November 28, 2024, 13:03 |
compiling error
Rep Power: 2 |
I'm trying to compile solids4foam in linux cluster and local windows sub linux system (WSL), but I got some errors, I wonder if anyone has any ideas what it could be. Thanks in advance!! I was able to follow the installation guide and install all the dependencies in WSL for local desktop, and compiled solids4foam with no errors. But when I ran Alltest, there were cases failed. See attached WSL_1, WSL_2 screenshots. If I try to compile it in cluster, the compiler throw me errors, and Alltest failed many cases too. See attached cluster_1, cluster_2. I have loaded all the dependency modules, but I'm not sure what happened. The OpenFOAM I'm using is OpenFOAM-v2312, which is the latest that is supported by solids4Foam. The main problem I have right now is to compile solids4Foam to the cluster so I can run simulation from there. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 07:25 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 06:07 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
