Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
Transferring Total stress of FS-Interface
Old   December 26, 2023, 11:26
Default Transferring Total stress of FS-Interface
Dorian
Dorian90 is on a distinguished road
Hello Foamers,
I want to Total Fluid viscous (isotropic or hydro stress [-p*I] and anisotropic or deviatoric stress [sigmaFluid = 2*nuf*dev(symm(fvc::grad(U)))] on the Fluid-Solid Interface patches.
I am not sure how to code the face normals and transfer the total fluid stress on the interfaces to account for the dynamic condition at FS-Interface.
Fluid-Solid interface patches :
patch consoleFluid (in Blue)
( (7 6 2 3) (0 1 5 4) )
patch outlet
( (1 5 6 2) )
patch consoleSolid (in Red)
( (8 9 21 20) (23 22 10 11) )
patch midNotch
( (9 10 22 21) )
So, here are my questions:
1. Since i will have 3 face normals ( 2 face normals from patch consoleFluid/consoleSolid) and one face normal (oulet/midNotch), I have tried to proceed as below but having some errors.
// Solid Domain
label consoleSolidPatchID = stressMesh.boundaryMesh().findPatchID("consoleSoli d");
label midNotchPatchID = stressMesh.boundaryMesh().findPatchID("midNotch");
// Fluid Domain
label consoleFluidPatchID = mesh.boundaryMesh().findPatchID("consoleFluid");
label outletPatchID = mesh.boundaryMesh().findPatchID("outlet");
vectorField faceNormal1 = (stressMesh.Sf().boundaryField()[consoleSolidPatchID])
/(stressMesh.magSf().boundaryField()[consoleSolidPatchID]);
vectorField faceNormal2 = (stressMesh.Sf().boundaryField()[midNotchPatchID])
/(stressMesh.magSf().boundaryField()[midNotchPatchID]);
symmTensorField solidPatchTraction1 =
interpolatorFluidSolid.faceInterpolate
(sigmaFluid.boundaryField()[consoleFluidPatchID])
symmTensorField solidPatchTraction2 =
(sigmaFluid.boundaryField()[outletPatchID])
solidPatchTraction1 *= rho.value();
solidPatchTraction2 *= rho.value();
tForce.traction() = (solidPatchTraction1 & faceNorma11) + (solidPatchTraction2 & faceNormal2);
My code crashes at this point with the following error :
--> FOAM FATAL ERROR:
given field does not correspond to patch. Patch size: 20 field size: 10
From function PatchToPatchInterpolation::faceInterpolate(const Field<Type> ff)
in file /home/user/foam/foam-extend-5.0/src/foam/lnInclude/PatchToPatchInterpolate.C at line 128.
b. Can I do this for the traction vector calculation?
vectorField tractionVector1 =
(sigmaFluid.boundaryField()[consoleFluidPatchID] & faceNormal1)
vectorField tractionVector2 =
(sigmaFluid.boundaryField()[outletPatchID] & faceNormal2)
vector totalTractionForce =
sum
tractionVector1*rho.value()
+ tractionVector2*rho.value()
Info << "Total traction force = " << totalTractionForce << endl;
c. Please, where does the totalTractionForce is used in the solver? Because I can’t figure out. Is it in the tractionDisplacement BC code? If yes, how? Because I can’t see the linkage...
d. Finally, when we have the code below:
scalarField solidPatchPressure =
p.boundaryField()[fluidPatchID]
solidPatchPressure *= rhoFluid.value();
tForce.pressure() = solidPatchPressure;
vector totalPressureForce =
sum
p.boundaryField()[fluidPatchID]*rhoFluid.value()*
(mesh.Sf().boundaryField()[fluidPatchID])/(mesh.magSf().boundaryField()[fluidPatchID])
Info << "Total pressure force = " << totalPressureForce << endl;
where does the totalPressureForce is used in the solver? Because I can’t figure out. Is it in the tractionDisplacement BC code? If yes, how? Because I can’t see the linkage...
Thank You.
Dorian90 is offline   Reply With Quote
Calculating source term total cell-zone volume parallel computation RobV Fluent UDF and Scheme Programming 2 May 30, 2022 04:46
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
How to use the CFX periodic interface zhihuawan CFX 61 January 15, 2018 17:20
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
