[solids4Foam] How to apply a constant force on a solid during solids4foam fluid-structure coupling? |
ysh
Rep Power: 3 ![]() |
When conducting fluid-structure coupling simulations for a flexible cylinder, I've been trying to apply a tensile force on the top surface of the solid using the "solidTraction" boundary condition in the solid solver's initial conditions. However, the calculation quickly diverges (it runs well when the top surface is set to "fixedDisplacement"). Could you please advise on how to apply a tensile force on the top surface of the cylinder?
Any suggestions would be greatly appreciated! |
Ivan Batistić
Can you provide more information about the boundary conditions and geometry of your case? If the solid does not have a prescribed displacement on any patch, this may cause the problem (the body is floating in space - that's why it can converge when you prescribe it).
solids4Foam & FOAM-FSI | farah.elias | OpenFOAM | 21 | August 28, 2023 15:57 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
coupling solid and fluid cells?? | kcg | Siemens | 4 | March 13, 2007 09:39 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
