[solids4Foam] Using Temperature-dependent thermal constants with Thermo-Elasticity Model? |
August 26, 2024, 03:45 |
Christian Ernst
as the question is implying i would like to use the Code:
thermoLinearElastic Example from hotSphere Tutorial in 0/T Code:
inside { type fixedTemperature; temperatureSeries { fileName "$FOAM_CASE/constant/timeVsTemperature"; outOfBounds clamp; } value uniform 300; } Code:
thermal { type constant; C C [0 2 -2 -1 0 0 0] 486; k k [1 1 -3 -1 0 0 0] 20; } With kind regards Christian |
dependent variable, material constant, thermallaw, thermalproperties |
Temperature Dependent Thermal Properties in LaplacianFoam | Akram_ | Main CFD Forum | 9 | January 7, 2022 00:59 |
Temperature dependent thermal conductivity and specific heat Property of mixture of t | rohan@123 | FLUENT | 0 | April 17, 2020 10:34 |
Adding new temperature dependent viscosity model | vabishek | OpenFOAM Programming & Development | 3 | May 15, 2016 21:05 |
Radiation Modeling | Chris89 | CFX | 20 | August 14, 2014 07:51 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
