Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
Fluid to solid interfaces for an extremely large model.
Old   March 23, 2023, 21:43
Default Fluid to solid interfaces for an extremely large model.
Ben
Ben0000 is on a distinguished road
Hello, I've made a model using snappyHexMesh to create the mesh for a building and the air domain surrounding it, but I'm having difficulties with getting the model to run. I believe the issue is with the size of interface between the solid and fluid domains. When I ran the model with interfaceTransferMethod directMap, I got up to the following lines in the log.
additionalMeshCorrection: false
Selecting interfaceToInterfaceMapping directMap
At this point the program doesn't progress any further, I left it running at this stage for ~8 hours before terminating it.
Next I tried interfaceTransferMethod RBF. This resulted in:
Selecting interfaceToInterfaceMapping RBF
Time = 0.001
Setting traction on solid interfaces
Interpolating face values using RBF
Create RBF interpolator from fluid_to_solid to solid_to_fluid
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
ERROR
Finally I tried interfaceTransferMethod GGI, this resulted in:
Selecting interfaceToInterfaceMapping GGI
Time = 0.001
Interpolating face values using GGI
Create GGI zone-to-zone interpolator
interface-to-interface face error: 0.0237136
calcMasterPointAddressing() const
Extended GGI, master point distance, max: 0.325573, avg: 6.52438e-07, min: -0.331222
interface-to-interface point error: 0.331222
Number of uncovered master faces: 0
Number of uncovered slave faces: 0
Total force on fluid interface 0: (0 0 0)
Total force on solid interface 0: (0 0 0)
Evolving solid solver
Solving the momentum equation for D
setCellDisplacements: reading cellDisplacements
Corr, res, relRes, matRes, iters
ERROR
The program ran for about two hours after the second-last line, before outputting "ERROR" and stopping.
I'm thinking that the size of my model might be the issue, looking at solid/polymesh/boundary, the solid_to_fluid patch is defined as:
solid_to_fluid
type mappedWall;
inGroups List<word> 1(wall);
nFaces 4445923;
startFace 22265720;
sampleMode nearestPatchFace;
sampleRegion fluid;
samplePatch fluid_to_solid;
And similarly, in fluid/polymesh/boundary, the fluid_to_solid patch is:
fluid_to_solid
type mappedWall;
nFaces 4445923;
startFace 32173810;
sampleRegion solid;
samplePatch solid_to_fluid;
Given the large number of faces these patches have, I was wondering if there is an issue with how much memory is required. Watching the program whilst its running, my ram usage stays around 95%. Is there anyway to estimate the ram required for the ~4.5 millions faces? Also, does anyone know why the number of faces is not equal between the two patches? I modeled both the solid and air domain using a single snappyHexMesh, and then used splitMeshRegions to split the mesh into a fluid and solid domain. I did this as I thought it would make the two meshes conformal, but perhaps not? Thanks.
Ben0000 is offline   Reply With Quote
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
How to change a fluid model to solid? abose06 FLUENT 4 May 11, 2020 15:49
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Extremely high fluid temperatures with simple model Jason_2 FloEFD, FloWorks & FloTHERM 9 March 5, 2014 08:43
