Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solids4Foam] Unusual error: " fromField is the wrong size! "
Old   September 19, 2023, 16:04
Default Unusual error: " fromField is the wrong size! "
thegauravonline's Avatar
GS
thegauravonline is on a distinguished road
Hello members,
I'm currently working on setting up a case that features a flap positioned perpendicularly under flow, anchored at its center. You can view the setup here: https://imgur.com/a/PNNWIAb.
Configuration Details:
1. Geometry & Mesh:
I've created two solid blocks stacked atop one another. Their faces overlap, primarily because I wasn't able to assign boundary conditions on the internal face of the solid.
2. Meshing: The `blockMesh` ran successfully for both fluid and solid regions, maintaining conformity and yielding no errors.
Problem:
When I attempt to run `solids4Foam`, I encounter a unique error, one I haven't faced before:
--> FOAM FATAL ERROR:
fromField size: 244, fromZone size: 240
From function void Foam::interfaceToInterfaceMapping::checkFieldSizes
    const label fromFieldSize, const label toFieldSize
) const
in file fluidSolidInterfaces/fluidSolidInterface/interfaceToInterfaceMapping/interfaceToInterfaceMapping/interfaceToInterfaceMapping.C at line 104.
FOAM aborting
Aborted (core dumped)
I suspect the overlapped faces in the middle of the solid might be the cause. However, I'm struggling to devise a solution.
Software Details:
- Solver: `solids4Foam`
- Version: foam-extend 4.1
- Reworking the tutorial case `HronTurekFsi3' in solid4Foam tutorial.
I'd deeply appreciate any guidance from those who have faced similar issues or have insights into this particular error. Any pointers to help me rectify this would be invaluable!
Thank you in advance!
thegauravonline is offline   Reply With Quote
Is it possible to use Eulerrian-Eulerian with large bubble size Tleja FLUENT 0 January 13, 2018 23:25
udf error srihari FLUENT 1 October 31, 2016 15:18
meshing of a compound volume in GMSH shawn3531 OpenFOAM 4 March 12, 2015 11:45
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 05:35
[ICEM] Meshing Size Problem eRzBeNgEl ANSYS Meshing & Geometry 2 April 17, 2011 16:53
