the turbulence modelling, I found that it is very important to treat the production term correctly. The problem with production terms based on the strain tensor is that production will be non-zero in a potential flow field, which by definition is irrotational! Therefore Mayer and Madsen (2000) suggested to use the curl of the velocity field instead. I have also had successes with this type of formulation in k-omega models. Kind regards Niels Mayer S, Madsen PA. Simulation of breaking waves in the surf zone using a Navier–Stokes solver. Proceeding to Coastal Engineering Conference 2000; I:928–941. |
January 14, 2013, 07:25 |
dynamic mesh
#272 |
Ed Ransley
Rep Power: 14 |
Dear waves2Foamers,
I'm struggling to get the waveDyMFoam solver to work. I have followed the instructions on the wiki to couple interDymFoam with waves2Foam but when the solver tries to refine the mesh is crashes. Has anyone got the dynamic mesh to work? Any help would be much appreciated. The terminal gives the following: /opt/openfoam211/bin/tools/RunFunctions: line 37: 3280 Segmentation fault (core dumped) $APP_RUN $* > log.$APP_NAME 2>&1 The log file give this (after the usual preliminaries) Starting time loop Interface Courant Number mean: 6.86629e-05 max: 0.0102554 Courant Number mean: 0.00296173 max: 0.010832 deltaT = 0.00116279 Time = 0.00116279 Selected 3740 cells for refinement out of 75000. Refined from 75000 to 101180 cells. #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::dynamicRefineFvMesh::refine(Foam::List<int> const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libdynamicFvMesh.so" #4 Foam::dynamicRefineFvMesh::update() in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libdynamicFvMesh.so" #5 in "/home/eransley/OpenFOAM/eransley-2.1.1/platforms/linuxGccDPOpt/bin/waveDyMFoam" #6 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #7 in "/home/eransley/OpenFOAM/eransley-2.1.1/platforms/linuxGccDPOpt/bin/waveDyMFoam" I'm no expert but I think it must be something to do with the refinement as if the initial number of cells are purposely over the max cell number it runs fine. Thanks a lot, Ed. |
January 14, 2013, 11:05 |
#273 |
Rep Power: 37 |
Hi Ed,
Have you tried running the case with interDymFoam, i.e. without the coupling to waves2Foam? This would be a nice way to verify whether it is an error exclusively related to the mesh refinement or whether waves2Foam also cause problems. Kind regards, Niels |
January 14, 2013, 12:15 |
#274 |
Ed Ransley
Rep Power: 14 |
Hi Niels,
I have set up the case by changing the boundary types in 0/alpha.org and 0/U.org from waveAlpha and waveVelocity to fixedValues and used a setFieldsDict to set the fields without using setWaveFields. Then using interDymFoam it crashes at the same point (when trying to make the first refinement) so It must be something to do with my case. I have run the damBreakWithObstacle tutorial and it runs fine and the refinement works. Any hints on setting up a Dynamic mesh case that I may have over looked? |
January 14, 2013, 16:09 |
#275 |
Rep Power: 37 |
Hi Ed,
No, I have never used the dynamic refinement. But some else might? Kind regards, Niels |
January 15, 2013, 12:04 |
#276 |
Ed Ransley
Rep Power: 14 |
Niels,
I've now managed to solve the dynamic mesh issues I was having it was a combination of empty boundary types don't work and a slight alteration to the fvSolution file. The details can be found in these two posts (below). I'd like to thank Adriaan Steenkamp for the help. http://www.cfd-online.com/Forums/ope...tml#post401945 http://www.cfd-online.com/Forums/ope...erdymfoam.html I'm now having another issue: I'm trying to install waves2Foam on a cluster and when performing the SVN to sourceforge from the wiki site I get an error saying that it cannot find the code. Is the wiki up to date, has anyone got any tips to get waves2Foam on a cluster. I'm really out of my depth with HPC stuff, any help would be great. Thanks, Ed |
