[solids4Foam] solids4Foam with 5.0 - parallel issue |
Nicolas FORESTAL
Rep Power: 3 ![]() |
Hi !
I compile solid4Foam on FOAM-Extend 5.0, the work fine in sequential but I have some issues with the parallel I attach my log file to the tread If someone have an idea of the problem Thanks Bye |
Philip Cardiff
Rep Power: 34 ![]() ![]() |
Hi Nicolas,
Feel free to create an issue at https://github.com/solids4foam/solids4foam; also, feel free to propose a solution ![]() Philip |
[mesh manipulation] Issue with stitchMesh for parallel case | MarcusAng | OpenFOAM Meshing & Mesh Conversion | 1 | June 13, 2023 07:47 |
[OpenFOAM.com] Multiple Installation Issue: Parallel Processing No Longer Works | dancfd | OpenFOAM Installation | 11 | November 20, 2018 16:08 |
Issue with UDF in parallel processing | MC1 | FLUENT | 5 | August 29, 2017 03:17 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
