Simon
Rep Power: 0 ![]() |
I'm having issues installing solids4foam following the instructions on https://www.solids4foam.com/installa...romSource.html I'm very new to openFOAM and WSL so it's likely I'm missing something simple ![]() I have followed these steps: - Starting with fresh Ubuntu Install (WSL) - Install openFOAM - v2012 following instructions here: https://develop.openfoam.com/Develop...ompiled/debian - Add openFOAM source to ~/bashrc with the following Code:
source /usr/lib/openfoam/openfoam2012/etc/bashrc Code:
sudo apt install petsc-dev Code:
export PETSC_DIR = /usr/lib/petscdir - install gfortran with Code:
sudo apt-get install gfortran Code:
sudo apt-get install gnuplot Code:
git clone --branch v2.0 https://github.com/solids4foam/solids4foam.git Code:
cd solids4foam ./Allwmake -j 2>&1 | tee log.Allwmake Any help is very much appreciated. |
Ivan Batistić
Rep Power: 3 ![]() |
You have a problem with petsc during compilation. Skip the installation of petsc ( do not set PETSC_DIR variable) and try again.
Simon
Thank Ivan, that appears to have done the trick.
chtMultiRegionFoam not writing any results but not giving any errors | lmw354 | OpenFOAM Running, Solving & CFD | 5 | August 29, 2021 03:04 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
