Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[solids4Foam] Boundary Conditions for Simulating a Fixed Cylinder Rotating in a Flow Regime
Old   May 4, 2023, 09:52
Post Boundary Conditions for Simulating a Fixed Cylinder Rotating in a Flow Regime
Lekh India
lekhindia is on a distinguished road
I want to simulate a fixed cylinder in a flow regime that rotates due to fluid forces around its own axis. I am unsure of the appropriate boundary conditions to specify for this simulation. Although I have been able to simulate the cylinder's free translation, but I have not found a specific boundary condition for fixing the cylinder at its axis using the solids4foam software. further simulation will be stop due to meshing. a screenshot for reference. https://drive.google.com/file/d/1l_M...oJCDmuWqr/view
lekhindia is offline   Reply With Quote
Old   June 15, 2023, 05:12
Franco
fconcli is on a distinguished road
Can you kindly post the case-files?
fconcli is offline   Reply With Quote
fsi mesh, fsi problem, solids4foam
Fluid Domain moving with Rigid body Lloyd Sullivan CFX 3 August 17, 2018 10:58
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
