[solids4Foam] Building Rotating Mesh in Solids4Foam |
jack riordan
Rep Power: 0 ![]() |
I am trying to build a model of a vertical axis wind turbin, I have ran FSI with strong coupling ,it converges, on the static blade. I have also ran a CFD analysis and performance model on the rotating blade using an AMI and rotating zone condition. I am trying to find a method to rotate the mesh like in the CFD and use the FSI solver but cannot figure out how or find any examples online. Has anyone completed a similar case or have anyone any suggestions how to format the dynamic mesh dict to handle both these motions.
fsi 2-way coupling, fsi dynamicmeshdict, solids4foam |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 14:56 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Compilation error OF1.5-dev on Suse10.3 | darenyang | OpenFOAM Installation | 0 | April 29, 2009 04:55 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
