December 6, 2024, 08:12 |
Instalation problems on 22.0
radin hosseini
Rep Power: 9 |
I have compiled solid4Foam on an Ubuntu 22.04.4 machine where OF9.0 in installed on it. the compilation was completed and then when I run the ./Alltest.
From the msg on the screen I see that all the tutorials were okay except two. this is the msg: Summary statistics Number of cases where a run was attempted: 39 Number of cases where the solver failed: 2 Number of cases where another command failed: 0 The solids4Foam solver failed in the following cases: Application solids4Foam - case beamInCrossFlow: ** ERROR ** Application solids4Foam - case flexibleDamBreak: ** ERROR ** Since I actually need the flexoibledambreak one, I was wondering what can be the cause for this problem and how to solve it. |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 12:12 |
[mesh manipulation] Problems with rotational cyclic boundaries | TReviol | OpenFOAM Meshing & Mesh Conversion | 8 | July 11, 2014 04:45 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 07:44 |
Two-phase air water flow problems by activating Wall Lubrication Force | challenger85 | CFX | 5 | November 5, 2009 06:44 |
Help required to solve Hydraulic related problems | aero | CFX | 0 | October 30, 2006 12:00 |