January 15, 2013, 17:25 |
#277 |
Rep Power: 37 |
Hi Ed,
Congrats on the successful refinement The SVN is currently down (see: http://openfoamwiki.net/index.php/Main_Page), so I suggest that you merely copy the files you have on your own computer to the cluster. Kind regards, Niels |
January 16, 2013, 10:24 |
#278 |
Ed Ransley
Rep Power: 14 |
Hi Niels,
Thanks for the info. I've done as you said and copied my waves2Foam folder from my desktop to the cluster but I'm having some problems making it on the cluster. Is there a specific place the folder needs to be to run the Allwmake command? I tried having waves2Foam in opt/OpenFoam/ as I want the libraries to be available to multiple users but I get lots of 'no rule to make target issues? Any tips on how to resolve this? Thanks a lot Ed The terminal read out I got is below: [root@fotcluster1 waves2Foam]# ./Allwmake > w2f.txt make[1]: Entering directory `/opt/OpenFOAM/waves2Foam/applications/utilities/misc' make[2]: Entering directory `/opt/OpenFOAM/waves2Foam/applications/utilities/misc/matlab' make[3]: Entering directory `/opt/OpenFOAM/waves2Foam/applications/utilities/misc/matlab/postprocessing' make[3]: Nothing to be done for `application'. make[3]: Leaving directory `/opt/OpenFOAM/waves2Foam/applications/utilities/misc/matlab/postprocessing' make[3]: Entering directory `/opt/OpenFOAM/waves2Foam/applications/utilities/misc/matlab/preprocessing' make[3]: Nothing to be done for `application'. make[3]: Leaving directory `/opt/OpenFOAM/waves2Foam/applications/utilities/misc/matlab/preprocessing' make[2]: Leaving directory `/opt/OpenFOAM/waves2Foam/applications/utilities/misc/matlab' make[1]: Leaving directory `/opt/OpenFOAM/waves2Foam/applications/utilities/misc' make[1]: Entering directory `/opt/OpenFOAM/waves2Foam/applications/utilities/postProcessing' make[2]: Entering directory `/opt/OpenFOAM/waves2Foam/applications/utilities/postProcessing/surfaceElevation' make[2]: Leaving directory `/opt/OpenFOAM/waves2Foam/applications/utilities/postProcessing/surfaceElevation' make[1]: Leaving directory `/opt/OpenFOAM/waves2Foam/applications/utilities/postProcessing' make[1]: Entering directory `/opt/OpenFOAM/waves2Foam/applications/utilities/preProcessing' make[2]: Entering directory `/opt/OpenFOAM/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make[2]: Leaving directory `/opt/OpenFOAM/waves2Foam/applications/utilities/preProcessing/relaxationZoneLayout' make[2]: Entering directory `/opt/OpenFOAM/waves2Foam/applications/utilities/preProcessing/setWaveField' make[2]: Leaving directory `/opt/OpenFOAM/waves2Foam/applications/utilities/preProcessing/setWaveField' make[2]: Entering directory `/opt/OpenFOAM/waves2Foam/applications/utilities/preProcessing/setWaveParameters' make[2]: Leaving directory `/opt/OpenFOAM/waves2Foam/applications/utilities/preProcessing/setWaveParameters' make[1]: Leaving directory `/opt/OpenFOAM/waves2Foam/applications/utilities/preProcessing' make: *** No rule to make target `lnInclude/sampledSurfaceElevation.H', needed by `sampling/sampledSurfaceElevationFunctionObject/sampledSurfac$ ./Allwmake: line 47: cd: applications/solvers/solvers200: No such file or directory make[2]: *** No rule to make target `../../../../src/lnInclude/IOsampledSurfaceElevation.H', needed by `surfaceElevation.dep'. make[2]: *** No rule to make target `../../../../src/lnInclude/sampledSurfaceElevation.H', needed by `surfaceElevation.dep'. make[2]: *** No rule to make target `/opt/OpenFOAM/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude/sigWriteNow.H', needed by `surfaceElevation.de$ make[2]: *** No rule to make target `/opt/OpenFOAM/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude/sigStopAtWriteNow.H', needed by `surfaceElevat$ make[2]: *** No rule to make target `../../../../src/lnInclude/sampledSurfaceElevationTemplates.C', needed by `surfaceElevation.dep'. make[2]: *** No rule to make target `../../../../src/lnInclude/readWaveProperties.H', needed by `surfaceElevation.dep'. make[2]: Failed to remake makefile `surfaceElevation.dep'. make[2]: Target `/root/OpenFOAM/root-2.0.x/platforms/linux64Gcc45DPOpt/bin/surfaceElevation' not remade because of errors. make[1]: *** [surfaceElevation] Error 2 make[1]: Target `application' not remade because of errors. make: *** [postProcessing] Error 2 make[2]: *** No rule to make target `/opt/OpenFOAM/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude/sigWriteNow.H', needed by `relaxationZoneLayou$ make[2]: *** No rule to make target `/opt/OpenFOAM/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude/sigStopAtWriteNow.H', needed by `relaxationZon$ make[2]: *** No rule to make target `../../../../src/lnInclude/relaxationShape.H', needed by `relaxationZoneLayout.dep'. make[2]: *** No rule to make target `../../../../src/lnInclude/relaxationWeight.H', needed by `relaxationZoneLayout.dep'. make[2]: *** No rule to make target `../../../../src/lnInclude/relaxationWeightCourantCorrection.H', needed by `relaxationZoneLayout.dep'. make[2]: *** No rule to make target `../../../../src/lnInclude/readWaveProperties.H', needed by `relaxationZoneLayout.dep'. make[2]: Failed to remake makefile `relaxationZoneLayout.dep'. make[2]: Target `/root/OpenFOAM/root-2.0.x/platforms/linux64Gcc45DPOpt/bin/relaxationZoneLayout' not remade because of errors. make[1]: *** [relaxationZoneLayout] Error 2 make[2]: *** No rule to make target `/opt/OpenFOAM/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude/sigWriteNow.H', needed by `setWaveField.dep'. make[2]: *** No rule to make target `/opt/OpenFOAM/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude/sigStopAtWriteNow.H', needed by `setWaveField.$ make[2]: *** No rule to make target `../../../../src/lnInclude/setWaveField.H', needed by `setWaveField.dep'. make[2]: *** No rule to make target `../../../../src/lnInclude/convexPolyhedral.H', needed by `setWaveField.dep'. make[2]: *** No rule to make target `../../../../src/lnInclude/localFace.H', needed by `setWaveField.dep'. make[2]: *** No rule to make target `../../../../src/lnInclude/localCell.H', needed by `setWaveField.dep'. make[2]: *** No rule to make target `../../../../src/lnInclude/localCellNeg.H', needed by `setWaveField.dep'. make[2]: Failed to remake makefile `setWaveField.dep'. make[2]: Target `/root/OpenFOAM/root-2.0.x/platforms/linux64Gcc45DPOpt/bin/setWaveField' not remade because of errors. make[1]: *** [setWaveField] Error 2 make[2]: *** No rule to make target `/opt/OpenFOAM/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude/sigWriteNow.H', needed by `setWaveParameters.d$ make[2]: *** No rule to make target `/opt/OpenFOAM/OpenFOAM-2.0.x/src/OSspecific/POSIX/lnInclude/sigStopAtWriteNow.H', needed by `setWaveParame$ make[2]: *** No rule to make target `../../../../src/lnInclude/setWaveProperties.H', needed by `setWaveParameters.dep'. make[2]: Failed to remake makefile `setWaveParameters.dep'. make[2]: Target `/root/OpenFOAM/root-2.0.x/platforms/linux64Gcc45DPOpt/bin/setWaveParameters' not remade because of errors. make[1]: *** [setWaveParameters] Error 2 make[1]: Target `application' not remade because of errors. make: *** [preProcessing] Error 2 make: Target `application' not remade because of errors. |
