September 22, 2024, 14:52 |
Use Turbulence Models in Solids4Foam
Andy Valdés
Rep Power: 2 |
Is it possible to use turbulence models in solids4foam, e.g. RANS or even LES? The question is because the first version of solidsfoam included the use of turbulence, I wonder if it has been removed because it is unstable or something similar. If not, I would consider using preCICE, however in that case I would like to know which version of preCICE is compatible.
Kind regards, Andy. |
wall y+ and turbulence models | narayanan | FLUENT | 1 | May 13, 2019 10:18 |
Validation of homogeneous turbulence with constant shear for RANS models | GeorgS | OpenFOAM Running, Solving & CFD | 2 | August 30, 2018 15:11 |
Adding turbulence models to (reacting)TwoPhaseEulerFoam | lavdwall | OpenFOAM Running, Solving & CFD | 0 | February 3, 2017 03:04 |
y+ range for turbulence models | babri | FLUENT | 1 | August 30, 2016 17:39 |
in k-epsilon wall function approach high Re turbulence models: question of velocity | romant | OpenFOAM Programming & Development | 6 | May 26, 2016 09:14 |