January 16, 2013, 11:05 |
#279 |
Rep Power: 37 |
Hi Ed,
Did you make a Code:
wclean all Kind regards, Niels |
January 19, 2013, 05:59 |
#280 | |
Mohammad Ghandali
Rep Power: 13 |
i try to run waveflume tutorials and i execute ./Allrun script and then i run blockMesh and its ok and then run setWaveField and it runs ok when i run the solver waveFoam in terminal it says command not found and also i try with interFoam in terminal then i get this error | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : interFoam Date : Jan 20 2013 Time : 14:36:42 Host : mohammad-desktop PID : 3570 Case : /home/mohammad/Desktop/waveFlume nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 // using new solver syntax: pcorr { solver GAMG; tolerance 1e-07; relTol 0; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } // using new solver syntax: p_rgh { solver GAMG; tolerance 1e-07; relTol 0; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } // using new solver syntax: p_rghFinal { solver GAMG; tolerance 1e-08; relTol 0; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } // using new solver syntax: U { solver PBiCG; preconditioner DILU; tolerance 1e-09; relTol 0; } // using new solver syntax: UFinal { solver PBiCG; preconditioner DILU; tolerance 1e-09; relTol 0; } // using new solver syntax: gamma { solver PBiCG; preconditioner DILU; tolerance 1e-07; relTol 0; } PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field alpha1 --> FOAM FATAL IO ERROR: Unknown patchField type waveAlpha for patch type patch Valid patchField types are : 69 ( advective alphaFixedPressure atmBoundaryLayerInletEpsilon buoyantPressure calculated codedFixedValue constantAlphaContactAngle cyclic cyclicSlip directMapped directMappedField directMappedFixedInternalValue directMappedFixedPushedInternalValue directionMixed dynamicAlphaContactAngle empty epsilonWallFunction fan fanPressure fixedFluxPressure fixedGradient fixedInternalValue fixedPressureCompressibleDensity fixedValue freestream freestreamPressure inletOutlet inletOutletTotalTemperature kappatJayatillekeWallFunction kqRWallFunction mixed nonuniformTransformCyclic nuSgsUSpaldingWallFunction nutLowReWallFunction nutTabulatedWallFunction nutURoughWallFunction nutUSpaldingWallFunction nutUWallFunction nutkRoughWallFunction nutkWallFunction omegaWallFunction oscillatingFixedValue outletInlet outletMappedUniformInlet partialSlip processor processorCyclic rotatingTotalPressure selfContainedDirectMapped sliced slip symmetryPlane syringePressure timeVaryingAlphaContactAngle timeVaryingMappedFixedValue timeVaryingTotalPressure timeVaryingUniformFixedValue totalPressure totalTemperature turbulentHeatFluxTemperature turbulentInlet turbulentIntensityKineticEnergyInlet turbulentMixingLengthDissipationRateInlet turbulentMixingLengthFrequencyInlet uniformDensityHydrostaticPressure uniformFixedValue waveTransmissive wedge zeroGradient ) file: /home/mohammad/Desktop/waveFlume/0/alpha1::boundaryField::inlet from line 21450 to line 21518. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /home/opencfd/OpenFOAM/OpenFOAM-2.0.1/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 135. FOAM exiting please help me like always i thank you for your best helping king regards |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
Re-Project topics | protocol | STAR-CCM+ | 0 | March 22, 2016 05:25 |
Waves2Foam Related Topics | seoseonguk | OpenFOAM Running, Solving & CFD | 0 | March 1, 2016 22:18 |
Waves2Foam Related Topics | seoseonguk | OpenFOAM Running, Solving & CFD | 0 | March 1, 2016 22:14 |
Error: "Cannot find file points" related to changing parallelized code to serial? | Suyf | OpenFOAM Running, Solving & CFD | 0 | February 12, 2015 04:31 |
